Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 12-01-2008, 10:12 PM   #1
bay350z is on a distinguished road
GPS Time
When I have GPS time sync enabled it jumps to Feb 08.... Any ideas? Then this causes RR not to run with the new time out. The time is fine, just the date.
Thanks.
bay350z is offline   Reply With Quote
Old 12-01-2008, 10:15 PM   #2
Super Moderator
JohnWPB's Avatar
JohnWPB is a jewel in the roughJohnWPB is a jewel in the roughJohnWPB is a jewel in the rough
Personally I recommend not using GPS time. It has never worked correctly for me or many others.
Front End of Choice: Ride Runner (Is there anything else??? ) & Powered by the DigitalFX 4.0 Skin Available at www.JohnWPB.com
My Fiero Build Thread
JohnWPB is offline   Reply With Quote
Old 12-01-2008, 10:16 PM   #3
Alright, this is the first time I have had an issue with it. But it doesn't matter windows can sync from the internet anyway.
Thanks though, at least I am not the only one.
Old 12-04-2008, 08:17 PM   #4
thwack's Avatar
thwack is on a distinguished road
Just started having a issue with this as well. It almost looks like GPS Time has broken with the latest release as I am using international units which have been working for a long time and with all previous releases.
Now the Day and Month are swapping. My system is set to dd/mm/yyyy and the GPS Time is setting mm/dd/yyyy so today I had it set to 13/4/2008 (I am ahead 9.5hrs so by midday today this will be 12/5/2008). I can confirm that the old versions of Road Runner are working well and that it is not my GPS unit as this is happening with both a u-blox and a Garmin both of which are reporting the correct UTM/UPS time.
I do not have US date settings set in the ini file.
I would love for this to be fixed as I do not have an internet connection in the car and have been relying on the GPS Time to set the clock.
Cheers.
Thwack
PS: It seems that the GPS Time set is before the Time Bomb in the current version as I now get the time set to the incorrect date and then Road Runner exits. Pain in the rear end to have to try and set the date then get Road runner working every time.
Car PC -Jetway J7F2WE2G, 4Gb CF Boot, 32Gb CF Data, 1Gb Ram, M2-ATX PS, 8" 800x600 TS, SiLabs USB Radio, Garmin GPS15L, Ublox SBR-LS DR GPS, Fusion Brain, Multibay Card Reader, Panasonic Slotload DVD+-RW, Custom Fab Steel Case
Car- 1988 Nissan Patrol 4WD
thwack is offline   Reply With Quote
Old 12-05-2008, 04:00 PM   #5
Raw Wave
mitchjs is on a distinguished road
im looking at gpstime right now
as far as I know, No code in this area of RR has changed in quite some time
now, i dont have gps, nor know anything about it
1st, "gpsusadate" is checked, if true, then the format is changed
your PC's timezone must be CORRECT!!
mitch
what does the
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 12-05-2008, 04:08 PM   #6
I will have to play with it some more, now that I have read all the posts. I did check my timezone and that was set. The time is fine, it is just the date. I will that gpsupdate option, maybe that was my problem. I will you all know.
FKA psptibby
Old 12-05-2008, 06:35 PM   #7
EricE is on a distinguished road
I tried using GPS time and it didn't work for me either. It always set the date to 2015 (the time was fine). The time zone for my PC is set correctly.
EricE is offline   Reply With Quote
Old 12-06-2008, 12:02 AM   #8
Raw Wave
maybe u can capture a gpsresponse
starts with
$GPRMC
and paste it here
example
$GPRMC,040302.663,A,3939.7,N,10506.6,W,0.27,358.86 ,200804,,*1A
the date here is, AUG(08), 20th, 2004
20 08 04 DDMMYY
if it comes in MMDDYY, then set gpsusadate=true
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 12-06-2008, 12:11 PM   #9
I changed my GPSUSADate to false and now GPS time works fine.
Old 12-06-2008, 03:16 PM   #10
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Typically if someone has gpsusadate=false and it doesn't work, changing it to true fixes it.
Similarly, if someone has gpsusadate=true and it doesn't work, changing it to false fixes it.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 12-07-2008, 09:25 PM   #11
Yup that did it. Mine works now, I guess in the past I always happen to have the right setting.
FKA psptibby
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
