The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 04-10-2008, 06:19 AM   #1
My Photos: (0)
Unable to display Chinese/Japanese/Korean tracks?
Hi all,
First of all this is my configuration.
- RR December 07 (used installer then upgraded to Dec 07)
- LSX Void 3.3 (but also tried the default skin)
- Winamp 5.53
- English XP with East Asian fonts installed
- All MP3's tagged in Unicode, in the ID3v2 fields
- RR is set to use ID3v2 fields
The problem is that in RR, the Chinese/Japanese/Korean (CJK) track/album/file names display as squares. Explorer displays CJK correctly, and Winamp does too.
As far as I know, both LSX Void and the default skin use Arial Unicode font, so it can't be a font issue. (Please correct me if I am wrong though.)
Tried changing the Windows locale, and the RR locale, but it makes no difference.
Done a search but can't find anything.
Any ideas?
Thanks.
wywywywy is offline   Reply With Quote
Sponsored Links
Old 04-10-2008, 06:52 AM   #2
My Photos: (0)
http://www.mp3car.com/vbulletin/rr-f...se-korean.html
that doesn't do any good, i have no other suggestions other than a fresh reinstall.
brandensin is offline   Reply With Quote
Old 04-10-2008, 08:02 AM   #3
My Photos: (0)
Hi,
I have done those steps already, and also tried a fresh reinstall...
Thanks.
Old 04-10-2008, 08:10 AM   #4
My Photos: (0)
Hmm... square.. now that sounds not too alien... Are you sure you have asian pack installed? How does it display in winamp? If winamp doesn't display it right, it's your system... might wanna uninstall asian pack and reinstall it... sorry, don't have better suggestion... It should just work.. plain simple... You didn't mess with any MUI files did you? l
Old 04-11-2008, 02:17 AM   #5
My Photos: (0)
Hi,
As said in the first post.
- East Asian pack installed
- Winamp & Explorer display correctly
- Tried re-installing everything already
And no I didn't mess with any MUI files.
Thanks.
Old 04-11-2008, 02:18 AM   #6
My Photos: (0)
Also tried enabling/disabling iList by the way.
Old 04-15-2008, 07:37 AM   #7
My Photos: (0)
Hi all,
Found out what it is now. It turns out my Arial Unicode MS font was corrupted (bad CD I presume). And also the skins are hard-coded to use Arial instead of Arial Unicode MS.
Just a few observations for future references in case the newer generation faces the same problem.
- CJK displays as random Latin character = application problem, not designed to handle Unicode/double-byte character set
- CJK displays as question marks = Windows problem, East Asian language pack not installed
- CJK displays as squares = font problem, try changing the font to Arial Unicode MS or one of the specific fonts (e.g. MingLiU)
And also iList doesn't seem to support CJK properly as yet - it only displays the first 3 bytes.
Old 04-15-2008, 11:14 AM   #8
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
I have a few Chinese album that I never bother to figure out what the problem is. I just do a manual edit them to Pinyin so maybe other can read and understand it. I have no clue what those characters mean anyway. Most of my Vietnamese music with unicode, they also display funky characters. I just remove all the Vietnamese accent mark. Without accent marks, it not that different from English.
VB support for unicode is not that good.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 04-16-2008, 12:49 AM   #9
84RegalRider's Avatar
Vehicle: 1991 Lincoln Towncar
My Photos: (16)
yea i just edited mine as well.
took a while though since i have alot of japanese and korean stuff
Core duo
320gb harddrive
256 ddr
8 lilliput
still installing...
84RegalRider is offline   Reply With Quote
Old 04-19-2008, 01:04 PM   #10
kwchan's Avatar
Location: Singapore - Smallest country in Southeast Asia
Vehicle: 2005 Fiat Doblo
My Photos: (2)
so no way to have RR display Chinese at the moment?
kwchan is offline   Reply With Quote
Sponsored Links
Old 04-19-2008, 08:34 PM   #11
My Photos: (0)
Yes you can, but some of the things (e.g. Album name) don't always display correctly, and I think the problem lies in the RR-Winamp interface. And it seems that you can only have one Asian language active at a time, so you can't have Japanese + Korean displayed on the screen at the same time. And also iList doesn't support non-Latin languages yet.
These are the things to do:
1. Install Windows' East Asian language support
2. Set system default language to your favourite (let's say Taiwan/Traditional Chinese for example)
3. Change system locale to either US or UK (otherwise some skins go funky)
4. Make sure your skins are using Arial Unicode MS font instead of any other non-Unicode font
5. Change your apps settings (e.g. Winamp playlist, Milkdrop, etc) to use Arial Unicode MS
6. Pray
Old 06-09-2008, 06:07 PM   #12
CTQ
My Photos: (0)
I have intalled RR on an English WinXP systeam and a Chinese WinXP system.
Found the same song title display problem in English system, although I set all things that I can try.
No display problem in Chinese system.
Wish this experience useful to find the root cause.
CTQ is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Planning Phase help for ceiling mounted display HullBreach Newbie 3 04-07-2007 04:31 PM
Any way to relocate my display card?? SlimJimmy General Hardware Discussion 13 03-22-2004 09:14 PM
Choosing a Character display... Kryten LCD/Display 3 10-16-2003 10:43 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
