The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Search this Thread Display Modes
Old 10-13-2007, 07:58 AM   #1
kbreeden's CarPC Specs
Vehicle: 2005 Acura TL
My Photos: (0)
Has Anyone Using RR/DigitalFX/New RRConfig/iG4 Gotten Music to Pause?
I've posted this question in the bodies of a couple of threads, but nobody has answered. Hopefully, it will get more attention in its own thread.
A few of us who are using the combination of newest RR, newest RRConfig, newest DigitalFX and iG4 are unable to get music to pause when iG is saying directions. It worked flawlessly for me with the previous versions of all of those.
So the question is: Has anybody using that combination been able to make music pause when iG is saying directions?
If so, I sure would be interested in seeing your RRConfig settings and rr.ini entries.
kbreeden is offline   Reply With Quote
Sponsored Links
Old 10-13-2007, 09:25 AM   #2
nst6563's CarPC Specs
Vehicle: 2004 Nissan Maxima
My Photos: (0)
I haven't been able to get that function to work either. Haven't even gotten it to simply lower the volume. This is quite annoying though. As a way around it, I have set my wave volume to around 80% and the IG volume all the way up. This way at least the IG voice is slightly louder than music. Downside to this though is I have to turn up the volume twice as much as compared to the factory radio/cd. If I leave all the volumes at max, then the factory radio/cd volume matches the carpc volume...but then you can't hear the IG directions very well.
catch 22 right now.
I'd be interested in a fix as well. Tried everything I've seen in threads to get it to work, but nothing seems to work. Going to re-install everything this morning though.
nst6563 is offline   Reply With Quote
Old 10-13-2007, 09:38 AM   #3
My Photos: (0)
catch 22 right now.
Thanks, nst. Please let us know if reinstall is successful.
Old 10-13-2007, 11:49 AM   #4
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (130)
pauses for me just fine.. it pauses the same way in every skin just fine using the new config
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail, & CentraFusion
Old 10-13-2007, 05:21 PM   #5
My Photos: (0)
Thanks, Sonic. I know you use your own skin, though, and am curious whether you've done it in DigitalFX.
Old 10-13-2007, 06:15 PM   #6
fixerofallthing's CarPC Specs
fixerofallthing's Avatar
Vehicle: 2004 GMC Canyon
My Photos: (20)
I have it working fine in DigitalFX
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline   Reply With Quote
Old 10-14-2007, 07:21 AM   #7
MySQL Error
My Photos: (130)
the feature is really skin-independent.. its something thats set up for you in the new rrConfig. if the config detects you're using ignative and have pauseonvoice enabled... it will as you if u'd rather lower the volume. If you hit yes it works no matter what skin you use.
03 Acura RSX Coupe
Old 10-14-2007, 07:45 AM   #8
TonyWare's CarPC Specs
TonyWare's Avatar
Vehicle: 2003 Accord V6 Coupe
My Photos: (22)
Perhaps someone can re-create this.
Go to config, GPS and check the iG Native. The name of the window is iGuidance and the external radio-style button is set. The check button to reduce the volume is set and its at 10%. So now the IG Native panel (in the tree under GPS) is enabled so go in there and check all the checkmark-style buttons (the 2 auto switch and the pause). Save and exit.
Start RR with DFX (both latest and greatest). Start music, go to gps screen, make IG say something, whatever. Go back to main menu, exit application.
Go back to config and see if the 2 autoswitch checkmark-style and the auto pause are checked in the iGNative panel under GPS. Mine were unchecked even though I checked them when I setup using the config.
Perhaps these steps will give some clues to the folks who know the source code inside out.
TonyWare is offline   Reply With Quote
Old 10-14-2007, 12:13 PM   #9
My Photos: (0)
Sonic, I know that is supposed to be the case; however, n DigitalFX, volume will not pause or lower no matter what I do. I have spent hours trying to figure it out. It worked flawlessly for me until I loaded the new versons. DigitalFX does have an iGuidance autoconfig screen so there is some possibility for conflict, though I assume all the autoconfig does is put the appropriate lines in rr.ini.
Old 10-14-2007, 12:14 PM   #10
My Photos: (0)
I have experienced similar results.
Sponsored Links
Old 10-14-2007, 12:17 PM   #11
My Photos: (0)
Are you using RR (9/30), DigitalFX(9/9), RRConfig (10/10) and IG4?
Old 10-14-2007, 01:17 PM   #12
MySQL Error
My Photos: (130)
have you checked the skin exectbl.ini to see if you have a duplicate pause setting by chance? duplicate entries tend to cancel each other out in RR
03 Acura RSX Coupe
Old 10-14-2007, 01:43 PM   #13
TonyWare's Avatar
My Photos: (22)
Thumbs up
Bingo! Thats the issue (thank you!).
Found an extra set of pause related lines in the exectbl.ini under the rr directory. Don't ask me how they got there, I don't remember if I put there there myself while I was playing around or it came with it. The only pause-related lines now exist in the exectbl.ini under the DFX skin itself and everything else has been commented out.
/ Toggle the Auto Pause of Winamp On and Off when iGuidance Speaks
"AUTOPauseON","SETVAR;pauseonvoice;1||SAVETOINI;pa useonvoice;1||SETIND;!AutoPauseOn;ON||SETIND;!Auto PauseOff;OFF"
"AUTOPauseOff","SETVAR;pauseonvoice;0||SAVETOINI;p auseonvoice;0||SETIND;!AutoPauseOn;OFF||SETIND;!Au toPauseOff;ON"
Still for the music to go all the way down to 0 the IG volume should be set to 4 out of the 5 lines in the IG volume menu for the music volume reduce to work.
Old 10-14-2007, 07:10 PM   #14
My Photos: (0)
Thanks to Sonic, it appears that we're starting to nail down this issue. I found two exectbl.ini files, one in the Road Runner folder and the other in the DigitalFX folder. The one in the Road Runner folder was created by RRConfig. That tells me there must be some sort of conflict going on between the new Config and DigitalFX. I deleted the exectbl.ini in the RoadRunner folder and the music volume is now lowering when iGuidance speaks, but it is not pausing. I can live with that because at least now I can hear the iGuidance directions; however, I prefer pausing. FWIW, screen switching is working just fine. Maybe Blue and JohnWPB can get together and figure out how to eliminate this issue.
Old 10-14-2007, 07:13 PM   #15
My Photos: (0)
Tony, I'm a little confused by this statement. Are you getting the music to actually pause or just reduce to zero volume?
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 11:19 AM
Music Indexing aforget StreetDeck 6 02-06-2007 10:25 AM
DISH TV music storage project... claylong General Hardware Discussion 2 04-16-2003 09:08 PM
Sponsored Links
Ad Management by RedTyger
