Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 07-18-2008, 04:47 PM   #1
Dougw133 is an unknown quantity at this point
Dial UP Connection Window RR/DFX?
Hi, I have inquired to JohnWPB of the DFX3 skin which I activley use, if it would be possible to add a button and screen for DUN. I use a cell phone to get my internet on the go. At current I have to minimize RR and open a shortcut of the Pre-Setup Dial Up Connection. The all I have to hit is dial or disconnect. John responded to me and has figured mostly what to do. Here's the problem... I am a moron when it comes to skinning. This is what john gave me.
"LOAD;Display_Properties.skin;NetworkConnections;C :\WINDOWS\system32\control.exe|netconnections"
Ok... I don't even know where to start with this. Where does this incorporate? Is it RR or the skin? How can I create a button to take me to a screen, something like the Wireless Manager in DFX 3. Big robust matching buttons. I am doing reading and have been playing with the skin editor. I am still lost. Any help is much appreciated.
Dougw133 is offline   Reply With Quote
Old 07-21-2008, 10:11 PM   #2
BumP!
I have adopted a program called SP Dialer 1.40. It manages the Dun just like window with more options. Windows Dial Up Network manager is a component of explore there for running it is a pain. This incorporates a Dial/Hang up button. It also allows a HOTKEY to be mapped for the dual function. I press END key and it connects, I press END key again and it disconnects. There's got to be a way to just have a button on the Main Menu that can serve this same function. Maybe something to mimic the key stroke? Rout to OSK perhaps in the background. I have embedded the app but it is ugly and i don't need the program in RR itself. It can just run in the tray as long as I had that button. Any ideas?? C'mon!?? Yer all geniuses!
Old 07-21-2008, 11:06 PM   #3
rsrblade is an unknown quantity at this point
Dougw133 here's what my buddy and I did.
First locate the Exec.tbl file within DigitalFX.
Create a couple of files:
1. "MyApp48","RunQ;$SKINPATH$\connect.bat"
2. "SetCommandLabels48","SETVAR;MyApp48LB;CONNECT||Se tCommandLabels49"
and another set for Disconnect:
1. "MyApp49","RunQ;$SKINPATH$\disconnect.bat"
2. "SetCommandLabels49","SETVAR;MyApp49LB;CONNECT||Se tCommandLabels50"
Then create two .bat files using notepad. Call one Connect.bat and the other Disconnect.bat Save in the digitalfx folder
examples:
connect.bat contents = rasdial "your connection name" (be sure to put the connection name in quotes)
disconnect.bat contents = rasdial "your connection name" /d ( again be sure to put the connection name in quotes)
This should 1. create your "connect" and "disconnect" buttons and the .bat files will allow the built-in ras dialer in windows to start or stop the connection pending on button pushed.
Hope this helps
rsrblade is offline   Reply With Quote
Old 07-21-2008, 11:12 PM   #4
x10
x10's Avatar
x10 is on a distinguished road
ok you need to use rasdial...its the easiest way to connect to a phone modem (USB or bluetooth)
all you need to do is create a standard dial up connection using your phone as a modem...
Next is to create 2 batch files..just use notepad and when you save the file just make sure you put .bat at the end of it....I called my disconnect.bat and connect.bat
In the following examples..."NationalAccess - BroadbandAccess" is the name of my dial-up connection...change it to the name of your dial-up connection
connect.bat looks like this:
Code:
rasdial "NationalAccess - BroadbandAccess"
and disconnect.bat looks like this:
Code:
rasdial "NationalAccess - BroadbandAccess" /d
Next are the button codes....put the 2 batch files you made into your skins directory...
the code for the buttons are:
Code:
B,120,175,250,75,"RunQ;$SKINPATH$\connect.bat",
and
Code:
B,440,174,250,75,"RunQ;$SKINPATH$\disconnect.bat",
that should do it...
x10 is offline   Reply With Quote
Old 07-21-2008, 11:13 PM   #5
x10
x10's Avatar
Quote: Originally Posted by rsrblade View Post
Dougw133 here's what my buddy and I did...
haha...beat me to it...
Old 07-21-2008, 11:23 PM   #6
quick screen shot
Old 07-22-2008, 05:16 PM   #7
Well thanks a lot for all the help! I am going to try these right now.
Old 07-22-2008, 05:57 PM   #8
Alright I have written the Bat Files and allocated the buttons... There is to be two buttons ? Connect and disconnect? I have written the bat files as you stated. My DUN name is "VZW" so that's what I put. The buttons come I know how to do that. Only problem is, Nothing happens...No attempt to dial. Will the DUN window actually open? Thanks
Old 07-22-2008, 06:29 PM   #9
x10
x10's Avatar
You have to have the DUN always dial so to do that:
Open Internet Explorer
Click on Tools and then Internet Options
On the Internet Options window click on the Connections tab
Underneath your connection ("VZW") there will be 3 options:
  • Never dial a connection
  • Dial whenever a network connection is not present
  • Always dial my default connection
Click the radio button next to Always dial my default connection and make sure it says Default next to "VZW"
Then click on Apply and then press OK
As far as showing you a connection screen....I'm almost positive it doesnt. It will just connect "behind the scene"...the only way you'll know if your connected is the Online Status indicator on the skin...DFX3 has it for sure up in the top left of the top window...
Old 07-22-2008, 06:30 PM   #10
Found the problem... One of the files saved as text and not batch... It works great, thanks a lot. This makes this so much easier for me.
Old 07-22-2008, 07:51 PM   #11
Trying an alternate way so I only need one button I created a "sendkey" Script with a vbs file extension. It sneds my chosen hotkey in Sp Dialer and works great. How do I get the button to run the script? I have placed the Script called "Connect(vbs) into the Skin folder. Here's what I tried and it didn't work.
"MyApp49","RunQ;$SKINPATH$\connect.vbs"
Old 07-22-2008, 08:39 PM   #12
tried with and without VBS extension. Nothing yet
Old 07-22-2008, 11:40 PM   #13
barnyard is an unknown quantity at this point
Here is how I made mine work with one button:
add these lines(or similar) to your exectbl.ini:
Code:
"BBCONNECT","RUNq;$RRPATH$\Connect.bat||SETVAR;BBCONNECTED;1||SETIND;!BBCONNECTIONSTATUS;ON" "BBDISCONNECT","RUNq;$RRPATH$\Disconnect.bat||SETVAR;BBCONNECTED;0||SETIND;!BBCONNECTIONSTATUS;OFF"
And your button code would look something like this:
Code:
B,271,182,252,65,"BYVAR;BBCONNECTED;BBCONNECT<<BBDISCONNECT",
I also use an indicator to know when it's connected:
Code:
I,239,178,26,24,"!BBCONNECTIONSTATUS:b"
I know this method may get out of 'sync' because it just toggles, and doesn't actually know the status of the connection... I just don't know how to check to see if the connection was initiated.
VIA EPIA M10000
512 Megs RAM
8" Lilliput
Onstar GPS mod
XM
Visteon HDZ300
barnyard is offline   Reply With Quote
Old 07-22-2008, 11:54 PM   #14
Indicator LED and single button on/off, nice touch!
Old 07-22-2008, 11:54 PM   #15
That's a great idea! Thank you. The one advantage I find using this PS Dialer is it does carry status in a way, audible status. I have wav file that says in a females voice "Connection Established, and "Goodbye" for disconnect. If I push to connect and it doesn't for some reaoson you will not here the wav, and if it disconnects for any reason it will say "Goodbye"
My method might not be the best way but I like it. If only I could get the Script VBS file to run when I push the button. I am missing the right command or something.
Thanks for the post I am going to write one and try it.
Dial up status / Internet Connection Settings Digital Mod sharpmat007 DigitalMods (Scripts / API) 11 07-31-2008 08:47 AM
automatically picking the faster net connection hari-bhari Centrafuse 2 04-25-2007 01:47 PM
Wifi connection detected window Weatherboy General MP3Car Discussion 2 12-11-2004 04:30 PM
How can I get my 802.11 connection to do this? kiztope Wireless Communications 8 07-05-2004 05:18 PM
Wake-up Lan connection Andrew Taylor Newbie 2 03-07-2004 01:44 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
