this would require you to zoom into the maximum zoom to be of any use with iguidance. iG's maps are not very detailed. It would not require freefone at all because freefone only uses bluetooth serial port access. In fact freefone would have to be disconnected on most phones because of the 1 bluetooth connection limitation.
From there u'd need a way to make ur computer autoconnect to the file transfer protocol in your bluetooth stack. Iguidance does not screen capture so you'd have to write an autoit script to take a picture of a predefined spot on your screen (this would change depending on window title/ skin/ etc) then have the autoitscript send the image to a recongizable spot on your phone. Because different phones have different spots for that kinda storage u'd have to have a way of customizing it amongst alot of different phone models.
In summary... great idea but it would take quite a bit of input for alot of different sources to make work and to make usuable to the masses.
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail, & CentraFusion
