08-10-2008, 09:10 PM
#31
Raw Wave
with my RR, its impossible to have out of order channels
and what is this log, not from MY VERSION OF RR
there is no 8/5
also, is not having audio ur issue?
u need to tell me about how ur managing audio
prob has NOTHING to do with my RR or Sirius
ok, im heading out for night 1 of fireworks
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
08-10-2008, 09:13 PM
#32
Raw Wave
with my version, they should populate within 30 sec
sounds like you got NO SIGNAL (or really weak), did u do what i said, forget RR.../
use SID (my sirius demo program)
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
08-10-2008, 09:19 PM
#33
I'm just trying to figure out what is going on. I didn't have these issues until I became a tester for the your version. I want to make it clear that I am not blaming your code, because as far as I know, it has worked for others. Like I said, I am just trying to find out what went wrong, as the problems started when I made the switch.
My Car: 2001 Mazda MP3
My OLD Carputer project: Here
Completion Progress Bar: [**********100%]
Current build! Here
Completion Progress Bar: [*********99%]
08-10-2008, 09:21 PM
#34
mitch
I'm going to go try that right now. I am using the Sirius Line-In Plugin to pipe SPDIF audio (via mitchjsALP USB adapter Version 1.2. ).
Current build! Here
08-10-2008, 11:18 PM
#35
I just tried the Sirius Recorder, and no audio. The channels loaded, but no sound. It may be due to the fact that I can't do digital in, at the same time as analog out on my card. This is why I use the Winamp Line-In plug in with RoadRunner. I am unable to figure out what has changed, besides loading the new RR from Mitch. The After that, Sirius didn't work anymore, even though it was working right before I put in the new RR from Mitch. The battery slider ( In Road Runner and the Sirius Recorder) shows both strong Satalite, and Terrestrial Signal.
Another weird thing is that my Sirius channels still show out of order. I even reloaded the Digital FX 3.0 skin, and the channels were still out of order! I am at a loss as to what could be wrong now.
Current build! Here
08-11-2008, 02:52 AM
#36
Raw Wave
duh, try analog audio
and USE SID
not sxrecorder, not anything else..
get it all working with SID (Sirius Interface demo...aka my sirius demo app)
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
08-11-2008, 01:17 PM
#37
I can try that, but I would have to rewire, and change my audio settings in windows... If I'm not mistaken, I think that I may still have the old wire ran, I just have to verify.
Any chance in the future that you may make something that would utilize the Winamp Line-In plugin for those who have soundcards that can't do both Digital In and Analog out at the same time?
Current build! Here
08-11-2008, 02:40 PM
#38
Raw Wave
did i not say forget rr, get your sirius working 1st
i dint change anything in rr, the winamp line in plug in still works
(or it should, if it worked before)
im telling you, that right now, maybe ur sirius is bad... cause you keep saying i get no audio
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
08-11-2008, 02:41 PM
#39
Raw Wave
in sxrecorder, use the audio monitor too... that allows u to listen to and "PIN" on a mixer live
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
08-11-2008, 02:42 PM
#40
Raw Wave
I still need a SIRIUS TESTER
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
08-11-2008, 04:19 PM
#41
mitch
mitch? what is latest build? i have 31st....
also.. you said delete old HDRADIO from rr
when i do this my RR looks for install file over and over and over... dunno maybe you can tell me which folder i need to delete again
08-11-2008, 04:38 PM
#42
Raw Wave
im at 8/7/008
rr doesnt look for install file, its because u set up rr with that MSI installer version, MSI installer sees that "roadrunner.exe" has changed, and wants to repair it
best bet, is cancel, then use the MSI Clean up tool
http://support.microsoft.com/kb/290301
-Thanks
Mitch
www.rush2112.net
within our hearts
08-11-2008, 06:02 PM
#43
Mitch,
Sirius going good so far, the only thing that I have noticed is that when resuming from hibernation the audio does not always comes back. It does work 80% of the time resuming from hibernation but around 20% of the time RR resumes it even appears to load the Sirius because the RR Skin display's what is actually playing at that time I just get no Audio.
My next step is to enable your debugging feature and capture a log when this occurs which I will send to you.
08-11-2008, 07:39 PM
#44
Raw Wave
the odds are u got some audio issue
unrelated
if it comes back and loads channels, its working
u should trace out ur audio issues... like what is managing ur audio
winamp? mixer?
trace audio from the sirius tuner...back to... where ever it goes
-Thanks
Mitch
www.rush2112.net
within our hearts
08-11-2008, 07:51 PM
#45
unrelated
winamp? mixer?
Mitch,
Good Question I have no idea what is managing my Audio I did nothing special I installed Windows XP and Installed RR and the DFX4 skin so it is all default..
but I am sure you are correct that it has nothing to do with your code but rather my configuration.
On another not the new code I have from you loads the channels SUPER fast and has been very stable for me. Thank!
| Thread Tools |
| Display Modes |
Linear Mode
