Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 06-05-2008, 07:51 PM   #1
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
AlbumArt and flash
i been trying to get this to work and cant find the way, i created a small flash object using flash CS3 to show the current albumart with some effects, it works flawlessly standalone, hardcoding the picture path, but when using RR it just dont work, it appears that the flash object is not getting the path from RR for the image, i even make the flash object to set a variable in RR to see what is getting from _root.ALBUMART and all i get is "undefined". i have the label "ALBUMART" in the screen where the movie is embedded, so as far as i know is all i need, heres part of the code i'm using
Code:
fscommand("GETLABEL", "ALBUMART"); artwork = _root.ALBUMART fscommand("SETVAR;FLASH;" + artwork);
EL CAMINO is offline   Reply With Quote
Old 06-06-2008, 08:40 AM   #2
Wants to make it harder
monkeyracer's Avatar
monkeyracer is an unknown quantity at this point
I'm not sure it will work with flash, but have you tried the RRStrings plugin yet with the "PathFromPath" tag?
That might work.
Or have you tried the "COVERART" code instead of albumart? coverart is supposed to act a little different than albumart.
2007 Chrysler PT Cruiser TE
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
monkeyracer is offline   Reply With Quote
Old 06-06-2008, 11:39 AM   #3
EL CAMINO's Avatar
that plugin will help if you don't want to use a script to get paths, i can do that inside flash or a script, the labels and indicators for 'ALBUMART" and "COVERART" will return a string with the path of each one as fas as i know...
Old 06-06-2008, 11:59 AM   #4
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
i'm not using flash cs3 but if it helps i can post a working version from swishmax? Has no affects tho just displays the album art from the ALBUMART label.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 06-06-2008, 01:12 PM   #6
Terminal flasher
Quote: Originally Posted by EL CAMINO View Post
please thanx
here you go.. you should be able to compile that , add the ALBUMART label and flash object to your skin file and be good to go. Credit goes to CDR for most of that code though.
03 Acura RSX Coupe
Old 06-06-2008, 01:16 PM   #7
EL CAMINO's Avatar
cool thanx again
ALBUMART of the specified item banderas RR Skins 5 04-09-2008 11:57 AM
Flash ALBUMART Loader LeeVD RR Skins 0 01-10-2008 04:14 PM
Notice :- Flash speed with albumart CdRsKuLL RR Skins 7 03-15-2007 07:39 AM
Audio_Browser and Albumart CdRsKuLL RR Bug Tracker 0 03-12-2006 03:48 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
