Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 11-20-2008, 09:07 AM   #61
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Quote: Originally Posted by Sonicxtacy02 View Post
especially now that you can adjust the "cycle clock" for labels n such
Huh?
Where did that come from. <looks to left field, but get's no help from there>
Enforcer is offline   Reply With Quote
Old 11-20-2008, 09:50 AM   #62
brandensin is an unknown quantity at this point
i didn't mean it's slow. I am wondering if it can be faster.. I am also wondering what is "cycle clock"?
brandensin is offline   Reply With Quote
Old 11-20-2008, 09:57 AM   #63
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
what i meant is you can now adjust the rate that the labels/indicators update. before they updated 1/sec essentially. Now you can set your own interval. Check your documentation folder.. the history.txt file. Reads this :
+ Screenrefresh rate control, 10 steps, (.1s to 1 second) 10 = 1 second and is default
+ USER variable: "screenrefresh", default set to 10 (1 second)
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 11-20-2008, 09:59 AM   #64
MGD
MGD's Avatar
MGD is on a distinguished road
You guy's don't know?
This is Cycle Clock.
MGD is offline   Reply With Quote
Old 11-20-2008, 10:38 AM   #65
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
What about once every 4 months the built in browser or a inet control tried to connect to the net if it didnt get a connection directly to your website guino then it would display a cached or local version of your website explaining its freeware etc etc not for commercial use
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 11-20-2008, 12:21 PM   #66
Terminal flasher
dunno if this needs its own thread but i cant get "SETVARBYIND" to set the variable anymore. It worked in old versions. My command is "SETVARBYIND;WEATHERIMAGE;WICON" as debug shows
Code:
11/20/2008 12:04:15 PM: Que Exec: True, menu.skin, "SETVARBYIND;WEATHERIMAGE;WICON||SETFLASHVAR;WEATHERIMAGE;$WEATHERIMAGE$", False 11/20/2008 12:04:15 PM: Executing: SETVARBYIND;WEATHERIMAGE;WICON 11/20/2008 12:04:15 PM: Que Exec: True, menu.skin, "SETFLASHVAR;WEATHERIMAGE;$WEATHERIMAGE$", False 11/20/2008 12:04:15 PM: Executing: SETFLASHVAR;WEATHERIMAGE; 11/20/2008 12:04:15 PM: Leave Exec: False, menu.skin, SETFLASHVAR;WEATHERIMAGE;, False
the indicator is defined in menu.skin. RELOADWEATHER command was run before the SETVAR and the skintool is pulling the file path correctly.
03 Acura RSX Coupe
Old 11-20-2008, 01:31 PM   #67
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Code:
There was a lot re-built with indicators (internally), somehow this got messed up. I've fixed it for next release.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 11-20-2008, 01:37 PM   #68
Terminal flasher
works for me.. thanks!
03 Acura RSX Coupe
Old 11-20-2008, 04:38 PM   #69
Chuck's Avatar
Chuck is on a distinguished road
My OSK will only do caps in this version for some reason.
Anyone else?
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 11-20-2008, 05:31 PM   #70
guino's Avatar
I found the issue with the ONBTNPRESS adition.. it'll be fixed on next build.
Old 11-22-2008, 12:05 AM   #71
AXm77 is on a distinguished road
Guino can you take care of this problem?
AXm77 is offline   Reply With Quote
Old 11-22-2008, 06:08 AM   #72
guino's Avatar
Check your PM
Old 11-23-2008, 07:42 AM   #73
GF-ler's Avatar
GF-ler is on a distinguished road
IS IT SHAMELESS to ask for some more commands and/or changes ???
my wishlist for christmas, so i can make my skins i like to have in my car.
[ironic on] i know i post it again but its my demenz that i forget if anyone gives me an answer.[ironic off]
1)
a single command for RADIO "on/off"
a single command for AUDIO "on/off"
not the way through the "radio_player.skin" or "audio_player.skin" the radiomute didnt work for me.
2)
selection for 5 different backgroundscreens in one skin. if i want to draw a storyboard as skin it would be nice to have different backgrounds.
3)
popups selectable "with/without" backgroundscreen.
4)
backgroundscreen justable like PopUps. "/POSX=, /POSY=, /SHOWWIDTH=, /SHOWHEIGHT="
5)
better quality of fonts in the iList window. now are only some fonts with good quality.
6)
a working "RDSSIGNAL" for the ADS radio too. now it only works "RSIGNAL" in slider showing.
7)
a second radio preset function for station name, delayed readin when button pressed.
8)
a change inside the usbradio.dll for showing the RDSTEXT. selectable for RDSText showing in LINE format or showing in 2 block format.
(the problem of all my ADS sticks is, they only show the RDSTEXT if it selected as 2 blocks).
9)
showing all information of the internet radio. title and station name. (more communication with winamp)
10)
with the command X,xxxxx in the menu.skin i can load a driver or plug. i need a command to unload it.
perhaps its possible to do it with "SELECT" if the skin_browser is showing.
if i change the skin to another one sometimes i get no output. example the plug for the ICERADIO is one of these problems.
11)
i want to start a timer with a pressed button, its not possible because the signal of the button only works with "pulse of button NOT PRESSED"
dont know how you call it in english, but i need the a signal of pressed button also the frontside and all the time i pressed him.
its using for starting a timer, if selected time is ended and button is also pressed....shift data from "a" to "b".
GF-ler is offline   Reply With Quote
Old 11-23-2008, 07:57 AM   #74
Terminal flasher
Quote: Originally Posted by GF-ler View Post
1)
trust me when i say this would require a MAJOR rewrite. I've tried this countless times and i just gave up
03 Acura RSX Coupe
Old 11-23-2008, 02:03 PM   #75
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
Perhaps I'm using it wrong or missing something, but I cannot get inipath= working at all.
I'm running the OS and RR from read only XPE on flash media and having rr.ini on a write-able drive will save settings. No matter what I set inipath= to it still read rr.ini from root.
Maybe a bug or maybe i'm using it wrong, although it seems to be a pretty straight forward option.
blk02si is offline   Reply With Quote
Lsx Void 3.0 liquid_smoke RR Released Skins 3116 11-02-2009 05:41 PM
What Winamp version is everyone using with RR craigt Road Runner 9 09-30-2005 02:42 PM
Release CENTRAFUSE BETA 2 (1.3) veetid Centrafuse 128 08-01-2005 04:13 AM
Any news about my strange problem? RR and Girder slimmegane Road Runner 6 07-11-2005 12:52 PM
News on the 07 version netsuo NeoCar Media Center 14 11-06-2004 10:01 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
