12-01-2007, 08:12 PM
#31
High Voltage
Newest version is working perfect for me, with winamp, FMOD, internal video, CD's, mp3's everything is quite fast and stable. Problems are probably in your guys config files. Most likely rr.ini. Will be pushing the new HD code in about a week
12-03-2007, 01:55 PM
#32
sometimes resuming from hibernate the lists still dont show up, although i cant really reproduce it accurately. only solution is to restart rr. i should be getting a new carpc in a few days and will try it out on that with a full windows install instead of nlite and go from there.
12-03-2007, 04:08 PM
#33
Raw Wave
That's a bug in DirectX, don't tear-up your system. Search for "ilist hibernate" and you'll find the work-arround.
12-04-2007, 06:30 AM
#34
Checked RR.ini, seems all OK in there. Rescanned library from WinAmp and also in LSXVOID skin. Still same problem, even after a fresh re install ( reformat, etc....).
GUINO, did you have any chance checking the file I uploaded ? Thx
12-04-2007, 09:14 PM
#35
Anyone else having a problem with Ilist's disapearing when left idle?
If I leave the screen idle for around 5 secs or so, the entiere list disappears. A "touch" on the blank list brings the songs display back but it will go blank again after 5 secs. More of an anoyance than anything.
Is this a setting somewhere for "autohide" or some other sort of thing?
I'm using void 3.2, the newest RR (04/11/07), and a full xp install...........
Leonardo Da Vinci
12-04-2007, 10:13 PM
#36
what you are describing is the auto album art feature in void. its showing up blank for you because the song you are on doesnt have any album art specified. there is an option to turn the feature off.
12-05-2007, 12:19 PM
#37
yup, thanks. got it............
Leonardo Da Vinci
12-07-2007, 02:26 AM
#38
just jumped onto guino's website and noticed theres a 12-06-07 release...
Quote:
Dec 6th, 2007:
* Added Single Image Slider
* Added SETVARBYIND command
* Added fade support to "file" and custom indicators
* Added ADD1 dynamic command for scripts
* Added iList Position Slider Codes
* Added RADIORESET command for all radios
* Fixed Built-in video player "SELECT" bug
* Fixed Radio Playlist issue when using line in plugin
* Fixed issue with SETPATH not selecting first item of list
* Fixed issue with iList long scroll when using large lists
* Fixed issue with loading iList on menu.skin
* Improved Resolution setting to not change resolution not present
* Improved Audio/Video Art preview
* Improved INC Definition so it can accept variables
* Improved IMG Def so it can accept full paths
2005 Nissan Xtrail
DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
worklog
12-07-2007, 10:08 AM
#39
The Last Good Gremlin
Yea, but its got problems with MP3Art plugin.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
12-07-2007, 11:47 AM
#40
and i noticed the EXE is over 2 Mb!!!
12-07-2007, 12:10 PM
#41
Terminal flasher
i'd imagine thats simply because he hasnt compressed it yet. Uncompressed the binary .exe is usually around 2.5- 2.7MB, but compressed it goes down to around 700kb.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
12-07-2007, 01:28 PM
#42
i tried the ilist sliders..
the playlist sliders looks fine,but stops in the middle of the list
the DL slider works fine
the PB slider does not display correctly..
but we will start bug reporting as soon as Guino releases this..
12-07-2007, 11:19 PM
#43
Is there any place that mirrors the RoadRunner source code? The 2 spots on the official site don't actually have it.
12-08-2007, 04:16 PM
#44
Does anyone know where I can find or kindly send me the 11-2 version? Having problems with embedded album art display with 12-6. Thanks!
12-08-2007, 10:24 PM
#45
The Curator
| Thread Tools |
| Display Modes |
Linear Mode
