The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 08-21-2007, 12:17 PM   #1
Custommx3's CarPC Specs
Custommx3's Avatar
Vehicle: 2007 Mazdaspeed6
My Photos: (7)
RR , Iguidance, and Xport3
Im using a GM-210 reciever. If I use it with Iguidance only it works great.
If I use RR with it exclusively, it works great...
BUT..
If I use Xport3 to split the ports to RR and IG, it takes 20+ mins to lock on and the updating in IG to my movements is VERY slow.
Any help would be appreciated.
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
Sponsored Links
Old 08-21-2007, 01:23 PM   #2
Machinehead's CarPC Specs
Machinehead's Avatar
My Photos: (0)
Xport3 was causing my system to BSOD.
I just set the GPS to Port 0 in RR.
Machinehead is offline   Reply With Quote
Old 08-21-2007, 03:01 PM   #3
Custommx3's Avatar
My Photos: (7)
well, I want to use it for my flash gauges.
2007 Mazdaspeed 6
Old 08-21-2007, 04:40 PM   #4
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
Can you list what ports you using for each?
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 08-21-2007, 07:54 PM   #5
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
BUT..
Is this when resuming froom hibernate? If you open XPort, do you see anything changing on the bottom of the XPort window during the first 20 minutes?
Bet you have bluetooth. Many times you can see the problem driver on the blue screen. Just change your virtual ports to something higher or make sure they don't conflict with other ports that may try to open later, the way some bluetooth drivers do it.
XPort 1.24 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 08-22-2007, 09:08 AM   #6
My Photos: (0)
No sir, no bluetooth. But I am running XP via VMWare fusion on a Mac Mini.
Of course I can't read the bluescreen on my 7" monitor because it's too small.
Old 08-22-2007, 09:19 AM   #7
Custommx3's Avatar
My Photos: (7)
Nothing changes..
I can go into IG and goto GPS info, I see 4-5 sats displaying signal bars, but IG says
SATS 0/7
I have tried using it directly in the back of the PC, or using a hub, no difference.
the GPS is on com 2
I have it split between com 4 and 6
4 is for IG, 6 is for RR.
I have also tried this with a PC and a laptop, same issue.
I have also tried GPSGate to, same issue.
But if I use it without a port splitter, it works fine!!
Would it matter if it was USB 1.1 instead of 2.0? I wouldnt think so as its only 4800bps.
2007 Mazdaspeed 6
Old 08-22-2007, 10:03 AM   #8
Raw Wave
Blue ZX3's CarPC Specs
Blue ZX3's Avatar
Vehicle: 01 Ford ZX3
My Photos: (16)
Which version of Xport are you using, as for a long time i used an older version and decieded to try the newest and then had all sorts of probs...went back to old version, rock solid.
Other ppl have mentioned that different versions work better with their setup than the others. Maybe this is your prob??
Blue ZX3 is offline   Reply With Quote
Old 08-22-2007, 10:23 AM   #9
Custommx3's Avatar
My Photos: (7)
Im was using v3 of xport.
Remember, Im using GPSgate right now with the same issue..
without a splitter, it works great individually, but with a splitter, I get no, or sometimes get signals.
2007 Mazdaspeed 6
Old 08-22-2007, 10:29 AM   #10
Raw Wave
Blue ZX3's Avatar
My Photos: (16)
All the probs occurring when running win in vmware? Or R you saying that you have also tried it on a full pledged PC/NON Mac with the same issues?
Sponsored Links
Old 08-22-2007, 11:22 AM   #11
MySQL Error
MatrixPC's Avatar
My Photos: (0)
Curiosity release sub-version (that is what Blue ZX3 was asking) once in a while or whenever people report bugs.
There are version 1.01 to 1.13.
All my hardware work best on 1.04 or 1.06 (can't remember)
Old 08-22-2007, 11:51 AM   #12
Raw Wave
Blue ZX3's Avatar
My Photos: (16)
I couldn't remember which one I use either...as I really don't care. It just works.
Old 08-22-2007, 02:42 PM   #13
Custommx3's Avatar
My Photos: (7)
Ive tried 2 different PCs, my carPC itself and a laptop with the same issue.
Those who have a working one, would you mind sharing your version of Xport so I may test it?
2007 Mazdaspeed 6
Old 08-22-2007, 07:49 PM   #14
Raw Wave
Blue ZX3's Avatar
My Photos: (16)
This is the one that I have been using.
Old 08-23-2007, 04:27 AM   #15
Vehicle: 91 Ford Probe
My Photos: (0)
Just want to say that I'm using XPort3, latest RoadRunner and IG2.1.2. Everything works fine. Did you set the correct baudrate in XPort ?
Konrad is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
How to setup iGuidance GPS for RoadRunner MatrixPC RR FAQ 27 07-08-2008 10:34 PM
Digital FX 2.0 Transparent Released JohnWPB RR Skins 3759 03-07-2008 12:23 PM
xport3. Errors service 1073 and confused driver? Gearhead61 GPS 1 01-10-2007 03:45 PM
iGMon - Solution for integration between iGuidance and Road Runner (I hope) b8bboi RR Plugins 567 10-07-2006 09:52 PM
RR, Xport and GPS Naesstrom Road Runner 7 08-19-2006 03:34 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
