Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 11-17-2008, 08:13 AM   #1
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Arrow RR 11-15-08 ... New Version & News
This is a release thread post since the last version I posted (12/06/07):
Since that version:
-Added MitchJS HD/Sirius/XM Improvements
-Added MitchJS "Touch" on-resume issue fix
-Added MitchJS Last Source Resume
-Added instant debug commands: DEBUGON/OFF
-Added SKIPTODESC command
-Added duplicate settings debug log warning
-Added ActiveSource/ActiveSourceID variables
-Added RTUNE command for radio direct tunning
-Added XMMute/SRMute direct toggle/set commands
-Added extra checks for Background image files
-Added presetspath setting (defaults to RoadRunner\Presets\)
-Added backgroundsspath setting (defaults to RoadRunner\Backgrounds\)
-Added pluginspath setting (defaults to RoadRunner\Plugins\)
-Added defaultbg setting to set default background image of skins
-Added support to dvd_player.skin as alternative for MPC in DVD mode
-Added Support to ONSLDxxxxx events for ALL slider codes
-Added option to disable iLists/DirectX usage
-Added support for Label from slider values
-Added modifier to LOADLIST so it doesn't clear current playlist
-Added Hard-Coded CTRL+ALT+Q Keyboard shortcut to quit RR
-Added PRESETLOAD/PRESETSAVED events (by MitchJS)
-Added Vista Master Volume Control Support (by MitchJS)
-Added ONBTNPRESS and ONBTNHOLD events, for every button
-Fixed Issue with Silabs not starting at last used Frequency
-Fixed Issue with SEARCHFILES when using iLists with no icons
-Fixed Issue with Heading and Status indicator paths/names
-Fixed issue with SEARCHFILES not updating song titles with lazytag=false
-Fixed issue with Indicator codes from extension plugins
-Fixed taskbar so it does not hide durning load, if not set in settings
-Improved background on transparent skins to default to black when no image set
-Improved IMG Definition so it can accept variables
-Improved Ipod Support for Newer models
-Improved SiLabs Radio Support
-Improved Extension Plugin Interface
-Improved BYVAR command to also work with true/false
-Improved GPS/Temp/Volt sensor reading to read even when RR is hidden
-Removed Built-In GPS Gas feature (no longer worked)
Please download it from my site:
http://guino.home.insightbb.com/
There's always more to come.. enjoy it for now,
Guino.
Notes:
-Many thanks to Mitch for heavily contributing to the code and making an installer
-Thanks to Blue for the new config
-Thanks to all the community for the continuing support
-RoadRunner now will check the date when running: it will not run if your date is set BEFORE its release date, or 4 months PAST it's release date -- I know this is a drag, but this is only to ensure nobody loads it on products for distribution without permission. I'm also here to commit on making a monthly update from now on, even if just to update the version.
-The Dimmer function may not work well with iLists on slower machines
-Documentation is updated with all new commands/settings
Some News:
First, I want to ensure everyone that RoadRunner will remain free for personal use, which includes our great Mp3Car community. Next, I want to disclose that I have associated myself with a company in order to build a full CarPC product (Hardware+Software solution) using the code I wrote as its base. I will also ensure everyone that any code contributed to RR along the years was either removed or used WITH permission for being included in the final product. Also, the software in the final product is not being sold, it's a PART of the product and really only works with that set of specific hardware, so there would be no point in selling it separately as-is. Having said that, the sources for the latest versions will be controlled to prevent certain activities from taking place. If you wish to work on the sources (even though the best still is to make extension plug-ins), you can download the previously released sources, make your changes and send them to me so I can merge them in (basically the same it's been along the years). Otherwise, if you're only interested in contributing to this project, you can send me a message and we can talk about accessing the SVN server for RR sources. I know this is a hassle, but it is the only way to protect the best interest of BOTH the community and those investing time and money to keep this project going.
I'll give more details on all of this when the time is right,
Thanks for understanding,
Guino.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Advertisement Sponsored links
Old 11-17-2008, 09:56 AM   #2
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
is the RR installer on your site the same as mitch's installer? Also, is the label from slider value the thing me and mitch have been working on that displays the slider value in flash?
I'm 99% sure it is but i'm just curious. In any event great release and nice to see you back on board guino.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 11-17-2008, 10:06 AM   #3
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
w00t!
Glad to see you back.
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Old 11-17-2008, 10:12 AM   #4
guino's Avatar
The installer is what Mitch built for THIS version (newer than his older one).
The Slider value on labels is for skin display and SDK integration, the flash function is in there as well, but it's a separate thing since flash can't accept variables with ';' in them.
Old 11-17-2008, 10:19 AM   #5
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
great stuff guys hats off to you all involved
carputer1 is offline   Reply With Quote
Old 11-17-2008, 01:40 PM   #6
kpjuk's Avatar
kpjuk is on a distinguished road
nice one Guino, and welcome back.
Good Luck with the project. I hope it provides you with some return for the great work you have done here with RR, ably assisted by too many to mention.
cheers
KPJUK.
M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
kpjuk is offline   Reply With Quote
Old 11-17-2008, 03:24 PM   #7
InfinitiPC's Avatar
InfinitiPC is an unknown quantity at this point
YES! Finally a clean install instead of having to merge tons of updates. Thanks Guino/Mitch/others!
4-month kill date though... really? A big: DO NOT USE THIS COMMERCIALLY splash-screen or something would work just as well. If someone really wanted to remove the expire date it is not too difficult to hack out. All this does is frustrate the good users. Please reconsider a different approach for a future build. I don't want to worry about my CarPC becoming unusable if I forget to update for 6-mo. I also want to be able to setup friends with RR who are not tech-savy enough to update on their own.
-InfinitiPC
InfinitiPC is offline   Reply With Quote
Old 11-17-2008, 03:43 PM   #8
Chuck's Avatar
Chuck is on a distinguished road
Good work Guino
I see XMMute/SRMute are back in after I changed all my skin stuff to line in.
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 11-17-2008, 04:20 PM   #9
Nomader's Avatar
Nomader is on a distinguished road
glad to see you back mate..
by the way why does
"Added Vista Master Volume Control Support (by MitchJS) "
does not work for me
ps..just found the "VistaMixerControl" folder.. volume control works in vista!!!!!
Nomader is offline   Reply With Quote
Old 11-17-2008, 07:54 PM   #10
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
Huh? is that what that means? Something needs to be done to "activate" RR every 4 months?
treetop777 is offline   Reply With Quote
Old 11-17-2008, 07:56 PM   #11
DaveDog's Avatar
DaveDog is on a distinguished road
sure sounds like it, I wonder if updater still works, I'll try it tonight
TruckPC, BoatPC, and CarPC I need a life!
DaveDog is offline   Reply With Quote
Old 11-17-2008, 08:21 PM   #12
Raw Wave
mitchjs is on a distinguished road
chuck, i would NOT use the xmmute/srmute
it could have adverse effects, i removed them on purpose
the muting of the radios, is part of how i manage all 3 radios, xm/sr/hd radio
it might be ok, it might cause a problem with 2 devices being unmuted at one time
so use with caution
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 11-17-2008, 08:24 PM   #13
Raw Wave
guys, dont over think the 4month thing, what it means is guino is gonna give you more updates to RR in the future, its his was of making sure you're up to date, and preventing some people to attempt to SELL RR
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 11-17-2008, 08:25 PM   #14
Raw Wave
updater? whats that, there isnt anything im aware of
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 11-17-2008, 08:26 PM   #15
Raw Wave
when updating you EXISTING install, just use the installer!!!
it wont touch any .ini file
it will update all ur xm/sr image...
it will update any changes to hd/xm/sr objects
and if vista, it will install vista volume control
and all these are OPTIONAL
-Thanks
Mitch
www.rush2112.net
within our hearts
Lsx Void 3.0 liquid_smoke RR Released Skins 3116 11-02-2009 05:41 PM
What Winamp version is everyone using with RR craigt Road Runner 9 09-30-2005 02:42 PM
Release CENTRAFUSE BETA 2 (1.3) veetid Centrafuse 128 08-01-2005 04:13 AM
Any news about my strange problem? RR and Girder slimmegane Road Runner 6 07-11-2005 12:52 PM
News on the 07 version netsuo NeoCar Media Center 14 11-06-2004 10:01 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
