Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 05-04-2008, 09:52 AM   #1
-zip-'s Avatar
Cant Figure out the Label Shuffle/Repeat Indicator
Hi Guys,
Tried to make a label indicator for the shuffle/repeat button
When I click on the shuffle repeat button the indicator does squat, what am I doing wrong?
Code:
"BYIND;SHUFFLE/REPEAT;=SHUFFLE/REPEAT OFF<<=SHUFFLE<<=REPEAT"
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 05-04-2008, 10:12 AM   #2
The code for the button: "SHUFFLE/REPEAT"
code for shuffle indicator: "SHUFFLE"
Do you have the indicator picture on your down picture ?
otherwise open the bmv skin in one editor and your own in another and coppy the code.
rijk is offline   Reply With Quote
Old 05-04-2008, 10:57 AM   #3
-zip-'s Avatar
Trying to use the text/label method as opposed to adding a picture with an on/off indicator.
Carputer
Sound Stage
Old 05-04-2008, 03:16 PM   #4
treetop777's Avatar
Use an indicator ("I") definition with the command "shufflerepeat" - it will show the words.
treetop777 is online now   Reply With Quote
Old 05-05-2008, 11:42 AM   #5
-zip-'s Avatar
ugh cant seem to get that going. "Shuffle/Repeat" using I (Indicator). I do use the Label Indicator for mute, works like a charm, did some reading on the boards some people have done it using L (Label).
Carputer
Sound Stage
Old 05-05-2008, 12:09 PM   #6
carputer1's Avatar
for label to show like mute or shuffle/repeat try this
L,569,487,101,44,255,0,0,23,"Arial:B","BYIND;MUTE; = <<=Mute","CENTER"
I,568,480,103,49,"MASTERMUTE"
you can have IND line anywhere you need it and same for the label.
just change the word Mute in the Label line for what ever word you want to use.
carputer1 is offline   Reply With Quote
Old 05-05-2008, 12:16 PM   #7
-zip-'s Avatar
My first post above, I tried this.. I bet is some ; or " out of place or something...
Carputer
Sound Stage
Old 05-05-2008, 12:22 PM   #8
carputer1's Avatar
correct
Old 05-05-2008, 12:55 PM   #9
-zip-'s Avatar
What it does with this code is on the skin it shows Shuffle/Repeat and does not change to "Shuffle" or "Repeat" hitting the buttons. It just stays Shuffle/Repeat.
If that makes any sense LOL.
Carputer
Sound Stage
Old 05-05-2008, 01:14 PM   #10
carputer1's Avatar
BYIND;SHUFFLE/REPEAT;=<<=SHUFFLE<<=REPEAT"
you have to use SHUFFLE/REPEAT as your IND line this will toggle between the too
Old 05-05-2008, 02:22 PM   #11
-zip-'s Avatar
tyvm for sticking with me on this carputer, will give it a go after work. Thanks again!
Carputer
Sound Stage
Old 05-05-2008, 02:23 PM   #12
treetop777's Avatar
I don't know for sure but "OFF" is probably missing in that string..
Old 05-05-2008, 07:04 PM   #13
-zip-'s Avatar
Weird
BYIND;SHUFFLE/REPEAT;=<<=SHUFFLE<<=REPEAT" Did not work either.
I have tried several combinations. Just not the right one yet
Carputer
Sound Stage
Old 05-05-2008, 08:15 PM   #14
treetop777's Avatar
This will work..
If this is what you're after..
It cycles through repeat, shuffle, shuffle and repeat, and off.
Old 05-05-2008, 08:26 PM   #15
-zip-'s Avatar
YYYYYYAAAAAYYYYY!!! Ty Tree! it worked!
Carputer
Sound Stage
Set Label to dsplay Variable mukow RR Skins 2 03-06-2008 11:03 PM
Flash Skin Tutorial? Cruizer RR Skins 49 01-10-2008 11:02 AM
Scrollable Label? JWise1203 CF SDK 11 11-03-2006 10:21 PM
My Online Indicator F350 Road Runner 10 10-05-2005 03:18 AM
M1-ATX - Q2 part label - please help cclass Power Supplies 8 08-07-2005 01:14 AM
