The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 02-18-2008, 01:23 PM   #1
Road Runner & Mp3car Gatherings Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
Question Retreiving Custom SLider value help needed
I am working on a script, that I need to get the slider value sent to. I have read there is a way to set a slider, then press a button, to get value of where the slider is.
If this were the way a volume slider worked, you would need to put the slider where you want, and then press a button to actually change the volume.
I am looking to do this in one step. Move the slider to the center for instance, and RR sends/stores a 50% command (or 0 to 255 whatever, I can have the script EVAL the range to get the correct value I need). I just need to then read that value after the slider has been moved without an extra "set" button to do it. Does anyone know of a way to do this?
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0
7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD
Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 4.0 Skin www.johnwpb.com
JohnWPB is offline   Reply With Quote
Sponsored Links
Old 02-18-2008, 01:37 PM   #2
Sal R.'s CarPC Specs
Sal R.'s Avatar
Vehicle: 2001 A4 1.8TQMS
My Photos: (36)
In ExecTBL.ini,
"ONSLD<SLIDERVARNAME>","SENDMSG;<your script>;<cmd>"
Where <SLIDERVARNAME> is the CL slider var name. "ONSLD<SLIDERVARNAME>" is executed everytime you adjust the CL slider.
You can then tell your script to read the raw value of <SLIDERVARNAME> and evaluate it w/in the script.
EDIT: If you're just creating a custom VOLUME slider, the raw slider value can be evaluated w/in rr w/o the need of an external script:
Skin Custom Slider:
Code:
S03,...,H,03,"slider2.gif",30,"$RAWVOLUMEVAR$","" .
ExecTBL.ini
Code:
"ONSLDRAWVOLUMEVAR","SETVOLUME;<LINE>;$RAWVOLUMEVAR$" .
I think that might work...*shrugs*
MicroXP / RR v11/04/2007 / Winamp v5.13 / MMIv2
RR Album Art Browser
Sal R. is offline   Reply With Quote
Old 02-18-2008, 02:30 PM   #3
JohnWPB's Avatar
My Photos: (0)
Thanks! I will give it a shot now.
Actually, hahaha this is not for volume control..... Its to dim lights in the living room
EDIT:
Ok, I am pretty sure I have the exectbl.ini correct. What I am unsure of is the skin code. In your above example, I do not see where the slider name goes:
Code:
I also have to pass 2 variables with the skin command(slider pressed), the device to control and the level to set it at. something like $device$ $dimlevel$. (The Device is hard coded, but the slider var needs to report where the slider is)
I have a vbscript that reads the 2 parameters passed to it. It then in turn sends that command over the network to the home automation server to carry out the command.
This is what I have in the exectbl.ini:
Code:
"ONSLD","RUNQW;wscript.exe" "$SkinPath$\scripts\vb.vbs|$device$ $dimlevel$"
Old 02-18-2008, 05:11 PM   #4
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
"ONSLD" needs the variable name after... like "ONSLDRAWVOLUMEVAR"..
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 02-20-2008, 09:14 PM   #5
Vehicle: 2004 F-150
My Photos: (0)
[quote=JohnWPB;1178580]Thanks! I will give it a shot now.
snip
I only hope that means there will be an x-10 skin in DFX 3. I'm keeping my fingers crossed.
Cicciotino is offline   Reply With Quote
Old 02-21-2008, 02:28 PM   #6
Sal R.'s Avatar
My Photos: (36)
EDIT:
Code:
In the case above, the slider name is the variable $RAWVOLUMEVAR$
Code:
The slider above can only pass one numerical value that ranges from 0-65535, which is stored in the variable $RAWVOLUMEVAR$. To be able to pass 2 variables, you'll probably need two sliders, use a BYVAR command, or use and EVAL function if the variables are related somehow.
Old 02-21-2008, 04:24 PM   #7
JohnWPB's Avatar
My Photos: (0)
Thanks for the help, I have it almost all working with the above code.
Sponsored Links
vB code is On
Trackbacks are Off
Suburban - Custom console carputer - W/Pics rcracerx Show off your project 35 06-14-2007 01:36 PM
Epia-M custom Bios & entertainment module. Bios chip # needed. v1s General Hardware Discussion 0 11-22-2006 08:33 PM
Trouble setting custom resolutions.... SinnerG LCD/Display 10 06-18-2003 07:15 AM
X-MP3Pad: Beta testers needed... Please read! PorscheMP3 Software & Software Development 0 08-22-2002 11:55 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
