Quote: Originally Posted by
mitchjs
why dont you solve the real problem
get the newest RR to work
use the INSTALLER!!!
I did use the installer, but there are a couple of things holding me back from the new version of RR. One is the four-month issue mentioned in the release thread. I know Guino is going to try to come up with a better solution to that, though.
The other is with respect to XM sound quality. Generally, I think XM's sound quality is pretty lousy. I have improved it a lot using the line-in plugin and a little Winamp DSP called Enhancer. It really brightens the compressed XM signal a lot. Maybe I'm wrong, but isn't the new version of RR using Dotnet for XM? If that's the case I won't get any benefit out of my DSP, which will likely render XM less than satisfying to me. Am I wrong about this?
