Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 02-14-2009, 07:01 PM   #46
ws6vert is an unknown quantity at this point
Quote: Originally Posted by dotcom1 View Post
thanks man!
Nvm Dotcom, I fixed it and will update all attachments and README to support sending any commands to Coverjuke. I'll post the part of the README on here as well.
ws6vert is offline   Reply With Quote
Old 02-14-2009, 07:43 PM   #47
CJSend
I have attached a .zip of the CJSend.exe that can be used to send keys to coverjuke.
I also updated the previous attachment with these instructions and the CJSend.exe
CJSend.rar
Instructions:
Add CJSend.exe to your coverjuke directory and make buttons on you skin with the following button codes.
Code:
SENDING KEYS TO COVERJUKE ------------------------- 1. To send a key to coverjuke simply make a button in your skin that executes the key stroke you want to send according to the following list: Note: The following list is based on your coverjuke directory being located in C:\Program Files\Coverjuke. If it in a different location you will have to update the button code with the correct directory. DESC. Button Code --------------------------------------------------------------------------- Next Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{RIGHT}" Prev. Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{LEFT}" Select Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{ENTER}" Skip to Letter "RUN;C:\Program Files\Coverjuke\CJSend.exe|{"letter"}" -- Insert any letter (could even be set to a variable in RR, for quick searching) 1st Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{HOME}" last Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{END}" Randon Album "RUN;C:\Program Files\Coverjuke\CJSend.exe|{SPACE}" Jump Right 10 albums "RUN;C:\Program Files\Coverjuke\CJSend.exe|{PGDN}" Jump Left 10 albums "RUN;C:\Program Files\Coverjuke\CJSend.exe|{PGUP}" Close CoverJuke "RUN;C:\Program Files\Coverjuke\CJSend.exe|{ESC}" *New
Here is a picture of a new skin I made that utilizes the new Sendkey ability.
Old 02-15-2009, 01:35 AM   #48
dotcom1 is an unknown quantity at this point
you'r the best man!!!!
dotcom1 is offline   Reply With Quote
Old 02-15-2009, 01:43 AM   #49
Thanks,
If anyone has problems or questions, just ask away and I will do my best to give an answer
Old 02-16-2009, 05:16 AM   #50
I've got something working thats going to require a whole new thread!
See if you can spot whats new?
xbox
And Coverflow
I'll post up with more details after my tests (actual tests).
(Hint: No more Skinbedder)
Old 02-16-2009, 07:00 AM   #51
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
slider
carputer1 is online now   Reply With Quote
Old 02-16-2009, 12:55 PM   #52
Quote: Originally Posted by carputer1 View Post
slider
Yup, And no more rediculous Skinbedder settings. This is click and go.
Will post all details later.
Old 02-19-2009, 03:00 PM   #53
Old 02-19-2009, 03:10 PM   #54
finished with tests yesterday, I'm going to do some cleanup on the code, and will post up, sorry it's takin' so long.
Old 02-19-2009, 03:40 PM   #55
Old 02-19-2009, 04:42 PM   #56
brandensin is an unknown quantity at this point
Great work ws6vert!!!! Getting it done without skinbedder is big......... Looking forward to it..
brandensin is offline   Reply With Quote
Old 02-20-2009, 01:38 AM   #57
Carputer1, Brandensin, dotcom1, you have PM.
Old 02-20-2009, 02:41 AM   #58
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
My question is "Will one install of coverjuke work with multiple skins, i.e., I use three skins primarily but the old coverjuke had to be unregistered and reregistered for each skin?" - PITA!
I want to install coverjuke in my C:\Program Files\Road Runner\Plugins directory; put the specifics for each skin in the skin.ini; and it work the same for all.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 02-20-2009, 02:44 AM   #59
toxic000 is an unknown quantity at this point
Hi,
can I get also one pm?
If it runs without more skinbedder, I want to also build it into my skin.
Thanks for your work with this great "plugin"!
toxic000 is offline   Reply With Quote
Old 02-20-2009, 03:11 AM   #60
Gizmo: Yeh, I dont see why not, doing a quick beta test with a couple of the other members, and I will post up in the Skins section if everything is working correctly.
Quote:
Hi,
Toxic: Yup, check PM
Coverjuke, (openGL) EL CAMINO RR Plugins 145 02-23-2009 09:15 PM
Embeding AutoEnginuity dnr250 Road Runner 1 11-24-2008 03:04 AM
I need a little help with embeding in CF 1.4 wodie Centrafuse 0 08-02-2005 09:31 AM
embeding in frodo djmickyg FreeDrive 0 06-18-2005 05:22 AM
Embeding CoPilot Live? aoLhaTer GPS 2 06-09-2005 03:45 AM
