10-16-2007, 09:34 AM
#1
Issue TRYING to install Road Runner
Problem im having with Road Runner is, I download it from either the main site or the link, then I unzip it, but not all the files unzip... I test the file and it comes back fine... I try and select single files to extract and I just get an error
I run the installer and I can get into the config but then it trys and run RR and it says road runner is missing...
I had multiple people uncompress it for me and get the same results... its driving me crazy!!
HELP!!?!?!
10-16-2007, 10:16 AM
#3
HELP!!?!?!
Heard about this before......I think it turned out to be the AntiVirus program. (NOD 32 if I remember right) Try disabling your AV while you D/L & unzip.
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
10-16-2007, 10:17 AM
#4
NOD32 isnt even running
10-16-2007, 10:30 AM
#5
Terminal flasher
was the rr installer/updater tool not available.. check the sticky in the main forum.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
10-16-2007, 12:29 PM
#6
Sure you aren't running an old version zip program?
I had a hedace with this once and it turned out to be a outdated version.
10-16-2007, 12:31 PM
#7
Its not the Zip program.... reason is even when I run the installer, files come up missing... like roadrunner.exe and a few others....
Im about to give up on RR
10-16-2007, 12:35 PM
#8
THE EXPERIMENTER
are you able
to install on another machine,and see if its the same ,atleast then you know its the machine and not the download, also can you do a sreen shot of your rr folder after an install.
10-16-2007, 12:36 PM
#9
I don't have a machine available.... I have to build one and cant do that right now....
10-16-2007, 12:48 PM
#10
Any AntiVirus ???
#11
already went through that..... no anti virus is running
10-16-2007, 01:00 PM
#12
THE EXPERIMENTER
you said you had to unzip it
did you download the installer which is not zipped or the binary which is zipped.
use the link i put up in the above posts and try it, i have just downloaded the installer setup five times and ran each 1 with success.
10-16-2007, 01:01 PM
#13
thats the one I tried to install....
send me a screen shot of the files after the install and I will send you mine
10-16-2007, 01:12 PM
#14
THE EXPERIMENTER
give me
a few minutes want to try something 1st,
| Thread Tools |
| Display Modes |
Linear Mode
