09-14-2007, 11:51 PM
#1
some music wont play
I've registered my winamp.dll and i set my music types to .mp3,.wma and all my music still wont play  any thoughts? Thanks, Drew
1998 Camaro Worklog Pioneer P860MP, 3 JL 500/1's, JL 300/4, 3 12" Type R's, Diamond m611's
09-15-2007, 12:48 AM
#2
RoadRunner Mastermind
Does any music play ? did you by any chance register winamp.dll and then moved it somewhere ?? are you able to play the same files in winamp alone (outside RR) ?
Road Runner,RR's Myspace
09-15-2007, 12:50 AM
#3
i didn't move the dll. I can't play the files in or out of rr while i can play others.
09-15-2007, 02:32 AM
#4
Road Runner & Mp3car Gatherings Moderator
Just a stab in the dark here, but if you cant play them outside of RR, I would possibly, tend to thing, that is is not a RR related issue
Sounds like you just downloaded some bad / corupt MP3's
09-15-2007, 11:36 AM
#5
ok well then i guess it'd be a winamp issue since i ripped the cd's and they play perfect in window media player.. any ideas on that? they used to play in winamp. I'm using 2.95
09-15-2007, 11:46 AM
#6
Just so we are clear, the CD's play fine, but not the rip'd MP3's do not. It just sounds like a bad rip for some reason, Is it a lot of mp3's or just ones on certain CD's that were ripped from?
The more information you can provide, the better.
#7
Are they .mp4?
Ampie Case
2.5" Hard Drive 80GB Toshiba 5400rpm
Kingston 512 MB DDR RAM PC3200
Xenarc 700TSV - VGA Monitor
VIA EPIA M10000 Mini-ITX Mainboard
M1-ATX 90 Watt - Smart Power Supply
2005 Honda Civic
09-15-2007, 07:16 PM
#8
guess he ripped some cd tracks
the ripped tracks play fine on WMP but not on winamp
is that the question?
you ripped it to .wma or .mp3? constant bitrate or VBR? wich bitrate?
as john said, the more info, the better
[]s
09-16-2007, 02:13 AM
#9
ripped as .mp3 at 192kBps
They work perfect on windows media player but not winamp.
I have version 2.95 and have downloaded it several times to make sure it's not corrupt and tried it on different computers without any problems. To top it off tonight i installed winamp 5.3 and it works perfect, but i'd like to not use it because of the performance side effects.
| Thread Tools |
| Display Modes |
Linear Mode
