The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 05-06-2008, 07:01 PM   #1
mpfjr's CarPC Specs
mpfjr's Avatar
Vehicle: 1965 Dodge A-100 Van
My Photos: (0)
HDRadio & Roadrunner (will not turn on)
Ok, so I installed the latest PCR software off of mitch's site. Have the HDZ300 unit hooked up correctly. Got it working for a while using the software but could not get it working with Roadrunner.
Latest Road Runner comes with the files in the HDRadio folder. I ran that "runmefirst.cmd" and did all that. Set up rr.ini according to mitch's instructions. When I start HD Radio (using digitalfx 3.0) it doesn't click on.
Tried an updated .dll file dropped into that same directory and still nothing. If I plug in the little control unit the HD Radio comes with I can tune in stations and listen to them etc. If I use mitch's pcr software it works too. Just can't get RR to switch it on when I hit the hd radio icon. Is it a skin issue or a RR issue or something else?
Now I have a new problem. Found out I didn't have the HD Radio unit (black wire) grounded. It was routed up where I as going to ground it but it wasn't grounded. So I fixed that but now when I run the PCR software it immediately generates an error and I have to exit out. So now the unit ONLY works when I use the controller box. Maybe my battery is low and there is not enough amps/volts? Could be. I have it charging and I'll test it tomorrow. But that still doesn't solve the problem with the unit not starting (powering up) withing RR.
My RR.ini says
[Radio]
radiomode=8
allowallfreqs=false
radioline=5
userbds=true
mpfjr is offline   Reply With Quote
Sponsored Links
Old 05-06-2008, 07:36 PM   #2
Sal R.'s CarPC Specs
Sal R.'s Avatar
Vehicle: 2001 A4 1.8TQMS
My Photos: (36)
hdradioport=<enter com port>
MicroXP / RR v11/04/2007 / Winamp v5.13 / MMIv2
RR Album Art Browser
Sal R. is offline   Reply With Quote
Old 05-06-2008, 08:24 PM   #3
mpfjr's CarPC Specs
mpfjr's Avatar
My Photos: (0)
Thanks I'll try that in the morning.
Edit/update: That did the trick thanks!
Sponsored Links
vB code is On
Trackbacks are Off
Mappoint and Roadrunner Error 0statik GPS 0 07-05-2006 11:46 PM
AMP wont turn ON!! HEELP! pdjafari Car Audio 1 10-15-2005 07:43 PM
PC wont turn on.... Cheekz185 General Hardware Discussion 0 08-18-2005 12:27 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
