Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 07-08-2008, 09:05 PM   #1
volume level on resume from hibernate
sometimes when I resume from hibernate the volume level in the mixer for whatever I'm using i.e. digital in for Sirius, or winamp for music is all the way down. What would lower the volume on these things when I resume from hibernate? I tried "roadrunner is aware of hibernate etc etc" in the config tool and it really doesn't seem to affect anything.
thanks
turbochris is offline   Reply With Quote
Old 07-08-2008, 09:13 PM   #2
fixerofallthing's Avatar
thanks
try turning off the fade in volume on resume setting in RRConfig. It fixed it for me.
The Car 2005 Scion xB
The Truck 2004 GMC Canyon
fixerofallthing is offline   Reply With Quote
Old 07-09-2008, 02:03 AM   #3
Griff1's Avatar
Yeah i had the same thing.
P4 2.8 HT, 1GB Ram, 200Gb 3.5 HD, M4-ATX,2 x Silabs USB, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RoadRunner, iGo8,Custom Freedom 2.1
Griff1 is offline   Reply With Quote
Old 07-09-2008, 05:48 AM   #4
RR raises the volume of winamp from 0 up to where it was previously. you can actually watch winamps vol slider go up (if the winamp window is visible). you may also try disabling volume control (Preferences>output plugins>Directsound>configure>Other>Volume Control) on the winamp side of things, and it might make winamp locked into full (100%) volume at all times.
Iceman_jkh is offline   Reply With Quote
Old 07-09-2008, 10:39 PM   #5
DONT USE VOLUME FADE!!!! its conceptually bugged... would need a complete rewrite of audio management in RR
fadeinvolume=false
UNLESS!
you are using winamp FOR ALL AUDIO MANAGEMENT
ie. all sources use winamp, like XM, Sirius, HD and etc. must use the WINAMP LINE IN PLUGIN
and NOT the Windows mixer
THEN fade would be OK
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is online now   Reply With Quote
Old 07-10-2008, 12:33 PM   #6
fadeinvolume=false
UNLESS!
Mitch,
Do you know why it works sometimes but not others? I don't mind turning it off, but I do enjoy the effect. Thanks!
qbunnie is offline   Reply With Quote
Old 07-10-2008, 04:33 PM   #7
I think it has something to do with not getting focus on the winamp window for long enough to issue the fade=in command. It switches back to RR focus to early, in some cases. But thats only a guess based on what I have observed.
Old 07-10-2008, 09:30 PM   #8
yes... i know exactly why it doesnt work...
hard to explain... i would rewrite it if it was easy...
its because how audio is managed in RR all together
some audio is MIXER managed, and MP3s are WINAMP managed
prob should all be dumped, for say a single audio system, like BASS Audio Library
but if u use winamp for EVERYTHING (XM, HD, Sirius) and RR not touching the mixer for volume... it might work... its also tied to the fact that RR resumes last source as MP3 (now thats fixed in my version)
also the volume isnt tracked by RR, it assumed to be in winamp... and winamp volume 0-255 has NOTHING to do win MIXER VOLUMES 0 -65535, so i see the mixer volumes get so messed up
just dont use it
audio VOLUME should be managed at 1 point!! which its not
prob could do a work around fix, the keep RR from touching the LINE IN VOLUMES
but then they wouldnt fade up, just like i dont think it should be touching WINAMP volume, volume should be controled at the OUTPUT side, not on a SOURCE
source meaning mixer input, winamp
not to mention VISTA audio management, which is ACTUALLY AWESOME!
maybe a rewrite to RR to fade volume with MASTER, it might work
i know, i dont know enough about RR, i dont use RR (im not carpc nut, hehe), but i have been deep in RR code alot lately
mitch
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 07-11-2008, 11:34 AM   #9
Yeah, I think taking the Hardware Abstraction Layer away in Vista was a good move, even if a lot of manufacturer's hated it. Simpler for applications. Thanks for the information.
Hibernate and Vis and Resume RichP714 RR Bug Tracker 7 09-22-2007 02:43 AM
Set Volume at Start and Resume from Hibernate efficinet Software & Software Development 3 02-01-2007 09:33 AM
Resume after hibernate scrutinized ldave PowerVoice 6 02-09-2006 11:04 PM
Resume from hibernation, Volume level at 0 blackflux General Hardware Discussion 13 04-08-2005 02:19 PM
Audigy 2 NX full volume after resume STI_FFY Car Audio 4 11-22-2004 09:38 AM
