The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Search this Thread Display Modes
Old 01-19-2008, 08:25 AM   #1
My Photos: (12)
Embed Visu when already running & in multiple screens?
Hi all,
I'm working on a RR skin and I've hit a problem - What I'm trying to do is embed the winamp visualization on the main rr screen without having to manually launch the visu from a button.. then when i switch to the audio player screen I want the visu to embed into that screen too - again without having to manually launch the visu from a button.
I can sucessfully embed it if I put a button on each skin with the command "Visu" but I want it running all the time..
I also tried putting "AUDIO||VISU" in the button command for switching to the audio player screen and while it did solve the problem of auto starting the visu it also STOPS it if already running
Is there any way I can achieve this ?
Cheers!
swift_gti is offline   Reply With Quote
Sponsored Links
Old 01-19-2008, 03:24 PM   #2
kpjuk's Avatar
Vehicle: Peugeot 807 - 2003
My Photos: (0)
You could try and control the state yourself by doing
VISU||AUDIO||VISU from each skin, effectively making ot turn off leave the skin, load the next skin and fire up the Visual.
The VISU command is a toggle that turns it on or off.
cheers
KPJUK
M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
kpjuk is offline   Reply With Quote
Old 01-20-2008, 11:31 AM   #3
My Photos: (12)
Thanks for the reply - I've not tried yet, but thinking about it I guess that way would work.
How would I embed to the main.skin though as there is no 'calling screen' that can pass the VISU command..
Does RR not provide the ability to just embed a specified window even if its already running instead of having to keep turning it on and off?
Old 01-22-2008, 08:32 PM   #4
moahdib's Avatar
Vehicle: Acura TL 2004
My Photos: (0)
U create a command in the exctbl.ini called VISEMBED for example with the "RUN;;visu window name".
When u switch from main menu to audio you do AUDIO||VISEMBED. ( asssuming you already started the VIS). This will automatically embed the visu in the skin you are loading.
Good luck.
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
moahdib is offline   Reply With Quote
Old 01-23-2008, 05:48 AM   #5
My Photos: (12)
Good luck.
Good man, I will try this one later and see how it goes
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
FAQ: VGA vs. Composite (Video) Screens cproaudio The FAQ Emporium 2 12-28-2007 11:45 AM
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 09:11 PM
External GPS - Running the Program multiple times Purplxd Road Runner 4 10-31-2005 02:20 AM
Video playback on multiple screens sweetlikealemon LCD/Display 8 07-05-2005 04:53 AM
Sponsored Links
Ad Management by RedTyger
