NEW NEW NEW
http://www.mp3car.com/vbulletin/road...se-update.html
This is It!
Guino, did a wiz of a job merging all my changes/updates to the NEWEST BASE RR CODE (5/27/08). Also There are a few other things fixed.
.NET 2.0 FRAMEWORK ONLY REQUIRED TO USE XM RADIO / SIRIUS RADIO / HD RADIO
--- Changes that are new to this build ---
* FIXED Unimplemented methods in plug-ins
(this fixes the missing sliders!!!!)
* XMComm.dll Changed to remove VB6 TYPE Dependency
* Fixed the dreaded Indicators in plugins BUG!
(a small change of PLUGINS must be done, i have a new example plug in)
(its so small, its basicly changing "false" to "")
* Fixed Silders in plugins!
--- Changes that are from my MJS Builds ----
* Complete rewrite of XM Radio, Sirius Radio
* Partial rewrite of HD Radio
* Changes in last source resuming
I need to update the NOTES, but one thing after installing...
if you got in the "Road Runner" directory a directory called "HD Radio" and/or "XMRadio" you can delete them!!! XM/Sir/HD controll .dlls are now all in "MJS Gadgets" directory.
The file here is a MINI installer, it will backup any existing "Roadrunner.exe", install the new "Roadrunner.exe" +
the OPTIONAL "MJS Gadgets" directory, and automaticly register the required .DLLS
OPTIONAL:
also the "Required skins.zip" file, contains a popup box, unzip and drop the files into your current skin(s). its used to provide error/infomation about XM Radio/Sirius Radio/HD Radio
ALL PLUGINS NEED a SUPER quicky easy update:
I already posted the info in the plugin sub forum
Also Bluezx3 is working on a updated RRConfig, with all the new stuff! (THANK YOU)
people using XM/SIRIUS/HD use this new installer, for XMCOMM is UPDATED!
A snip of the install notes:
XMCache.ini, SRCache.ini, Resume.ini, XMFavs.ini, SRFavs.ini
ALL NEED TO BE ABLE TO WRITE, MAKE SURE NOT SET TO READONLY
ALSO if 1st time using my build... wouldnt hurt to delete all those files and start fresh
there is a bunch of people that really need to be thanked:
Sonicxtacy02, blk02si, GizmoQ,
barnyard, JohnWPB, Dave321
And of course GUINO!
