The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 04-12-2008, 12:31 AM   #1
seninha's Avatar
Vehicle: Mercedes ML 320 , 1999
My Photos: (0)
HD Radio
After receiving the HD kabel from Mitchell I want to try it with my CarPC.
Before I start I have 2 questions:
Do I need to install any other software or can I just use latest RR version?
and which skin is getting the most out of the radio.
Gods right foot!!
Mercedes ML320. Intel D201GLY2,1024mb DDRII,120Gb S-ATA HD,HQCT,7"Touchscreen,2x 7"build in headrest screens,OBDII reader,Mauri skin.
seninha is offline   Reply With Quote
Sponsored Links
Old 04-12-2008, 01:32 AM   #2
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
I'm a little outdated on the skins right now, but you can use the HD radio solely with RR (though I would recommend installing Mitch's application to test it first).
On another note, I thought HD radio was only for the USA... are you just going to use the device for standard Radio in Holland ?
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 04-12-2008, 01:42 AM   #3
seninha's Avatar
My Photos: (0)
Correct. One guy from the Dutch CarPC forum bought the radio from ebay.
He already tested als stand alone, and find it very nice.
Now I want to test it within RR to use it only as a FM radio (Holland doesnt have HD radio )
When you talk about solely, do you mean that i need to start the HD software next to RR??
Hope not because I just want to be able to control it inside RR
Gods right foot!!
Old 04-12-2008, 01:49 AM   #4
inh
Vehicle: 91 CRX Si
My Photos: (0)
Digital FX 3 has an awesome HD radio skin =]
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
inh is offline   Reply With Quote
Old 04-12-2008, 02:44 AM   #5
seninha's Avatar
My Photos: (0)
Thanks. I will try that.
But let me see if I get it right.
step 1:
-install Mitchell software.
step 2:
-choose HD radio inside RR config.(and if needed change com nr inside RR.ini)
step 3:
-start RR and ciontrol radio using FX's skin.
Is this correct???
Gods right foot!!
Old 04-12-2008, 07:07 AM   #6
greatwhite's CarPC Specs
greatwhite's Avatar
Vehicle: 2004 Chrysler 300M Special
My Photos: (1)
Void has hd radio support as well..............
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 04-12-2008, 10:04 AM   #7
xelz's Avatar
Vehicle: 2000 Nissan Maxima
My Photos: (0)
Just installed my HD radio last night, and here are the steps that helped me succeed:
First I made sure i had .net 2.0 installed - .net
Make sure you have the newest version of roadrunner - installer
run "runme1st" which is located in your roadrunnerdir/HDRadio directory after you install road runner
Under RRConfig->Radio choose HD Radio and pick your Line used for Radio Audio...
under RRConfig->INI Variables add: hdradioport=X where X is the COM port your HD radio is connected to (save and exit)
And run road runner and try it out.
it should work after that. when i click on radio in my skin i hear a click coming from the tuner. that should tell you the computer is accessing it. I had a tough time getting it to work in my car computer last night. the way i solved that was a fresh clean copy of of Road Runner. (i had just updated it from a previous version). You don't need to install mitch's software program (although you can use it to test your radio out). Good luck!
james
xelz is offline   Reply With Quote
Old 04-12-2008, 10:59 AM   #8
treetop777's CarPC Specs
treetop777's Avatar
Vehicle: 1981 Ford F-100
My Photos: (0)
Good info, thanks.
treetop777 is offline   Reply With Quote
Old 04-12-2008, 03:16 PM   #9
My Photos: (0)
Mitchell, who is this Mitchell???
call me mitch
anyway... the HDRadio PCR application is a joint program effort
alot of it was done by PsychoRich, http://psychorich.com/default.aspx
I just to thank him for all his work on the GUI and such!
-Thanks
Mitch
www.rush2112.net
mitchjs is online now   Reply With Quote
Old 04-13-2008, 01:23 AM   #10
seninha's Avatar
My Photos: (0)
Thanks xelz. Will try this my self
Mitch:
I was looking at the link you posted. There I see the HD interface.
Is it possible with this interface to use lets say the next frequentie: 100.8 Or is it a hardware issue and it just doesnt accept a even number??
Gods right foot!!
Sponsored Links
Old 04-13-2008, 03:19 PM   #11
seninha's Avatar
My Photos: (0)
UPDATE:
Okay. i took my PC from the car and iinstalled the HD radio.
When I use Mitch's software then I have sound. But in R when I toch the RADIO button , radio goes on but I dont hear nothing.
Also using an other frequentie doesnt help. Just can get to find any station.
Already tried 3 different skins (Void,FX and Carwings) and all gave me the same result
Gods right foot!!
Old 04-13-2008, 03:34 PM   #12
xelz's Avatar
My Photos: (0)
Yeah i was going through the same thing also (mentioned in my previous post). To get it working i just uninstalled RR, and reinstalled it in a new directory, reinputed all my settings (i know it's a pita) double checked that i did all the steps and got the correct port and and made sure i ran runme1st. if you hear clicking from the unit then the computer is accessing it. i would check your volume settings and see if you don't have anything muted. (or try hooking directly from radio unit to speakers and see if sound is coming out that way)
does it scan and stop at radio stations? it might just get stuck at 0 if there is no communication between computer and radio unit.
james
Old 04-13-2008, 03:37 PM   #13
seninha's Avatar
My Photos: (0)
I also did a new fresh RR installation. But that didn't help much
Gods right foot!!
Old 04-13-2008, 03:43 PM   #14
xelz's Avatar
My Photos: (0)
the skin you use shouldn't really matter. if it works in one skin it should work in all of em. so the problem is w/ something to do w/ RR since mitch's app works. but you probably figured that out. i'm out of ideas
Old 04-13-2008, 03:57 PM   #15
treetop777's Avatar
My Photos: (0)
Open windows volume control, make sure nothing is on "mute"
Sponsored Links
vB code is On
Trackbacks are Off
HD Radio Cables READY! mitchjs User Innovations 611 Yesterday 11:05 AM
HD Radio Commands MGD Road Runner 4 12-09-2007 12:09 PM
Can get HD Radio running on my test pc not but the carpc.. help Sonicxtacy02 Road Runner 25 11-27-2007 06:52 PM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 11:19 AM
HD Radio for the PC? dodgetimes2 Car Audio 1 08-03-2005 10:35 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
