01-30-2009, 08:17 AM
#61
Quote: Originally Posted by guino
This is a DirectX issue -- it drops the memory surfaces without telling it's clients (RR in this case).. RR has many built-in functions to detect/correct this issue, but if your hibernate/resume procedure isn't working right to begin with, my guess is that the only solution for you will be to reload the skin after resuming (i.e. by adding: "ONRESUME","RELOADKSKIN" to exectbl.ini)
well, this was a try, but since hibernation awareness is switched of, skin reload didn't work.
ticking this on leads to a reload of the skin, but the initial problem is not solved then.
Car: Ford S-Max 2,5T
CarPc: intel D201GLY, 7"-Touchscreen, RoadRunner, IGo8
HiFi: Alpine CDA 9855R, Diabolo D19/AA165g, Tymphany LAT500, Signat RAMbo, AudioSystem f2-300
01-30-2009, 11:02 PM
#62
Raw Wave
Quote: Originally Posted by Spacelord
Hi *,
ticking off the checkbox for "hibernate awareness" in settings did the fix for me. RoadRunner and embedded progs run as expected. no reenter into hibernate after 5 minutes.
The only issue remaining is the iList-blackout after resume
not having hibernate aware on, will have other issues...
also, what does "ticking off" mean, unchecking?
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
02-02-2009, 03:39 AM
#63
sorry, I meant unchecking.
Well, when I check "Hibernate aware" on and add skin reloading, the problems are even worse. I have to tap on the screen to unfreeze Roadrunner, then the skin reloads (I use the old Carwings skin) but I get a small white rectangle in the left upper corner. Have to tap again to get rid of it.
Which issues are to expect, when "hibernate aware" is not switched on?
02-02-2009, 08:12 AM
#64
Raw Wave
on hibernate:
hdradio, sirius, xmradio will not close
internal gps,temp com stuff will not close
winamp will not be told to stop
hdradio, sirius, xmradio, will not restart
internal gps,temp com stuff will not restart
winamp will not get reinited(may not be a problem)
screen refresh will be missed
NOT TO MENTION, the next hibernate/resume is gonna really be messed up
if u wanted, we could work together, and figure out what stage in the Resume u got issues at...
i would make a couple custom builds...
when i think about it... im not sure the why this check is even needed
Please collect a debug.txt for a session with a resume, and ATTACH it here
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
02-02-2009, 09:52 AM
#65
Well, I don't have those radios over here in good old germany
Also, tried 2 days without hibernate awareness and everything worked except the ilists.
Anyway, I'd like to have this issue resolved and I'll attach the debug file here tomorrow.
02-03-2009, 06:10 AM
#66
WEll, I have to read the threads more carefully  I have the same issue with InitDX.
Installed RideRunner (2/2/2009) and the issue is gone.
But I have a strange problem with mixer settings. Initially, no sound was coming. As i went to the mixer, the settings for master volume was 100%, bass 0%, treble 0%, cd 0% and so on. I anyway tried to increase the master volume and bass, treble, cd and aux went up and sound came out. Is it a new issue?
02-03-2009, 06:53 AM
#67
RoadRunner Mastermind
You probably changed the master volume map setting.. check/set that mapmastervol=0 in rr.ini
Ride Runner RR's Myspace
02-03-2009, 09:23 AM
#68
this was a clean install of RideRunner, no mods...
02-03-2009, 11:11 AM
#69
Raw Wave
yes, sorry, unless u run rrconfig and set volumemap
i sent it out as -1, it really should be 0, almost NEVER needs to be -1
fixed for future releases
-Thanks
Mitch
www.rush2112.net
within our hearts
| Thread Tools |
| Display Modes |
Linear Mode
