try looking for those and setting/adding them (when not already present) in RR.INI:
mapmastervolume=0
fadeinvolume=false
If you already have those in place, open winamp and switch the Output plugin from Waveout to DirectShow or the other way around, then try again. If anything, try uninstalling and deleting Winamp's folder then re-installing.. this is most likely a setting issue, but you can try a different winamp version.
Normally this problem just happens when not using the mastervolume map or when screwing with winamp's settings.
Road Runner,RR's Myspace
