11-11-2007, 11:53 AM
#1
Vehicle: 2003 Mercedes C230
USB sound card supported by RR
i was on newegg and I saw these two USB sound cards. Anyone have experience with either? anyone know which one is supported by RR for Bass and treble functions?
tia
Turtle Beach Audio Advantage Micro Virtual 5.1
GWC USB 5.1 Channel Audo Adapter
11-11-2007, 12:30 PM
#2
Vehicle: 95 Nissan Hardbody
im pretty sure RR isnt bias about sound cards since its your pc and media player that do the work RR just uses the functions of it.. as long as its supported on your OS you should be fine
11-11-2007, 01:14 PM
#3
MySQL Error
Vehicle: 2003/Acura/RSX
RR is very bias when it comes to treble and bass control.. i doubt anything thats out now will work with those controls honestly.. i've never seen ANY card make use of the control
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
11-11-2007, 01:28 PM
#4
hmm thats interesting... im almost tempted to buy streetdeck and scratch RR since the only thing i can get working in the damn thing is my music and video.. cant get the dvd software to work, cant get my phone to work, cant get my gps to work, cant get the sat radio to work... no matter who i ask nobody ever answers meh screw RR
gl with your usb audio
11-12-2007, 04:48 AM
#5
I tried to use the USB Audigy 2NX with RoadRunner. Everything works great. However when I recover from Hibernate mode, there is a problem with the sound driver reloading & the Winamp won't recover properly.
Anyone had any success with this USB SD with RR & Hibernate mode?
11-12-2007, 11:19 AM
#6
i'm contemplating on getting this because the output from the laptop is not loud enough. I've tried 2 different RCA Y splitters so that's not the problem. if i turn the laptop volume to 100%, then switch over to AM/FM radio on the headunit, the headunit's volume is about 25% louder. I'm trying to even it out. the only other possibility is to put some gain plugin in winamp for all the songs.
11-12-2007, 01:22 PM
#7
RoadRunner Mastermind
Vehicle: 04/Mazda/RX-8
Did you try to disable the on-board sound and set usbsound=true in RR.INI ?
Road Runner,RR's Myspace
11-12-2007, 07:03 PM
#8
Yes. I've set the audio device to Audigy 2NX & set usbsound=true.
I also found out if the Audigy 2NX 5V power is "ON" all the time, RR & Winamp will work once it recovers from Hibernate. If the 5V is powered OFF & then ON when the PC recovers from Hibernate, it will mess up all the sound drivers. Attached is a screenshot of the problem :
11-12-2007, 07:56 PM
#9
this is typical driver issue with USB devices..
11-13-2007, 01:51 AM
#10
Road Runner Moderator
Vehicle: 99 Mitsubishi Eclipse
Actually, the bass and treble work on both my desktop test machine, and on my car PC (which has on-board audio). Yes, it can be fickle, but is more of a hardware issue than a RR issue it seems.
As for the laptop not putting out enough audio, that is actually very strange. If you hook the cable to your headphone jack, and not the line out, you should get way more volume than you could ever want. I have it set up this way, and have the carpc volume set to around 30%, as putting the PC volume to any higher distorts the audio, and just control the volume with my head unit.
I prefer a real volume control personally. Also my HU has Auto volume, so if I put the windows down, the volume will increase automatically.
11-13-2007, 03:59 AM
#11
 . Looks like I'll have to accept my current onboard sound. Unless I want to setup another carpc with 5.1 sound card?
Anyway, thanks for all the excellent contributions.
Cheers!
11-13-2007, 05:55 AM
#12
Are you able to recover functionality of your USB sound card after hibernation (i.e. by closing and re-opening winamp)?
11-13-2007, 09:13 AM
#13
thanks for the response. i have it on the headphone jack. it's just basic onboard sound. with headphone out and microphone in. i'll just have to play around with it some more.
thnx!
11-13-2007, 09:28 AM
#14
Nope.. It only recovers if I re-boot the PC.
11-26-2007, 04:36 AM
#15
Vehicle: Nissan R33 GTS-T
What does usbsound=true actually do?
| Thread Tools |
| Display Modes |
Linear Mode
