The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 12-20-2007, 09:05 PM   #1
Iceman_jkh's CarPC Specs
My Photos: (1)
HD Radio Mod: Power Antenna Trigger
Hey All,
I modded my Visteon Hd Radio to automatically trigger my car's power antenna to extend when the radio turned on.
Before I show you how to do this, I gotta do a slight disclaimer:
The pin I used to carry the +12V for the trigger signal appears to have nothing else was connected to it (ie: it was floating and not GNDed or anything else that I could tell). I have tested it on/off for a couple of cycles and everything looks fine. No overheating, burning smell, etc. Hence I'm going to publish this. As always, perform this mod at your own risk! Dont blame me if something messes up.
Ok, so here it is.
-There are 2 relays inside the RF cage of the unit.
-We connect +12V (from the power supply connector) to the NO pin on the second relay ONLY.
-As far as I can see the NO pin (only on Relay 2) was always floating!
-Relay 1's NO pin likely goes to the iBiquity RF unit.
-After performing the mod use a male motorola plug header in ANT OUT to access the +12V line to trigger your power antenna.
NO = Normally Open (If the relay has no power this contact is NOT connected to C)
NC = Normally Close (If the relay has no power this contact IS connected to C)
C = Common
When you apply power to the relay's coil, the C contact will become connected to NO not NC.
Cheers,
Ice
Iceman_jkh is offline   Reply With Quote
Sponsored Links
Old 03-15-2008, 02:13 PM   #2
My Photos: (0)
Thanks, this worked perfectly. I don't know if you explained it so well or no one has a power antenna.
dmacias is offline   Reply With Quote
Old 06-19-2008, 09:41 PM   #3
labenedict's CarPC Specs
Vehicle: 2003 Hyundai Sonata
My Photos: (0)
I'd like to also say thanks. I have it working in my setup now also.
labenedict is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Way to connect to power antenna for headless unit. stonestatue Car Audio 4 06-17-2007 04:58 PM
open power antenna? sanbas General Hardware Discussion 5 05-29-2006 01:33 PM
Radio Antenna / Power Extension Cables vatik General Hardware Discussion 1 11-16-2005 11:21 PM
FS: ITPS shutdown controller and PW-70a MINI-ITX power supply hanzacra Classified Archive 4 08-07-2005 10:32 PM
Using radio antenna for radio AND tv pyros General Hardware Discussion 1 05-19-2004 01:06 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
