Quote: Originally Posted by
ThunderStick
That's not the case though. At least with the problem I am having. I used a non-transparent OSK that is smaller than the normal like 600x300 and the previous screen will dissappear and then the OSK comes up. Still works but it is like the OSK is being called with a load command instead of the menu command.
Any thoughts or ideas for this...
Either the OSK is transparent and you don't know it OR it has some sort of control in it causing it to refresh (i.e. Flash/Another iList) ? I have just tested this, but if you want to try it, just get the BMV2 skin and make the playlist into an iList and press the GPS Menu button...
Road Runner,RR's Myspace
"The best things in life are always free -
but that doesn't mean money can't buy you good things."
