The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 05-06-2008, 01:04 AM   #1
My Photos: (0)
application shutdown on rr exit..
Now, does anyone experience that some of the ext. embedded app doesn't get shutdown when you exit RR?
It closes ig4, and other plugins..winamp most of the time.. even closes mpc, but, some of the application, it doesn't.... Is this a known issue, or am i doing something wrong? I like to have everything close on rr exit... i also set that flag in rrconfig too... What am i doing wrong?
Thanks. shoot.. screwed up the title... sorry....
brandensin is offline   Reply With Quote
Sponsored Links
Old 05-06-2008, 08:49 AM   #2
Wants to make it harder
monkeyracer's CarPC Specs
monkeyracer's Avatar
Vehicle: 2007 PT Cruiser Touring
My Photos: (63)
You can edit the thread title by double clicking it in the subforum or by changing to the more advanced editor.
I have an issue where it sometimes doesn't want to close winamp. For example; I'll make some changes in skineditor, and load RR, close rr, make more changes, load rr to test and since winamp didn't close properly, there are two instances, and rr doesn't know which one to pull info from. So I have to open up task manager, close all instances of winamp, and restart RR. I don't seem to have this issue with any other program, RR closes them fine, just winamp. I can try the "CLOSEWINAMP" code, but I test a lot of skins, and it's fairly annoying to add that to every skin I test.
@OP - from the skincommands.txt:
Quote:
"CLOSEWINDOW" - This allows you to close any running application based on the given window title. The application may request the user to save any unsaved data before closing, so beware.
Example: "CLOSEWINDOW;Notepad"
So whatever applications are having issues, just put this code after double pipes || to close out the stuff that RR didn't (but RR should just close anything that is embedded) on your exit button.
2007 Chrysler PT Cruiser TE
Car PC Progress:
Planning.......[---------X-] 90%
Fabrication...[--------X--] 80%
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
monkeyracer is offline   Reply With Quote
Old 05-06-2008, 10:39 AM   #3
My Photos: (0)
I can live with the way wimamp not being consistent.. but, other applications it just won't close at all... I want something like this monkeyracer, "shutdown||closewindow" but, that wouldnt' work as you know.. Is there something like this, "closeAllOpenWindows"?
Old 05-06-2008, 10:45 AM   #4
My Photos: (63)
it would be:
"SHUTDOWN||CLOSEWINDOW;"
This would close EVERY open window, I haven't tested it, but with nothing after the semicolon rr will tell windows to close any program with a windows name. (I think you just need to add the semicolon to the code.)
or to close specific windows:
"EXIT||CLOSEWINDOW;Notepad||CLOSEWINDOW;Inbox||CLO SEWINAMP" And so on, you shouldn't have more than a few programs embedded into your skin, so it shouldn't be too hard to do this.
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 05-06-2008, 10:51 AM   #5
Sal R.'s CarPC Specs
Sal R.'s Avatar
Vehicle: 2001 A4 1.8TQMS
My Photos: (36)
In rr.ini:
closeapps=true|false
Close any open embedded applications on exit
MicroXP / RR v11/04/2007 / Winamp v5.13 / MMIv2
RR Album Art Browser
Sal R. is offline   Reply With Quote
Old 05-06-2008, 10:52 AM   #6
My Photos: (0)
hmm... no luck... well.. i just gonna have to close it explicitly..
let me try that Sal...
well... just confirmed it was set to true...
closeapps=true
Old 05-06-2008, 11:08 AM   #7
Sal R.'s Avatar
My Photos: (36)
What version of RR are you using?
I use a few external apps (VAG-COM, System Manager, Filemanger, Notepad, etc.) embedded and they all close when I exit RR.
Old 05-06-2008, 11:21 AM   #8
My Photos: (0)
dec 13 2007.... It won't close garmin mobile pc it still runs after rr being out...
Old 05-06-2008, 11:32 AM   #9
My Photos: (63)
If that's the only program that doesn't close, either add the windows name to
embedapplist=[windows name]
in rr.ini,
or use the CLOSEWINDOW;[windows name]
Just replace the [windows name] with what the actual windows name is (winspector spy will help find this)
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 05-06-2008, 11:33 AM   #10
EL CAMINO's CarPC Specs
EL CAMINO's Avatar
Vehicle: 1981 chevy el camino
My Photos: (0)
some app's dont close at all when exiting, freefone, imageviewer, and rainlendar are the ones i know for sure they always keep running. sonic added a command 'ONEXIT" (i think)to one of his beta's, hope it makes it to the official soon.
EL CAMINO is offline   Reply With Quote
Sponsored Links
Old 05-06-2008, 12:06 PM   #11
My Photos: (0)
monkeyracer, i already have tried ur suggestion.. it didn't do it on shutdown.. it might close it when exiting a skin, but that's not what i want... i want it to happen when i close RR.... RR is big daddy... daddy says everyone go to bed... then it's a nap time for everyone, no BUT..
el,
so, it's a known thing.... well... guess i have to wait for sonic's magic command too then.....
thanks guys..
Old 05-07-2008, 01:27 PM   #12
Road Runner & Mp3car Gatherings Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
Arrow Manually kill a task
Its not a perfect sollution, but works perfectly for me. I simply wrote a small script, that I can pass the name of a task to, and it will kill it.
To Kill Winamp for instance, I have the following line in my Exectbl.ini:
Code:
"KillWinamp","RunQ;$skinpath$scripts\Kill_Task.exe|winamp.exe"
On the Exit button in my skin, I have:
Code:
"KillWinamp||QUIT"
This way when I close RR, Winamp is forced to close.
Simply change the winamp.exe to any process you want to kill and create more lines in the exectbl for each thing you want to be sure is closed, Rainlender for instnace:
Code:
"KillRainlender","RunQ;$skinpath$scripts\Kill_Task.exe|Rainlender.exe"
SO now your exit button would have the following code to close both:
Code:
"KillRainlender||KillRainlender||QUIT"
Attached it the zipped up .exe
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0
7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD
Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 4.0 Skin www.johnwpb.com
JohnWPB is offline   Reply With Quote
Old 05-07-2008, 02:31 PM   #13
My Photos: (0)
Thanks John, you're a star!!!
alex21008 is offline   Reply With Quote
Old 05-08-2008, 03:17 PM   #14
Valheru's CarPC Specs
Valheru's Avatar
Vehicle: 2006 Skoda Superb
My Photos: (0)
Hey John,
Can we all use that little TaskKiller .. it would be very useful ?
Valheru ...
Check out the TEKNIK skins here
Valheru is offline   Reply With Quote
Old 05-08-2008, 04:45 PM   #15
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
Try to have RoadRunner start the program.
Normally any program started as a child of another program will close when the parent closes (unless Guino has down something special to start external Programs)
Enforcer is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Why do people think RR is hard to setup? 2k1Toaster Software & Software Development 53 05-18-2008 12:38 AM
Someone please help - RR not saving song on exit ckny Road Runner 42 05-10-2008 11:43 PM
RR is acting really slow... debug.txt attached ludikris Road Runner 10 04-11-2008 12:35 PM
OBDII Module doesn't work Lok Bug Tracking 18 04-10-2008 03:33 PM
XMD RR Hibernation & XMRESET hank_kls65 Road Runner 17 10-25-2007 03:14 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
