Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 10-12-2007, 12:56 AM   #1
sparkyssb is on a distinguished road
iG and RR - GPS Port Issue
Alright...iG works fine stand alone. It uses the GPS on com 6. I am using Blue's config utility to setup iG with RR and I have no probs embedding iG with RR, except that it does not see the GPS data, even though I had the GPS port set to 6 within the RR config utility. So then I setup Xport and told com 6 to duplicate into com 10. Then I setup RR with the GPS port of 10........still no go. Any ideas on what I'm doing wrong? Thanks.
sparkyssb is offline   Reply With Quote
Old 10-12-2007, 03:23 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
you have to think of it as a splitter. Xport has to send the COM data from port #6 to 2 other ports. Then iGuidance needs one of those split ports and RR needs one of those split ports. If iG is using #6, then Xport cannot, and then cant send it out tothe other ports.
Old 10-12-2007, 07:07 AM   #3
kbreeden
Sparky, here's what you need to do:
Close Xport. Open iGuidance outside of RR. Go to tools/GPS Options/autodetect. After a minute or so it will tell you what com port iGuidance is using (should be 6 per your post). That's the port your GPS receiver is using and should be the port set as input in Xport. Exit iG.
Now load Xport. In Xport set the input port to the port determined above. In Xport hit scan. Then pick two available com ports in the output section. Make a note of the two outputs you have chosen. The first output port will be for iG and the second will be for RR. Hit enable in Xport. (Try to make the port you use for iG only one digit as some have reported problems with iG if using a two digit port.)
Open iGuidance outside of RR. Go to tools/GPS Options/com port and select the first output port selected in Xport per the above. Exit iGuidance. Go into RRConfig and in the GPS section put the number of the second output port in Xport per above. Save config. All should now work.
kbreeden is offline   Reply With Quote
Old 10-12-2007, 09:25 AM   #4
Awesome. Thanks to both of you guys, I got it to work! Take care.
The GPS Locks up RR! wsudu Road Runner 3 09-10-2007 12:17 PM
Focus lost when switching to GPS - RR nor iG has focus cMags RR Bug Tracker 7 05-22-2007 09:36 AM
IG and RR.....New Issue mobileT83 Road Runner 4 12-28-2006 03:30 PM
IG in RR..help please avix Road Runner 2 03-27-2006 03:18 PM
IG, Works on it's on but not in RR (No GPS) tbird2340 Road Runner 5 03-11-2006 02:48 AM
