Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 11-24-2007, 12:56 PM   #1
MGD
MGD's Avatar
MGD is on a distinguished road
HD Radio Commands
DO we have somewhere a list of available commands and indicator codes for the HD Radio?
RDS an STEREO don't semm to work.
MGD is offline   Reply With Quote
Old 11-24-2007, 08:43 PM   #2
Raw Wave
mitchjs is on a distinguished road
i think they are in the skin commands text file
thats where i saw em
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 11-25-2007, 09:24 AM   #3
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
I made a list for my own reference not too long ago... And here it is..
INdicators:
"HDACTIVE" - HD Radio Signal Active (For MitchJS's HD Radio tuner)
"SURF" - Radio Surf Mode (Same as "SCANMODE")
"STEREO" - Radio Stereo (Works with DLink, Cinergy & HQCT ONLY)
"SCAN" - Radio Scan Mode (Indicates whether FREQ+/- will "seek")
SLider Codes:
"HDSIGNAL" - HD Radio Tuner Signal Strength (Road Runner Only -- for MitchJS's HD Radio Tuner only)
"RSIGNAL" - Signal strength of the radio station received
--- Radio Support Labels ---
"HDARTISTX" - HD Artist on Sub Channel X
"HDTITLEX" - HD Title on Sub Channel X
"HDSUB" - Current HD Sub Channel
"HDSUBCOUNT" - Number of Sub Channels Available for current Station
"RDSNAME"/"RDSTEXT" - Those also may provide information about the Current Station for HD Radio
"FMAM" - Inficates if the current frequency is FM (True) or AM (False)
"FREQUENCE" - Radio FrequencY (Yeah, it's misspelled to support older MediaCar skins)
"STATION" - Current Station Name (Radio)
"PRESET" - Current Preset Number (Radio)
"RDSNAME" - RDS Name of Station (if any)
"RDSTEXT" - RDS Text from Station (if any)
"RDSSIGNAL" - RDS Signal Level (SiLabs Radio Card Only)
"PTY" - RDS Program Type currently received (PTY)
--------------------Commands:
"HDSUB" - This allows you to select the HD Radio SubChannel for the current station.
Example: "HDSUB;1" (First Channel -- default)
"HDSUB;2" (Second Channel).. and so on from 1 to 6
"RADIO" - Loads the Radio Player Screen (radio_player.skin) -- Same as "LOAD;RADIO_PLAYER.SKIN;RADIO"
"PLAY" - Cycles through a Play/Pause state of current song. (RR Only) When Radio is ON, acts as "PRESETMODE"
"STOP" - Stops the playback of current song. (RR Only) When Radio is ON, acts as "SCAN"
"FREQ+" - Increases Current Radio Frequency
"FREQ-" - Decreases Current Radio Frequency
"SCAN" - Turns On/Off Scan mode in the Radio Screen. In scan mode, freq+/- act as a seek function.
"SURF" - Same as "SCANMODE" (below)
"TUNE" - Shows NUMPAD to enter a frequency/channel to tune into on Radio/XM/SIRIUS
"PRESET" - Shows NUMPAD to enter a preset number to jump to (Radio Only)
"RADIOMUTE" - Mutes/Unmutes the radio
"FUNCTION" - Shows up the RADIO_MENU_FUNCTION.SKIN menu.
IN RADIO_MENU_FUNCTION.SKIN:
"ADD" - This shows the OSK and allows you to enter a name to save the preset for current frequency.
"MOVE" - This allows you to use UP/DOWN to move a radio preset into a position of liking.
"MODIFY" - This shows the OSK and allows you to edit the name of the selected preset.
"DELETE" - This deletes the selected preset.
"SCAN" - This searches any stations and adds them to the playlist as presets
"SCANMODE" - Toggles scan mode. This works with MP3, TV and Radio as well
"ADDPRESET" - This shows the OSK and allows you to enter a name to save the preset for current frequency
"DELPRESET" - This deletes the selected preset
"EDITPRESET" - This shows the OSK and allows you to edit the name of the selected preset
"PRESETUP" - Switches to Next Preset
"PRESETDOWN" - Switches to Previous Preset
"SEEKUP" - Seeks (finds) next Radio Station
"SEEKDOWN" - Seeks (finds) previous Radio Station
"TUNEUP" - Changes Frequency UP by 1 MHz
"TUNEDOWN" - Changes Frequency DOWN by 1 MHz
"FINEUP" - Changes Frequency UP by 0.1|0.2 MHz (0.1 is used when Allowing all frequencies)
"FINEDOWN" - Changes Frequency DOWN by 0.1|0.2 MHz (0.1 is used when Allowing all frequencies)
"MONO" - Toggles Mono/Stereo mode of Cinergy 600 and Radiator supported FM tuners
"PRESETMODE" - Toggles Preset Mode ON/OFF. When the RADIO is ON, "NEXT"/"PREV" work as Seek UP/DOWN.
In Preset Mode, "NEXT"/"PREV" switch presets UP/DOWN instead of seeking the radio.
"SEARCHPRESETS" - Enter the search preset mode (Radio). This clears and adds found presets onto the preset list.
"LOCAL" - Toggles the Local Mode for the Radio Presets. While in local mode, any changes presets
that are searched, added, edited or deleted do not affect the main list of presets.
"AF" - Toggles the RDS Alternative Frequency function.
"TA" - Toggles the RDS Traffic Announcement function.
"PTY" - Toggles the RDS research by program type (PTY).
"FMPRESET" - Save/Load a Preset for the current Radio frequency. You can use this to make preset buttons for
the radio feature. Presing and holding the button will save the current frequency to the name
specified to this preset. Pressing the button normally will load the named preset frequency.
Example: "FMPRESET;PRESET1" (load/save current frequency from/to preset name PRESET1)
"RADIOBAND" - Toggles AM/FM Band
ThunderStick is offline   Reply With Quote
Old 11-25-2007, 09:25 AM   #4
One Sharp Cheddar
Taken from the Skin Commands txt
Old 12-09-2007, 01:09 PM   #5
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
Good thread to start, working on my HD menu skin also.
Is there a way to save the presets on the HD menu?
I don't use the preset buttons, I use a preset list (you can just click on the preset there)
BUT..
It seems any time I shutdown RR or even use "LOCAL" command all my presets are wiped out.
I believe the presets are supposed to be written to radio.ini in RR root folder but this file also remains blank.
Are you HD skinners experiencing similar behavior?
blk02si is offline   Reply With Quote
Old 11-28-2008, 10:20 PM   #6
lor109's Avatar
lor109 is on a distinguished road
BUT..
I know it's been a year since you posted this but I've been having this problem ever since upgrading RR. Did you ever figure it out?
lor109 is offline   Reply With Quote
Old 11-28-2008, 10:23 PM   #7
fixerofallthing's Avatar
fixerofallthing is on a distinguished road
Look at Carwings skin. It has this feature built in.
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline   Reply With Quote
Old 07-22-2009, 09:19 AM   #8
riko is an unknown quantity at this point
Hi,
Ihave a Silabs usb radio, but the RadioMute or Play or Stop don't work .... I want have a button that stop the listen radio... it's possible ?
thanks.
riko is offline   Reply With Quote
Old 07-23-2009, 04:01 PM   #9
Raw Wave
RIKO, make sure your using the JULY 2009 release of RR
also, with silabs, the usbradio.dll is in control, if it supports mute... it will mute
and there is quite a buch of versions of this .dll...
-Thanks
Mitch
www.rush2112.net
within our hearts
HD Radio Cables READY! mitchjs User Innovations 1170 11-11-2009 02:50 PM
Got HD Radio, adding Sirius and XM.. what are my options? Sonicxtacy02 General Hardware Discussion 2 12-14-2007 08:39 AM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
HD Radio Question... Shidoken Car Audio 15 11-29-2006 10:04 AM
HD Radio for the PC? dodgetimes2 Car Audio 1 08-03-2005 11:35 AM
