04-13-2008, 05:52 PM
#16
remember boys... when in doubt run hdradio PCR!
it will tune to even numbers!
its just not designed for europe, when seeking, scanning, it will wrap back to a odd number freq
mitch
04-14-2008, 04:50 AM
#17
Vehicle: Mercedes ML 320 , 1999
Mitch, can you tell me how I can tune on even numbers?? Because when I go through all the frequenties I only get odd numbers.
Thats why I would like to use it with RR, but somehow it just doesnt work
When I press radio inside the skin HD radio clicks on then I hear thet the radio wants to start playing but then I hear a plop and nothings happends anymore.
if I look at my soundcard software nothing is muted.
I also dont have the posibillity to run through the frequenties. Somehow it just gets stuck art around 88.1. If I go backwards I only can go to 107.1 and then it goes back again to 88.1
Using the HD software from you doesnt give any problem. I can choose al (odd) frequenties I want.
Gods right foot!!
Mercedes ML320. Intel D201GLY2,1024mb DDRII,120Gb S-ATA HD,HDradio,7"Touchscreen,2x 7"build in headrest screens,OBDII reader,Centrafuse.
04-14-2008, 01:08 PM
#18
Vehicle: 2004 Chrysler 300M Special
It sounds like you don't have your com port set correctly............
Leonardo Da Vinci
04-14-2008, 01:15 PM
#19
COM port not correctlly? Lets say that that is the problem how comes that the radio reacts when I go to the radio skin inside RR?
I did search wich port it uses and found out that there was only 3 ports availables. 2 of those where used by BT, so only port 1 is available (no name behind it)
I dont know if the port needs to be showed as HD radio device?
Gods right foot!!
04-14-2008, 03:52 PM
#20
If you followed the above posters advice in post number 7, then you either have the "line in" you're using muted or there's something set wrong in your RR config file..............
Are you using something besides XP? Are you using a usb soundcard or on board?
Leonardo Da Vinci
04-15-2008, 04:38 AM
#21
I use the onboard soundcard.
To make sure I had everything right I downloaded the latest RR. then set HD radio as standaard.
Then I added inside INI Variables: hdradioport=2 (I changed from 1 to 2 to see if this could solve the problem but no luck)
When I open RR and go to the radio skin, HD clicks on, and then nothing??
I tried to close port 2 and started Mitch HD software and then I get a pop up to chosse portnr. I took nr 2 and Radio starts.
So I figure out that I have placed the right portnr inside RR.
Gods right foot!!
04-15-2008, 03:05 PM
#22
mitch
Mitch: is it not possible to override this using some kind of software?Because I really would like to make this work. Specially after having a HQCT (what naver did what the designers talked about)
Gods right foot!!
04-15-2008, 05:31 PM
#23
i dont think so... seninha...
remember i dont make this tuner, i just reverse enginerred the protocol... and i dont have it all, only what i saw between the display the the box... i bet there is more...
now is there a Europe mode, i doubt that... they didnt have to do that since its primary function is HD
there are like 4 people who got a cable from me outside North America... maybe they can shead some light
mitch
| Thread Tools |
| Display Modes |
Linear Mode
