06-09-2008, 05:54 PM
#1
Getting an error when trying to open rr for the first time
I have just downloaded RR, installed it and when I try to open the RR Config.exe I get an error that says " Line-1,(next line) Error: Unable to execute the external program (next line) The system cannot find the file specified."
Anyone know what this error means and how to get rid of it?
06-09-2008, 06:21 PM
#2
Same here ,I downloaded from all mirrors installed ,uninstalled,reinstalled each one I downloaded . I installed RR and DigitalFX 3.0 six times on 6 different pcs and never had this happen before .And it seems there is a problem somewhere. maybe because I'm installing this on Vista this time and not XP ? Who knows never get a real answer on this site. It's just one big circle jerk here. .........good luck.
06-09-2008, 06:26 PM
#3
Maybe it is not Vista comp. B/c I am trying to install on 32-bit Vista too. I didn't read anything about not being Vista comp. did you?
06-09-2008, 06:48 PM
#4
Raw Wave
You certainly are not speaking from experience 'cause you are being helped! of course, you can always go away. Don't bite the hand that feeds you..
For the OP, I'm just guessing but make sure the RR files are in a folder called "Road Runner" not "RoadRunner"
The config is looking for a file it can't find; i would guess Roadrunner.exe or rr.ini
06-09-2008, 07:13 PM
#5
So do I need to download the rr.ini file? If it does not come in the installer package, where can I find it?
06-11-2008, 04:45 PM
#6
I don't understand, I have installed RR on my work computer which is running XP, copied the RR package and tried installing on the Vista running Carputer (same way has I did on the XP Computer) and when I open the config.exe, I get the error I stated above. When I try to open the RR.exe, the error I get is "C:\Program Files\Road Runner\Skins\Alpine does not contain a valid skin! Check your settings and try again", I understand what the error is saying but I can't change anything b/c I can't get the config.exe to open. Is there something special I have to do for Vista installation. I have read around and couldn't find anything. Has anyone seen this and have a fix for it.
06-11-2008, 04:49 PM
#7
Terminal flasher
open rrconfig, save rrconfig.. open roadrunner.. problem should be solved.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
06-11-2008, 05:17 PM
#8
OK i can open the config.exe now. I have changed the skins to BMW(default) but now I get this error when opening rr.exe, " Error:372, Failed to load control 'flash' from. Your version of may be outdated. Make sure you are using the version of the control that was provided with your application". Ok i have no idea what that means. I just downloaded the RR package today from the Sticky in the main page so I don't have a old version. Anyone know what this error is about and how to fix it?
06-11-2008, 06:34 PM
#9
Terminal flasher
open internet explorer and update flash from adobe's website
03 Acura RSX Coupe
06-12-2008, 07:39 AM
#10
06-13-2008, 04:38 PM
#11
Done that, I now get this error " Run-time error '75': Path/File access error" when trying to open the config.exe. After clicking OK, it opens the config.exe and I can change stuff around. After saving changes and setting the skins to BMV2. I try and open the RR.exe and get the error that state "C:\Program Files\Road Runner\SKINS\ Alpine does not contain a valid skin! Check you settings and try again." Well the Config setting is set to BMV2 so I don't know where Alpine is coming from. Any idea of what is going on and how fix it?
06-13-2008, 04:45 PM
#12
Raw Wave
Goodness! you got problems! Attach your rr.ini file let's take a look.
06-13-2008, 04:50 PM
#13
Not to be stupid but where in the Road Runner folder would I find the ini?
06-13-2008, 04:54 PM
#14
i heard people having all sort of problem using rr with vista... why not run xp, saves you trouble now and later... those file access problem seems alot to do with the way vista works... I was thinking about vista too,but what's the point if i am gonna run rr most of the time... This is not a solution but, i strongly suggest you do this with xp like creator recommended.. You might encounter more problems later and evetually fed up with it...
ini is in the road runner root directory where it was installed...
rr.ini
06-13-2008, 05:02 PM
#15
Ok, thank you.
Here is my ini file. I didn't realize RR had so many problems running on Vista.
[Player Setup]
player=Winamp
winamppath=Click here to set path
hidewinamp=true
exitmute=true
[General]
voice=false
disableinternat=false
showicons=false
showextensions=false
hidemouse=false
hidetaskbar=false
hidedesktop=false
hidedots=false
gpstime=false
exitmode=0
dateformat=Short Date
timeformat=Short Time
locale=0
screentype=4:3
debugmode=false
enableclipping=true
nozoom=false
usegestures=true
leavemousealone=false
closeapps=false
fastmode=-1
usedualmon=false
soundcard=0
screenlimit=10
mastervolmap=-1
hibernateaware=true
forcehibernate=false
hibernatereload=true
usbsound=false
browsertype=0
usevoicecontrol=false
usecar2pc=false
fadeinvolume=true
picspath=To set path, Click --->
[Skins]
skinpath=C:\Program Files\Road Runner\Skins\BMV2\
nightskin=C:\Program Files\Road Runner\Skins\BMV2\
transition=-1
background=To set path, Click --->
TransitionTime=0.2
[Gamma]
gammamode=3
gpsgammamodeoffset=0
gammaday=0:0:0
gammanight=-50:-50:-50
gammadaytime=1:00
gammanighttime=1:00
autogammamode=1
autoskinmode=1
[Preload Screens]
[Music]
musicpath=Click here to set path
playlistpath=Click here to set path
useid3=0
singleclickaudio=false
noformat=false
listnumbers=true
listfollowssong=true
id3listformat=%title%
id3browseformat=%title%
titlesafter=-
albumart=*.txt
fadeimages=false
visuname=MilkDrop
scrollmode=1
circularlist=false
groupnumbers=false
resumemusic=0
audiorepeat=false
audioshuffle=false
transparentvisu=false
opacityvisu=40
[Radio]
radiomode=0
allowallfreqs=false
userbds=false
[XM]
xmport=0
xmlineinplugin=false
xmtype=0
singleclickxm=false
xmformat=%station% %artist%
[SIRIUS]
srport=0
srlineinplugin=false
singleclicksr=false
srformat=%station% %artist%
[Video]
videopath=Click here to set path
mpcpath=Click here to set path
videoautohide=true
videohidetime=4
builtinvideo=true
videoshuffle=false
[TV]
tvline=0
[GPS]
mapmonkeypath=Click here to set path
gpspath=Click here to set path
gpsname=
overspeed=55
gpsport=0
mappointmap=1
mapcountry=United States
mapcity=
mapautozoom=true
isunits=true
usegpsserv=false
gasfinderautorefresh=false
[IG Native]
[Speed Att Vol]
speedatt=false
[Phidget]
phidget1=0
phidget2=0
phidget3=0
phidget4=0
phidget5=0
phidget6=0
phidget7=0
phidget8=0
[4 Temps]
tcomport=
tempscale=c
temp1=c
temp2=c
temp3=c
temp4=c
[Volt Meter]
vcomport=
[Phone]
phoconodesign=false
motophone=false
phonelistspath=Click here to set path
contactspicturespath=Click here to set path
ringtone=Click here to set path
smstone=Click here to set path
maxcalllistentries=100
phoconoincallevent=false
connecthsp=true
standardphonebook=0
phonebooksencoding=windows-1252
[Weather]
cityweather=
weatherunits=USA
weatherdegress=º
localdatacaptureinterval=0
[Extra's]
| Thread Tools |
| Display Modes |
Linear Mode
