Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 11-01-2007, 11:11 PM   #1
forrestang is an unknown quantity at this point
Problem browsing for Music in RR?
Hello,
I seem to be having a small problem with brosing for music. The FAQ on this topic confuses me......I'm new to this. I am using CDR's Iphone skin.
I can't really see or play my media files inside road runner? Actually, if I play a song before entering Winamp, this song will continue to play upons starting RR.
I can play all of my MP3 files fine from winamp. But when I start RR and go to audio, and switch the folders I have my music in, it either doesn't show up at all, or when I go to browse in that folder they files are in within RR, nothing is there?
Example, for now I have all of my folders with music in: C:\Documents and Settings\Speed6\My Documents\My Music\
Within that folder I have several other folders that contain mp3s.
My "Music Path" in my config file is set to: C:\Documents and Settings\Speed6\My Documents\My Music\
But I am having this problem. Any ideas, was this something you experienced too, or is this just some weird occurance?
Thanks,
Forrest
2006 MazdaSpeed6
Bigger Turbo, tuned with supporting mods.
-CarPC in car and completely functional.....still tweaking minor things.
-Still trying to figure out the CarPC thing :)
Last edited by forrestang; 11-01-2007 at 11:14 PM. Reason: Mods please delete, I'm asking in a similiar thread.
forrestang is offline   Reply With Quote
Old 11-01-2007, 11:17 PM   #2
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Have you registered the winamp.dll?
Enforcer is offline   Reply With Quote
Old 11-01-2007, 11:35 PM   #3
If you mean just registering Winamp when you first install it, I'm pretty sure I did?
I think it's the part when they ask if you want 50-free offers or somethign. I let it connect the wimanp server.
Everything works fine outside of RR though. I just can't browse within RR.
Forrest
2006 MazdaSpeed6
Old 11-02-2007, 12:28 AM   #4
Confusion Master
Enforcer's Avatar
No not registering with winamp(nullsoft), but registering the DLL.
In a recent update to RR it no longer uses the winamp.exe it uses winamp.dll, and this needs to be registered.
Easiest way to do this is to download the latest RRConfig and run that, it should do it automatically.
Old 11-02-2007, 01:29 AM   #5
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Just love comments like this...but I do not think that is whats causing the problem. He is not complaining about song selection control problems, he says that he can not see any of his music in RR, which by defalt uses a file browsing method and with or w/o winamp, should not effect RR ability to browse folders/files.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 11-02-2007, 02:12 AM   #6
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Delete the audiofiles= line from RR.INI, make sure your files are no hidden or set with a system attribute, and make sure your musicpath is pointing to the right place.. then it should work.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 11-02-2007, 09:13 AM   #7
jumbodogs's Avatar
jumbodogs is an unknown quantity at this point
In case you didn't do this. Run RR config then select page 1 under music on the left side. Down on the right side you need to select what type of files you want to show up like .mp3 and whatever else your music is stored as.
jumbodogs is offline   Reply With Quote
Old 11-02-2007, 09:32 AM   #8
Confusion Master
Enforcer's Avatar
Yeah oI know, just had to wash my mouth out with soap
Old 11-09-2007, 10:13 AM   #9
Ok, I deleted the audiofiles line from rr.
Now I can load the music, but I have to drag the music over the 'Load' button everytime. And to switch to another folder with specific playlists, I have to drag the entire folder, then hit the root button, which will then show all of the playlists, then I have to drag the spefic playlist over to Load.
This is a bit cumbersome. Is there a way I can navigate through the menu like you would normal folders?
Like click the Playlist folder which would show all of the folders in there, then click on the particular playlist folder I have, then click on the song?
Sort of navigate the normal way you can with windows to find files you want?
2006 MazdaSpeed6
Old 11-09-2007, 01:42 PM   #10
The Curator
Blue ZX3's Avatar
HOW CAN YOU PEOPLE HAVE SUCH A HARD TIME WITH SOMETHNG SO SIMPLE???
"but I have to drag the music over the 'Load' button everytime", WHAT? That makes no sence to me...
Do this...
http://www.mp3car.com/vbulletin/416744-post1.html
Link will be at the top of the list and will jump directly to your playlist folder...
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-09-2007, 02:00 PM   #11
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
if i remember right
cdr uses drag and drop feature in his skins
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is offline   Reply With Quote
Old 11-09-2007, 05:13 PM   #12
Nomader's Avatar
Nomader is on a distinguished road
Do this...
Blue has started newbies
I am going on a strike, and will use notepad for a week..
Nomader is offline   Reply With Quote
Old 11-09-2007, 06:17 PM   #13
The Curator
Blue ZX3's Avatar
Yeh, I have to blow a fuse once and awhile...
Can't just hold all that what I said above in forever!
Pressure relieved, should be back to normal...whatever is considered normal? LOL
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 11-09-2007, 08:12 PM   #14
Do this...
Thanks, I read that one before I posted this thread.
2006 MazdaSpeed6
iGuidance v2.1.2 into RR: Window problem sjj Road Runner 11 04-28-2008 05:51 PM
rr Problem starting 09-30-07 version maxzor Road Runner 1 10-21-2007 10:49 PM
Weird volume problem - is it RR?? sqkev Road Runner 3 11-27-2006 02:06 AM
RR 03-06-06 AVS problem mauri Road Runner 18 04-09-2006 12:40 AM
Problem with RR and 640x480 skins. bosse RR Skins 10 09-19-2005 04:59 PM
