The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 02-26-2008, 01:57 AM   #1
sebberry's CarPC Specs
My Photos: (4)
Odd problem with RR and iG4
When I run RR and tap my Navigation button, my navi skin loads and ig4 loads correctly.
However, when I exit the navi screen and return to my home screen, go into my music screen than back to the navi skin, the navi skin loads but the ig4 window doesn't re-appear.
When I exit RR, I see that ig4 is no longer running as an application in task manager, yet it is listed as a running process.
Any ideas as to what might be wrong?
Thanks!
sebberry is offline   Reply With Quote
Sponsored Links
Old 02-26-2008, 02:12 AM   #2
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
Window name? iGuidance instead of Guidance .... ?
BTW, what exactly the command that the skin use to load GPS? If just GPS, make sure that the skin is External_GPS.skin AND External GPS as an option for GPS in RRConfig.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-26-2008, 04:57 PM   #3
My Photos: (4)
I made the changes you suggested and it is still doing something funky.
I should clarify that it works fine when I simply return to the main skin then click on GPS, but if I click on the button for my music, then return to the main skin then back to GPS it doesn't show iGuidance.
However, if while in the external_gps skin I click my 2D/3D button outside of the GPS application area, iguidance comes up...
Old 02-26-2008, 05:57 PM   #4
treetop777's CarPC Specs
treetop777's Avatar
Vehicle: 1981 Ford F-100
My Photos: (0)
What skin?
treetop777 is offline   Reply With Quote
Old 02-26-2008, 06:26 PM   #5
My Photos: (4)
My own
Old 02-26-2008, 08:42 PM   #6
Vehicle: 03 Dodge Ram
My Photos: (0)
this may not be any help at all, but i have a similar problem with iG3 not showing up at times, when i return to the navigation screen. rather it just shows my desktop in the portion of the screen where the map should be displayed. panning (dragging my finger across the screen) will make the map appear again. kind of annoying, but not a HUGE deal i guess, since its just a matter of sliding my finger across the screen, then tapping the "X" to get it back to following me. maybe its worth a shot? ive never checked the task manager though...
maybe this is common, ive never really done a search to see if other people have the same issue. i havent noticed it only doing it when entering it from specific screens (like yours is with music player screen). i hope it helps! if not, sorry to waste your time!
Mike_713 is offline   Reply With Quote
Old 02-26-2008, 11:23 PM   #7
Raw Wave
Blue ZX3's CarPC Specs
Blue ZX3's Avatar
Vehicle: 01 Ford ZX3
My Photos: (16)
The only way you would see your desktop where the ig window should be is A: your gps screen has a graphic hole where the ig win is embeded and/or you might have a clip region defined giving you that unwanted effect...
Blue ZX3 is offline   Reply With Quote
Old 02-27-2008, 06:38 AM   #8
treetop777's Avatar
My Photos: (0)
That's what i was about to say - a "C" line in the skin somewhere. If it was a public skin maybe we could reproduce the problem (or not) and figure-out what it is.
Sponsored Links
vB code is On
Trackbacks are Off
IG4 Crash-Reboot with GPS data bmac67 GPS 1 02-05-2008 01:01 PM
iGuidance and Volume -odd problem sparkyssb Road Runner 53 01-31-2008 09:01 AM
HDRadio & IG4 issue Nanner RR Bug Tracker 3 01-16-2008 07:14 PM
cant seem to config rr for IG 3/4 or S&T sliturnek Road Runner 9 12-07-2007 07:11 PM
Downgrade from iG4 to iG3 KryptonianJorel GPS 1 10-24-2007 08:11 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
