The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 12-24-2007, 10:56 AM   #1
Custommx3's CarPC Specs
Custommx3's Avatar
Vehicle: 2007 Mazdaspeed6
My Photos: (7)
Move files...
Heres what I'd like to do if its possible.
I separate my music that I like in folders by genre. I have alot of music, but some of it I dont care to have to scroll through trying to find a song to listen to. I usually copy alot of it over to the PC and separate the ones I like into folders then delete the remaining. Doing this, I sometimes put it in the wrong folders, not realizing until Im listeining to that folder's music.
I would like to create a button that opens a popup menu, from that each button on a menu will copy the current selected song to a pre-determined folder. That way I can use it to sort my music that may be mis-sorted, as well as copy new music to specific genre's folders and eliminate the unwanted music.
I though about just creating an autoit script for each button, but I dont know how to tell the script to move the curent selected song.
Doable? Suggestions?
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
Sponsored Links
Old 12-24-2007, 11:11 AM   #2
Raw Wave
Blue ZX3's CarPC Specs
Blue ZX3's Avatar
Vehicle: 01 Ford ZX3
My Photos: (12)
Suggestions....
Don't seperate music by genre(makes no sence to me and others..)
Yes i could be done... what skin are you using BTW?
Blue ZX3 is online now   Reply With Quote
Old 12-24-2007, 11:36 AM   #3
Custommx3's Avatar
My Photos: (7)
Brushed metal, modified BMWE26's version how I wanted it.
2007 Mazdaspeed 6
Old 12-24-2007, 11:39 AM   #4
Sal R.'s CarPC Specs
Sal R.'s Avatar
Vehicle: 2001 A4 1.8TQMS
My Photos: (33)
Here's my autoIT script to move the current selected song to a RR defined folder variable $destinationmedia$
If you have any of Sonicxtacy02's plugins installed, the script will reuse the "SUCCESS" & "FAIL" skins for popup confirmation.
Hope that helps you out.
MicroXP / RR v11/04/2007 / Winamp v5.13 / MMIv2
RR Album Art Browser
Sal R. is offline   Reply With Quote
Old 12-24-2007, 01:00 PM   #5
Custommx3's Avatar
My Photos: (7)
thanks! may I ask which plugins your referring to? The ratings plugin?
Also, where do I specify the variable?
ExecTBL.ini in the RR directory, or the skin directory?
2007 Mazdaspeed 6
Old 12-24-2007, 01:15 PM   #6
Sal R.'s Avatar
My Photos: (33)
For sure, the New Hits plugin has the "SUCCESS" & "FAIL" skins. I'm not sure about the ratings plugins.
In any case, you can define the destination folder path in rr.ini, skin.ini or SETVAR;destinationmedia;<PATH> in RR.
i.e.
destinationmedia=E:\my_mp3\
Old 12-24-2007, 01:24 PM   #7
EL CAMINO's CarPC Specs
EL CAMINO's Avatar
Vehicle: 1981 chevy el camino
My Photos: (0)
mp3Copy plugin has those.
EL CAMINO is offline   Reply With Quote
Old 12-24-2007, 03:31 PM   #8
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (101)
ratings doesnt.. mp3copy and new hits do
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
Old 12-24-2007, 04:19 PM   #9
Custommx3's Avatar
My Photos: (7)
well,
I used the script above, changed the command of "filecopy" to "filemove" (I dont want to copy, I want to move obviously. Compiled it and put it in my skins directory.
In my Audio_player skin I added
B24,208,498,71,92,"MENU;copy.SKIN",
In my skin folders EXECTBL.ini
"altmusic","RUN;c:\program files\road runner\SKINS\MySKIN\altmusic.exe"
in my copy.skin I have currently 2 buttons
B,257,283,219,81,"altmusic",
B,92,373,331,103,"CANCEL",
Doesnt work .. help
2007 Mazdaspeed 6
Old 12-24-2007, 06:36 PM   #10
MySQL Error
My Photos: (101)
you want the command to read something like this barry
Code:
"altmusic","SETVAR;destinationmedia;C:\||RUN;c:\program files\road runner\SKINS\MySKIN\altmusic.exe"
you need first set the path as a variable.. then you run the script. So say if you wanted 5 different buttons for five different paths you'd just create 5 buttons with the exact code above.. but changing "C:\" with whatever path you wish the file to be moved to
03 Acura RSX Coupe
Sponsored Links
Old 12-25-2007, 02:49 PM   #11
Raw Wave
Blue ZX3's Avatar
My Photos: (12)
Here is another thought, by changing this slightly...you would only have one exe and be able to use it over and over again w/o having different exe for each different path to move to..
change this line:
$destinationmedia = $rr.GetInfo("=$destinationmedia$")
TO:
$destinationmedia = $rr.GetInfo("=$"&$CMDLINERAW&"$")
Then define each var in the rr ini as such
altmusic=<path to alt music>
rockmusic=<path to rock music>
ect...
And then change your exectbl line for each btn cmd to something like this:
"altmusic","RUN;c:\program files\road runner\SKINS\MySKIN\MoveMusic.exe|<exact nam e of variable for this btn>"
examples..
"altmusic","RUN;c:\program files\road runner\SKINS\MySKIN\MoveMusic.exe|altmusic" or
"rockmusic","RUN;c:\program files\road runner\SKINS\MySKIN\MoveMusic.exe|rockmusic"
Old 12-25-2007, 09:17 PM   #12
Raw Wave
Blue ZX3's Avatar
My Photos: (12)
Just after I posted the above post I had to leave and about half way to where I was going....it dawned on my why your script didn't work...you can't move a file in use, thats why it didn't appear to work. You would need to first stop the music and then move the file, but then you won't be able to continue to play it as its no longer in the same loc as the path defined in the current playlist.
One way would be to first copy it to the new loc, then check like every min and see if the song changed(using trackpath), and if it did then go and delete the origanal file.
Old 12-26-2007, 08:48 AM   #13
Custommx3's Avatar
My Photos: (7)
I did press stop, still didnt work Im gonna try your above and see if it works.. thanks guys for all your help on this!
2007 Mazdaspeed 6
Old 12-26-2007, 10:04 AM   #14
Custommx3's Avatar
My Photos: (7)
I have made the changes as suggested, and added the dual commands to my buttons to stop the music before moving.
ex:
"STOP||ALMUSIC"
And it works!! but it keeps saying it failed. Im almost thinking of removing the code for the pop-ups.
Any idea why it would fail when it works?
2007 Mazdaspeed 6
Old 12-26-2007, 10:15 AM   #15
Custommx3's Avatar
My Photos: (7)
I just removed the confirmation code, and added an extra command to close out the menu.
EX:
"STOP||ALTMUSIC||CANCEL"
Works, and no extra box to close. Thanks everyone for the help!
2007 Mazdaspeed 6
Sponsored Links
vB code is On
Trackbacks are Off
Service Configuration Files Phatsacks WinNT Based 1 08-29-2007 11:03 PM
Mirror Files guino Road Runner 20 03-02-2006 01:40 PM
I Have Voices! Andywaite FreeDrive 14 01-18-2006 05:07 AM
Complete set of PSD's Files MickW RR Skins 4 01-06-2006 02:13 AM
Adding files to a harddrive which is "hibernating" not being there when it wakes up? blak3r General MP3Car Discussion 2 09-08-2004 06:07 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
