11-26-2007, 10:58 AM
#16
I've allways had this problem, i just accepted it and learned to live with it
11-26-2007, 09:20 PM
#17
I used to have an Audigy 2NX but it wouldn't upmix my stereo mp3 to its 5.1 outputs so I traded it for an older Extigy which does that nicely. However, I also found that the Extigy (USB) loses its subwoofer settings and the linein mute state after resume. The checkboxes in its control program are correct but I have to uncheck/recheck them to get them to work. After looking for the "correct" way to fix the problem without any luck, I just wrote an Auto-It script that fires upon the RR onresume feature. The script brings up the sound control panel, does all the clicking, and then re-minimizes the panel. FWIW, here's the script if you want to tweak it for your sound card:
Code:
If Not WinExists("Creative Audio Mixer") Then ;start the Extigy mixer after a hibernate/resume operation
$x = Run("C:\Program Files\Creative\SBExtigy\USB Mixer\USBMix.exe","C:\Program Files\Creative\SBExtigy\USB Mixer")
WinWaitActive("Creative Audio Mixer")
EndIf
WinActivate("Creative Audio Mixer")
WinMove("Creative Audio Mixer", "",0,340) ;move dialog to a known location for subsequent mouse clicks
Sleep(100)
MouseClick("left",50,545) ;click the options button
Sleep(100)
MouseClick("left",50,515) ;click playback options
Sleep(100)
ControlCommand("Playback Properties","","Button5","uncheck") ;uncheck/check the bass redirection control
Sleep(500)
ControlCommand("Playback Properties","","Button5","check") ;this restores bass redirection after a hibernate/resume
Sleep(500)
ControlClick("Playback Properties","","Button1","left") ;close the playback properties window
Sleep(100)
MouseClick("left",330,498) ;click linein mute
Sleep(1000)
MouseClick("left",330,498) ;click linein mute again
Sleep(500)
WinSetState("Creative Audio Mixer","",@SW_MINIMIZE) ; re-hide the mixer
I'm sure an AutoIt guru could tweak this a bit, but it works for me!
Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
01-11-2008, 01:23 PM
#18
I have intermittent audio problems coming out of hibernation as well w/ my USB Creative sound card.. So there is no real fix for that?
01-12-2008, 05:21 PM
#19
I have the Audigy NX card. It is well-known to have this issue, unfortunately. Someone has found a remedy, but it requires losing SP2 altogether, and reverting to SP1. Apparently, it's SP2's USB handling that causes the issue. If you go back to XP SP1, the Audigy card will hibernate and resume properly.
The only thing you can do if you're on SP2 is make sure that you close whatever app is using the soundcard, before you hibernate. So if you're using RR/Winamp, you have to close it before you hibernate. Then, when you resume from hibernate, you wait about 10 seconds, and the Audigy will re-initialize itself. Then you can restart RR. It's a pain in the a**, but it's better than having to reboot the pc.
01-12-2008, 08:30 PM
#20
I'm using XP SP2 & RR. If the PC hibernates & the power to the Audigy 2NX remains ON, it recovers properly. If power to the Audigy is removed during or after hibernate, the PC sound driver won't load correctly after recovery from Hibernation.
Did some follow ups with Creative Tech Support & they insists that it should work well with Hibernate mode. Guessed I'm ****ed off after all the trials & errors.
Now in the lookout for some decent SQ USB soundcard that support RR in Hibernate. Any recommendations?
| Thread Tools |
| Display Modes |
Linear Mode
