Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 12-01-2008, 06:13 PM   #1
bay350z is on a distinguished road
Question Problem with Sirius not loading
I just rebuilt my carpc and loaded the latest if RR and using DigitalFX 4. I got everything working except for Sirius.
When I hit the Sirius button it doesn't do anything. What can I check to why it doesn't do anything?
Same goes for gas prices but I assume it isn't using the new command?
bay350z is offline   Reply With Quote
Advertisement Sponsored links
Old 12-01-2008, 07:20 PM   #2
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enough
Gas prices are available only by plugin now -- check the plugin section. The built-in feature got obsolete and stopped working.
For Sirius, there was an entire re-write and the new code requires .NET installed along with the libraries it uses. I'd suggest you install it all with the installer and it will install what you need automatically.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 12-01-2008, 07:25 PM   #3
I used the exe installer. Is that what you are talking about? I can run it again, I am not sure if it was before or after the 15th of nov. Seems like it is the newer one.
Will the one from http://guino.home.insightbb.com/ work?
Old 12-01-2008, 08:54 PM   #4
Thanks for the help. I ran the update and Sirius worked! I can't go without Sirius. I was having withdrawals.
As far as the GAS prices i extracted the gap zip from the other post and they still do not work. Is in there something in the skin i have to change or ....
I extracted the files to the RR folder, I just thought about it, is there a plugin folder or something? I can't remember?
Old 12-02-2008, 06:57 AM   #5
guino's Avatar
You need to install this plugin for Gas prices:
http://www.mp3car.com/vbulletin/rr-p...4-09-08-a.html
Old 12-02-2008, 11:38 AM   #6
Thanks, so in the case of DigitalFX4 do i need to change the button tag?
Old 12-06-2008, 07:04 PM   #7
maxxell is on a distinguished road
Hey, I have this same problem, but only intermittently. When it happens, I click on the sirius button the home screen, and nothing happens. If I reboot the carputer, that usually fixes it. Any idea what's going on?
A car without turbo is a car with perpetual lag.
My Ride
My New Page
maxxell is offline   Reply With Quote
Old 12-06-2008, 07:11 PM   #8
mitchjs is on a distinguished road
just use the installer, it has newest sirius/hd/xm control classes and other new items, like artwork
(when released)
using the .exe only zip file, u miss out on a bit of new stuff
and could cause problems if you use sirius/xm/hd and more
prob no real good reason NOT to use the installer
it will not overwrite any existing .ini files!
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is online now   Reply With Quote
Virtual Earth cache builder? Or even gps simulator to make it cache? thepunkerguy DigitalMods (Scripts / API) 183 08-28-2008 08:58 PM
Holux GPS Trouble mangus580 StreetDeck 34 11-26-2007 08:56 PM
Strange Sirius problem dima237 General Hardware Discussion 0 11-04-2006 02:37 PM
had an all day (9 hr) problem at work.... wizardPC Off Topic 13 10-20-2005 11:50 AM
Sirius Song name problem -zip- Road Runner 2 09-13-2005 09:20 PM
Powered by vBulletin® Version 3.8.2
Content Relevant URLs by vBSEO 3.3.0
