The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 05-11-2008, 01:09 PM   #1
My Photos: (0)
Line-in problem
Hi,
I just got my HD Radio working with Mitch's cable, really nice stuff. However, I'm having a problem with Road Runner and the line-in. RR does unmute my line-in, which is good. But for some reason, the volume is set to the lowest and I have to manually change it so that I can hear the radio.
Anyone got an idea why my line-in's volume gets set to the lowest?
Dgege is offline   Reply With Quote
Sponsored Links
Old 05-13-2008, 10:12 AM   #2
My Photos: (0)
I have the same problem but it only seems to happen after I use Iguidance for navigation. Would love to find a solution.
jjakes24 is offline   Reply With Quote
Old 05-13-2008, 09:57 PM   #3
My Photos: (0)
Hmmm... that might explain the "randomness" of it. So iGuidance is the culprit? I'll test that tomorrow. Btw, any solution? Maybe using the winamp line-in plugin?
Old 05-15-2008, 02:05 PM   #4
My Photos: (0)
I haven't figured anything out yet. Not even sure if it only happens when using Iguidance, I just noticed there might be a connection. I also lose all my presets in the HD radio skin. So bizarre. I might just put a button in the HD radio skin that executes a program that raises the line in to a certain level and unmutes it.
Old 05-15-2008, 03:01 PM   #5
My Photos: (0)
If you do that, don't forget to share please
Old 05-15-2008, 03:35 PM   #6
Machinehead's CarPC Specs
Machinehead's Avatar
My Photos: (0)
What about adding a command to your exectbl.ini to increase the line-in volume when you open the hdradio skin?
Machinehead is offline   Reply With Quote
Old 05-15-2008, 03:39 PM   #7
My Photos: (0)
Unfortunately, I have no skills when it comes to that
Old 05-15-2008, 03:56 PM   #8
My Photos: (0)
It's actually pretty easy. It's a setvolume command.
What skin are you using?
Old 05-15-2008, 04:01 PM   #9
My Photos: (0)
DigitalFX 3.0
Old 05-15-2008, 06:04 PM   #10
My Photos: (0)
Of course you had to pick the most complicated skin.....
I need to do some more poking around.
Sponsored Links
Old 05-16-2008, 12:23 AM   #11
My Photos: (0)
Hehe, sorry. Actually, I prefer LSX, but the HD Radio works better with DFX.
Old 05-16-2008, 10:22 AM   #12
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (129)
check to see in rrconfig if the master volume is mapped to the right line on ur sound card.
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
Old 05-16-2008, 04:10 PM   #13
My Photos: (0)
I think I fixed the problem by using the winamp line-in plugin. And that also makes the radio work better with iGuidance, since RR lowers the volume of winamp when IG speaks.
Two birds with one stone! And I don't seem to get any performance penalty
Sponsored Links
vB code is On
Trackbacks are Off
Sirius AUX in Connection to BMW e46 - line failing melukin Car Audio 0 11-22-2006 03:23 PM
zalman and dsb-r100 problem jampac Car Audio 2 11-17-2006 10:07 PM
Line Driver Vs. Amp Sensitivity Adjustment 3onDubs Car Audio 5 11-28-2005 07:37 PM
had an all day (9 hr) problem at work.... wizardPC Off Topic 13 10-20-2005 11:50 AM
Question on Line Out of M10000 and Audigy NX Mears General Hardware Discussion 24 06-10-2004 04:00 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
