The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 12-15-2007, 03:25 PM   #1
Iceman_jkh's CarPC Specs
My Photos: (1)
Enable voice control wherever a textbox/OSK exists? HOW??
Does anyone know how I can enable Voice Control whenever the OSK/text Cursor appears?
I dont want to control RR with it, only enter text and have it auto trigger whever there is an opportunity to type.
EG:
Enter address in Satnav
Enter track title in music search
Fill in Album/Artist/Genre in CdRip plugin
Enter a phone number in Phoco/Freefone/RRmobile
Is there an elegant/correct way to have this occur? something like trapping every call to OSK, or detecting wherever there is a text cursor/input field on the screen?
Any other ideas?
Ice
Iceman_jkh is offline   Reply With Quote
Sponsored Links
Old 12-16-2007, 11:25 AM   #2
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
Only by a means of a plugin you'd be able to check if RR is in either NUMOSK.SKIN or OSK.SKIN and have the voice control activated... I'd suppose you could also have a timer in NUMOSK.SKIN and OSK.SKIN which executes a command to activate the voice, and then have another command in the ESC/ENTER buttons of the OSK so it disables the voice control.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 12-17-2007, 12:58 AM   #3
My Photos: (1)
Is there any way to detect if the pointer has become a text cursor ?
and doing it that way?
Old 12-17-2007, 01:34 AM   #4
EL CAMINO's CarPC Specs
EL CAMINO's Avatar
Vehicle: 1981 chevy el camino
My Photos: (0)
try this. simple very simple script.
Code:
#Include <Misc.au3> AutoItSetOption("WinTitleMatchMode", 3) $test = "test" If WinExists($test) Then Exit AutoItWinSetTitle($test) $rr=ObjCreate("RoadRunner.sdk") if not IsObj($rr) then Exit $oMyError = ObjEvent("AutoIt.Error","MyErrFunc") HotKeySet("!{esc}", "_exit") ;for testing only, exit ALT+ESC disable when no need for it. While 1 If $oMyError.windescription then if Not WinExists("RoadRunner") then ExitLoop ;exit if RR is not Running. EndIf if MouseGetCursor() = 5 And _IsPressed("01") then MsgBox(4096, "", " text mode") $rr.execute("YOUR_COMMAND") ;place here your command EndIf Sleep (3000) ;push and hold 3 sec for executing. WEnd ;============================================================================================== ;AI's error reporting Object ;============================================================================================== Func MyErrFunc() Local $err = $oMyError.number If $err = 0 Then $err = -1 SetError($err) Endfunc Func _exit() Exit EndFunc
EL CAMINO is offline   Reply With Quote
Old 12-17-2007, 02:06 AM   #5
pRoFiT's CarPC Specs
pRoFiT's Avatar
Vehicle: 91/chevy/S-10
My Photos: (2)
Perfect thread.....Subscribed to thread
El Camino, do you have the same code for vb.net
I think i can create the roadrunner.sdk object like this
Code:
Dim rr As Object = CreateObject("RoadRunner.sdk")
hmm, strange but neat at the same time. If i do that roadrunner starts. so what..., i would be compiling a new program that would include RR? Or a new program that would include my features but call/open RR?
Okay tested a little more. So That will give me access to send to RR? And if my program is run without rr running, then rr will start. Otherwise RoadRunner can LOAD my program while entering a skin that would need my programs enteraction. Then you can have the skin close my program on exit.....hmmm.
Iceman_jkh, I would love to see what you end up with. I have a program that i'm secretly working on that needs the same kind of control of RR.
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
pRoFiT is offline   Reply With Quote
Old 12-17-2007, 02:38 AM   #6
pRoFiT's Avatar
My Photos: (2)
Hope the forum lets me double post
Anyways after a couple seconds i can send searchs to the search box like this.
Created a new form with button1 and textbox1
Code:
Public Class Form1 Dim rr As Object = CreateObject("RoadRunner.sdk") Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load End Sub Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click Dim i As Integer Dim ch As String ' must be string to send :) For i = 0 To TextBox1.Text.Length - 1 ch = TextBox1.Text.Chars(i) rr.execute(ch) Next i rr.execute("Enter") End Sub End Class
Simple VB.net code
Old 12-17-2007, 04:57 AM   #7
My Photos: (1)
Thanks El Camino.
EDIT: I got it to compile - turns out it must be saved as a .au3 file before it allows compilation (DOH!)
Basically, if the cursor becomes a text cursor, I want:
a) Audio to mute/pause
b) Mic to turn on
c) Accept commands/phonetic alphabet...until;
d) ENTER/command word is said (which is the equivalent of pressing ENTER)
e) turn mic off - as ENTER should change the cursor back to a pointer (not text cursor).
f) Audio resumes/unmutes
Profit> would also love to see what you are working on (in secret :P)
I'm hoping this little 'plugin' will make the voice control actually viable and useful!
Cheers
Ice
Old 12-17-2007, 07:27 AM   #8
My Photos: (0)
Question ICE
Quote: Originally Posted by Iceman_jkh View Post
Thanks El Camino.
Can you step me through that script a little. I ve only written 1 very VERY basic script before. I couldnt even see how to get this to compile.
b) Mic to turn on
Cheers
Ice
Ice - Won't you still have to issue the "letters" command or "numbers" command since they are in the commands.cfg or could you load a different config file for just the osk ? Also, doesn't the voice module stop listening after a successful command is issued and you have to prompt again ? I know I'm asking more questions than I'm helping but wanted to think it all the way through.
I use the voice control in mine all the time but I have a steering wheel control mapped to enable the voice prompt and then mute the mic after a set amount of time. Works out pretty well - I don't normally issue just letter and number commands because of what I asked you above.
montgomeryt is offline   Reply With Quote
Old 12-17-2007, 07:48 AM   #9
My Photos: (1)
OK, now that I can run it , Ive managed to understand whats going on
Heres what ive put together.
Purely a concept at the moment. Credit goes to El Camino for the main code!
Code:
#Include <Misc.au3> AutoItSetOption("WinTitleMatchMode", 3) $test = "test" $SpeechOn = -1 If WinExists($test) Then Exit AutoItWinSetTitle($test) $rr=ObjCreate("RoadRunner.sdk") if not IsObj($rr) then Exit $oMyError = ObjEvent("AutoIt.Error","MyErrFunc") HotKeySet("!{esc}", "_exit") ;for testing only, exit ALT+ESC disable when no need for it. While 1 If $oMyError.windescription then if Not WinExists("RoadRunner") then ExitLoop ;exit if RR is not Running. EndIf If MouseGetCursor() = 5 And _IsPressed("01") then ;Place code here.. to tell Voice control to listen ;$rr.execute("My_Commands") $rr.execute("next") ;Just a test - so you can see it switch to the next track - delete this line in real version! $SpeechOn= 1 ; Tells the app that it is about to receive speech commands EndIf Sleep (800) ;push and hold for 0.8 seconds to engage Voice control While MouseGetCursor() = 5 And $SpeechOn = 1 ; While we are waiting for the speech input, we make sure that the cursor stays as a TEXT CURSOR and is in speech mode ; Just sit here and do nothing. This means the app will wait till the ; ..user finishes talking and issues their "ENTER" command ; Might have to add a trap for AND Not(_IsPressed("0D")) to the end of this While loop WEnd If Not(MouseGetCursor() = 5) And $SpeechOn = 1 Then ;As soon as the user presses ENTER or gives the ENTER command $SpeechOn= 0 ; Turn off voice commanding - ignore incoming commands/turn mic off $rr.execute("prev") ;Just a test - so you can see it switch to the prev track - delete this line in real version! ;$rr.execute("My_Commands") any other commands you wish to run EndIf WEnd ;============================================================================================== ;AI's error reporting Object ;============================================================================================== Func MyErrFunc() Local $err = $oMyError.number If $err = 0 Then $err = -1 SetError($err) Endfunc Func _exit() Exit EndFunc
Compile it to an autoit script.
Hold left click for 0.8 seconds on a text box - should skip to next track.
Pressing enter, moving cursor off text box,etc should skip to prev track.
Basically all this does is prove that you can recognise such events and then trigger commands as a result
Next step is getting it to control/interface to the voice commands aspect of RR.
Ice
Old 12-17-2007, 07:57 AM   #10
My Photos: (1)
Im not that advanced at the voice control prog as you are mate.
But reading the .xml I can see what you are asking.
Hopefully we can create a smaller version of the .xml with only letters,numbers,etc using the grammar compiler. To be used specifically for this purpose. Even better would be causing the voice recognition to only use the mini .xml file when triggered in this way... and use the normal grammar file if invoked any other way. Get my drift?
Could even use PowerVoice from 0l33l (i tihnk it was). All I really want is a prog that writes what I speak into the text box.
Sponsored Links
Old 12-17-2007, 02:02 PM   #11
EL CAMINO's Avatar
My Photos: (0)
@Profit
sorry man, all i know is a little bit of Autoit, i'm lost in Vb.net, but i see you have it working by now, hope to see that secret program soon.
@iceman
i need to play more with voice control, my end gives me errors when enabled, cut be my end(nlite) so yea i can help you out with this, but if you know the commands let me know and we can get it to work for sure.
Old 12-17-2007, 03:02 PM   #12
My Photos: (1)
Just gotta find the rr.execute() commands needed for:
a) Pausing Audio - $rr.Execute("Pause")
b) Switching the voice control .xml file to the mini version (optional) - ?
c) Sending the HOTKEY to RR/Voicecontrol application - ? Cant seem to get $rr.Execute("SENDKEY;{F10}") to work
(turning the Mic on)
d) Sending the ENTER key to RR's OSK/TextBox - $rr.Execute("Enter")
(submitting the text to RR and turning the mic off)
....If I use $rr.Execute("Enter") inside the playlist search in BMV2 it works nicely, howver if I use it inside CDRIP to name the Artist/Album/etc, $rr.Execute("Enter") takes me to the main menu.
Is there any other way to trigger the enter command?
f) Resume audio - $rr.Execute("Resume")
Old 12-17-2007, 10:46 PM   #13
EL CAMINO's Avatar
My Photos: (0)
a)done i guess.
b)well dont know how voice uses this xml, but if is just mater of changing the file, file move would work nicely.
c)
Code:
$Voice = WinGetHandle("RoadRunner", "") WinActivate($Voice, "") Send("{F10}")
d)dont know about this one.
e)??
f)what about if music is paused before all this process? if you use resume or play will start playing no matter what, when finish, maybe use
Code:
$Status = $rr.getinfo("STATUS")
to poll the status info, and according to that, resume or not after this process.
Old 12-18-2007, 04:51 AM   #14
My Photos: (1)
Oops.. there was no (e) . I'm a little overzealous to get this working I guess
Good thinking regarding the status polling. Fixed it now.
Ive figured (d) out. When you click the text cursor (for 0.8 seconds in the text field) to trigger the Voice recognition to turn on, the process of sending the F10 key is actually taking focus away from the RR CDRIP app. This causes the LOADING screen to be seen. Pressing ESC goes back to the main menu and the entire app is still running correctly (thinking that it has been told to stop voice recognition etc).
Test: I replaced the send F10 to RR with send "5" to Calculator, the app worked perfectly and CDRIP DID NOT lose focus from the OSK screen.
[All testing was done on BMV2.]
Any other ways to trigger the Voice recognition plugin to ON?
Can the plugin be recoded to include this option?
I would almost prefer it if the plugin wasnt waiting for a hotkey, purely turning the Mic input ON/OFF.
I tried the following commands to send the F10 key - all result in LOADING screen:
1. ControlSend("RoadRunner","","","{F10}")
2. $Voice = WinGetHandle("RoadRunner", "")
Send("{F10}")
Anyway, heres my current code:
Code:
#Include <Misc.au3> AutoItSetOption("WinTitleMatchMode", 3) $test = "test" $SpeechOn = -1 $PlayStatus = -1 If WinExists($test) Then Exit AutoItWinSetTitle($test) $rr=ObjCreate("RoadRunner.sdk") if not IsObj($rr) then Exit $oMyError = ObjEvent("AutoIt.Error","MyErrFunc") HotKeySet("!{esc}", "_exit") ;for testing only, exit ALT+ESC disable when no need for it. While 1 If $oMyError.windescription then if Not WinExists("RoadRunner") then ExitLoop ;exit if RR is not Running. EndIf If MouseGetCursor() = 5 And _IsPressed("01") then ;Mouse has been clicked where the User wants to dictate If ($rr.getinfo("STATUS") = "Play") Then ;Check the previous play/pause/stop status $rr.Execute("pause") ;Pause music ;if playing, then pause the music, else skip $PlayStatus = 1 EndIf ;ControlSend("RoadRunner","","","{F10}") ; this does the same as the 3 code lines below - but is slightly less obtrusive ;the above line tries to tell the Voice Recog plugin to start accepting dictation $Voice = WinGetHandle("RoadRunner", "") ;trigger hotkey line 1 WinActivate($Voice, "");trigger hotkey line 2 Send("{F10}");trigger hotkey line 3 $SpeechOn= 1 ; Tells the app that it is about to receive speech commands EndIf Sleep (800) ;push and hold for 0.8 seconds to engage Voice control While (MouseGetCursor() = 5 And $SpeechOn = 1) Or (Not(_IsPressed("01")) And Not(MouseGetCursor() = 5) And $SpeechOn = 1) ;Above line checks that EITHER: ;a)The cursor is a text cursor (Ibeam) and it doesnt care if its being left clicked; or ;b) The cursor is NOT a text cursor (Ibeam) but thats OK, as long as the user isnt left clicking on anything - purely moving the mouse around! ; While we are waiting for the speech input, we make sure that the cursor stays as a TEXT CURSOR and is in speech mode ; Just sit here and do nothing. This means the app will wait till the ; ..user finishes talking and issues their "ENTER" command WEnd If Not(MouseGetCursor() = 5) And $SpeechOn = 1 Then ;As soon as the user gives the ENTER command - This needs work! ;Place code here for ;turn mic off /hotkey - mic has auto-off it seems $rr.Execute("ENTER") ;press enter/submit text - doesnt always work If ($rr.getinfo("STATUS") = "PAUSE") AND ($PlayStatus = 1) Then ;at the top we checked if RR was playing/paused/stopped, if playing this resumes, else skips over $rr.Execute("resume") ;resume audio $PlayStatus = -1 EndIf $SpeechOn = 0 ; Turn off voice commanding - ignore incoming commands/turn mic off EndIf WEnd ;============================================================================================== ;AI's error reporting Object ;============================================================================================== Func MyErrFunc() Local $err = $oMyError.number If $err = 0 Then $err = -1 SetError($err) Endfunc Func _exit() Exit EndFunc
EDIT: changed code to use the '$voice' method (simply changed commenting), as method 1 didnt always work (ControlSend("RoadRunner","","","{F10}"))
Ice
Old 12-18-2007, 08:47 AM   #15
My Photos: (0)
Voice Dictation
@ICE
I agree with turning the mic on/off. I had to switch to using the hotkey because the mic was always on and the voice control was in listen mode. I noticed that outside noise or conversation that may have resembled commands would get executed.
When I left work last night I tested what I was talking about. In order to type letters using the current voice commands the system had to be prompted for every letter - press a button letter "a" press a button letter "b" and so on. IMO the voice command system needs to be more like a Dragon Dictate software or the Microsoft voice dictation. Then the system could disseminate entire words or phrases. This would also facilitate the use of playing artists, or albums on command. I know there is a plugin (SmartPlaylist) that does this but if the voice commands plugin can be "re-written" may want to consider that as well.
Sponsored Links
vB code is On
Trackbacks are Off
voice control sw TwinII Software & Software Development 31 08-18-2002 04:15 AM
voice control idea crazyshaxs Software & Software Development 4 02-25-2002 12:32 AM
My hardware/Software computer control system - Wish list/feedback - Easy power off DarkWolf General Hardware Discussion 22 08-13-2001 01:42 PM
Voice Control bjrady Software & Software Development 4 05-26-2001 03:45 AM
Voice Control for Winamp Stryph Software & Software Development 8 09-14-2000 11:20 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
