Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 10-08-2008, 07:18 PM   #1
Kal250 is an unknown quantity at this point
Ebedded Sygic Focus Issue
I am able to embed an run Sygic Drive XP in RoadRunner 9/23/08, however I have noticed that whenever I press a button in the external gps skin (using a modified BMW E36 skin) the sygic app blinks off for just a second then comes back, it is not affecting operation everything still functions it is just annoying, especially when driving and the screen flashes for everyone around to see. Is there a solution for this, a setting or fix that perhaps I have missed?? I am using Drive XP 7.50.514 build 1298. Any help or comments would be appreciated.
BTW I am running Windows XP Pro SP2 with 2 GB RAM, on a D945GCLF2 MB, using the onboard video(Intel 82945G) latest drivers all around
OK NEVERMIND - I Guess I should have read all the FAQS
Quote:
Flashing of Embbeded applications
In most cases, clicking on RR's skin with an embbeded application will cause the application to "flash". The application flashes because RR's window comes up in front of your embbeded application. The way to "fix" this is to clip out that area of RR's window so it does not come up in front of your embbeded application. Once the area is clipped out of RR's skin, that region of the window will not surface above your embbeded application, preventing it from flashing.
The clipping definition must be added in your Application's screen (.skin file). Basically you'll open the .skin file and look for the line that starts with AXX,xxx... copy and paste this line as a new line and change the "A" from the new line to a "C" making it look like CXX,xxx...
Once the clipping definition is in place, it is normal to see "through" the screen while the application loads (in the space where the application will embed). But once the application is loaded, it will not flash when clicking in RR's skin.
will try this out
Last edited by Kal250; 10-09-2008 at 07:16 AM. Reason: I read the FAQ - Thanks Guino
Kal250 is offline   Reply With Quote
No audio after resume from hibernate issue - almost fixed - Help me finish? Trin Software & Software Development 0 07-26-2008 08:35 AM
Another Lilliput issue, Maybe djmickyg LCD/Display 15 05-04-2008 06:29 AM
M4-ATX Power On Issue PacketSniffer Power Supplies 1 04-24-2008 11:00 PM
Generic LCD display, PC TV-OUT issue, all other inputs fine... muxer107 LCD/Display 7 02-21-2008 11:30 AM
.M3U issue "Play all" issue Kimota StreetDeck 0 12-12-2007 10:34 AM
