Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Closed Thread
Old 07-02-2008, 09:23 AM   #61
Dave323Ci is an unknown quantity at this point
Save your logs for Mitch.... I had the same kinds of issues until I wired my XM and HD to be on w/computer power supply. Ever since XM and HD have been perfect -- doesn't matter which was active when I hibernate. For whatever reason my setup doesn't fully come out of hibernate until I hit the touchscreen.... so I usually wait a bit
Dave323Ci is offline
Old 07-03-2008, 09:09 AM   #62
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Quote: Originally Posted by mitchjs View Post
sonicx, logs..logs...logs
I havent had xm or HD turn on ISSUE since this release
need to see if xm was found...
at this point i dont see any issues...
it up to you guys to provide tangable(sp) data
mitch
well i cant duplicate that error now so i'll just let it go. Now couple of other things i have been able to duplicate. If i go from XM playing, back to the main menu, the run the RADIO command radio will successfully turn on and play, but if i go back to the main menu radio turns off and XM goes back to playing. Is it supposed to work this way?
Another thing i've noticed is that your SAT and TER labels dont update after resume. If i restart road runner they start working again.
here's my debug showing whats goin down with the XM switchback problem.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Sonicxtacy02 is offline
Old 07-03-2008, 09:42 AM   #63
Raw Wave
mitchjs is on a distinguished road
what is "run the radio command"
looking at your log, its all correct
your "wasradio" didnt change, so it still set to xm..
like i said before, RR source handling isnt so good
what is ur radio? hd radio? turn on hddebug=true
without that log useless...
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline
Old 07-03-2008, 09:44 AM   #64
Raw Wave
as for sat and ter lables, who knows...
i just added them in with all the rest, if the rest update, these should too
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
mitchjs is offline
Old 07-03-2008, 09:58 AM   #65
Terminal flasher
mitch
i ran the RR command "RADIO" which turns on the radio and goes to radio_player.skin. If wasradio didnt change then why did xm turn off and radio become tunable (cant neccessary hear it because of lack of line-in... but usually if radios not working at all frequency wont tune to stations)? And i do have HDDebug=true in rr.ini. Least i believe so.. i'll double check maybe it got erased somehow
03 Acura RSX Coupe
Old 07-03-2008, 03:42 PM   #66
Raw Wave
i didnt see any hd radio debug stuff... maybe i missed it
i look, yes sorry there is SOME..
sorry no need to look...
when u went into radio...
7/3/2008 8:06:47 AM: XM---> XMInActive: XMON=False
7/3/2008 8:06:47 AM: XM---> oXM_XMEventRadioReady:
7/3/2008 8:06:47 AM: XM---> XMPoweredON: XMON=False,XMTuneTo=0
the XM just came alive
but i NEVER SEE ANYTHING from HD from this point on
the log is HD FREE from your resume at 8:06:44
NO log entries for the HD Radio powing on...
7/3/2008 8:06:44 AM: HD---> HDRadioPowerOn:
7/3/2008 8:06:44 AM: HD---> HDRadioPowerOn: frmCOM.oHD.Open
thats why it failed
it tried to open the port, and couldnt
and this
7/3/2008 7:59:43 AM: ResumeFromHibernate: Start tuners... Sirius, XM, & HD
7/3/2008 7:59:43 AM: XM---> XMLoadIn: xmcache.ini, XMLastChannel=140
7/3/2008 7:59:43 AM: XM---> XMLoadIn: End Sub
7/3/2008 7:59:43 AM: XM---> XMPowerON: .Open
7/3/2008 7:59:43 AM: HD---> HDRadioPowerOn:
7/3/2008 7:59:43 AM: HD---> HDRadioPowerOn: frmCOM.oHD.Open
7/3/2008 7:59:43 AM: CheckResume: ResumeMusic=2 WasRadio=2
7/3/2008 7:59:43 AM: XM---> XMActive:
7/3/2008 7:59:43 AM: XM---> XMActive: PORT not OPEN, waiting...
7/3/2008 7:59:43 AM: XM---> XMActive: XMON=True, XMTuneTo=140
7/3/2008 7:59:43 AM: XM---> Radio not found
7/3/2008 7:59:43 AM: HD---> oHD_HDRadioEventSysPortOpened: .PowerOn
7/3/2008 7:59:43 AM: XM---> oXM_XMEventPortOpened: .PowerOn
7/3/2008 7:59:45 AM: HD---> oHD_HDRadioEventHWPoweredOn
7/3/2008 7:59:45 AM: XM---> oXM_XMEventRadioReady:
you are still having some hardware issues...
this is wierd
then it got the port open...
and why do i see double log entryies in UR log...
are u still band-aiding anything? if so remove it
at
7/3/2008 7:59:39 AM: ResumeFromHibernate:
then
7/3/2008 7:59:40 AM: ResumeFromHibernate:
why is resumefrom hibernation called many many times on ur system!
is windows sending you resume messages??!?!?!?
ResumeCheck
make sure its 0
ResumeCheck=0
there is only two places one canget to "resumefromhibernate"
one some some "ResumeCheck"?? and the other a OS windows message...
and why the f is 7/3/2008 8:06:44 AM: ResumeFromHibernate:
event here, ur not hibernating!!!
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
mitchjs is offline
Old 07-04-2008, 12:36 PM   #67
fixerofallthing's Avatar
fixerofallthing is on a distinguished road
I just wanted to drop in again and say GREAT JOB!! Everything is working great with no delays and all functions working perfectly. Thanks for all the hard work mitchjs.
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline
Old 07-04-2008, 01:54 PM   #68
Raw Wave
thanks, what radio systems you got? Xm, Sirius, HD Radio....
-Thanks
Mitch
www.rush2112.net
within our hearts
mitchjs is offline
Old 07-04-2008, 02:22 PM   #69
PontiacGA's Avatar
PontiacGA is on a distinguished road
Wow! Much improved! Thanks again.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
PontiacGA is offline
Old 07-04-2008, 02:29 PM   #70
XM and HD
Old 07-05-2008, 06:55 PM   #71
Raw Wave
All too quiet here... i gues it really is working well
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
mitchjs is offline
Old 07-05-2008, 08:48 PM   #72
insaneramman's Avatar
insaneramman is an unknown quantity at this point
Talking AAAAAAhhhhhhhhhh.
Dang it... Went out to try erie's new frt end (it's awesome) and didn't put the 7-1-08 version in. Will try tomorrow though and let you know. Although I"M STILL HAPPY WITH THE FIRST ONE
insaneramman is offline
Old 07-05-2008, 09:23 PM   #73
Raw Wave
what? erie's new frt end ?
whats that
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
mitchjs is offline
Old 07-05-2008, 09:38 PM   #74
Cool Just a little something
Mitch it's here-- http://www.mp3car.com/vbulletin/othe...6k-beware.html -- take a look I think it's pretty cool.J/K
Old 07-06-2008, 12:14 AM   #75
Raw Wave
looks like "another RR", just another front end, written in a old legacy language
it doesnt jump out, id prob have to see it in action
i for sure dont like the sample images, looks cluttered and hard to use when driving
like most skins... great when not moving...
course i've been spoiled, by my control... the sony rm-x11
is there a download?
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
mitchjs is offline
Closed Thread
RR 09-30-2007 ... HD Radio & some more.. guino Road Runner 83 10-20-2007 10:01 PM
XM issues with RR dseoane Road Runner 0 08-10-2007 06:10 AM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
