Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 01-27-2009, 05:35 AM   #1
alpax is an unknown quantity at this point
RadioSHARK Control Program
Are there any RadioSHARK owners around? Here are some good news for you.
I have found a control program for RadioSHARK, and modified it so it could be used with RoadRunner. It does not require original software and supports both versions of RadioSHARK!
RoadRunner RadioSHARK Control Program Version 1.0
Based on ControlSHARK2 version 0.2.2 by QUEBits
Portions Copyright (c) 2009 APSoft Systems
About
RadioSHARK is a USB AM/FM radio manufactured by Griffin Technology.
The radio simply streams audio to USB, so any program, which can
handle different audio input devices can be used to play it, for
example VLC, Media Player Classic, or Winamp with LineIn plug-in.
Just select radioSHARK device as the input in those players.
This control program allows changing frequencies on RadioSHARK either
from command line, GUI or by receiving messages from RoadRunner.
Both radioSHARK and radioSHARK 2 are supported.
Command line parameters:
/fm 101.1 - tune to 101.1 MHz FM
/am 730 - tune to 730 kHz AM
The original ControlSHARK1 and ControlSHARK2 programs were created
by QUEBits (http://www.geocities.jp/ne533/shark001.htm). Thanks a lot
to that guy from Japan who decrypted the radioSHARK communication
protocol, created a program to control the device, and made the source
code available!
Installation for RoadRunner
RadioSHARK Control Program can work with RoadRunner using the
communication method originally designed for HQCT radio, which is
natively supported by RoadRunner (that is why the EXE name is
RRHQCT.exe).
So to make it work you need to do these steps:
1. Copy RRHQCT.exe file from this archive to the existing
\RoadRunner\HQCT folder (none of the files there are required for
RadioSHARK, so you can just delete them or move somewhere else).
2. Run RRConfig.exe, and in Radio Settings select HQCT and enable
"Use Line-In Plugin" option.
Or you can just manually edit the following settings in rr.ini:
[Radio]
radiomode=4
uselineinplugin=true
lineinpar=line://title=Radio,srate=44100,bps=16,nch=2
Of course you also need to install the LineIn input plug-in for Winamp
if you didn't do it before.
Restart RoadRunner, open Radio screen and enjoy your AM/FM radio with
RadioSHARK!
Added on Feb 11, 2009:
Note: If you don't hear radio with Winamp/LineIn plug-in, you may need to open Sounds and Audio Devices Properties in Windows Control Panel, and select radioSHARK as default sound recording device.
alpax is offline   Reply With Quote
Old 01-27-2009, 09:26 AM   #2
pcpete's Avatar
pcpete is on a distinguished road
I would of jumped on this a year ago, as I had a radioshark, but I've since moved on to a visteon HD radio module.
I had bad reception with the RadioShark (i think i had v2) , the visteon works great, and I was able to plug it in to my cars antenna cable. How's your reception...?
pcpete is offline   Reply With Quote
Old 01-27-2009, 01:50 PM   #3
Yes, it's a bit late. RadioSHARK is not even offered on Griffin's website anymore (though it's still there, I believe).
Well, I am only on the first stage - reading, exploring, preparing components, trying different software at home...
I have radioSHARK2, and its reception inside my house near computer is not excellent, but passable. I can tune to all major stations we have here, even AM sounds quite well. It seems to be a bit better with an external antenna, so I hope I'll be able to use it in the car.
Oh, and one thing I didn't mention in my first post.
If someone has the original radioSHARK ver.1 (the white one) - can you please try this software and let me know. It should work, but I didn't have a chance to try it myself.
Thanks!
Old 01-27-2009, 02:26 PM   #4
pcpete's Avatar
My FM was passable, but AM was terrible, and I really wanted mostly AM, for news and sports talk...the visteon is like having my oem radio back...don't want to trash the shark too much, hope it works for you...
Old 01-27-2009, 02:54 PM   #5
Yes, I need mostly AM too - that's why I've chosen radioSHARK, and not some other USB FM radio. I basically need just one AM station - our local traffic radio, and it works just fine (at least at home), another news station is also OK - not worse than FM. I guess I'm just lucky that the signal in our area is strong enough.
I thought I'd give radioSHARK a try first - just need some stub for the radio, as I'm planning to remove the stock unit (it's just too big - 2-DIN), but don't want to lose AM/FM completely.
If it won't work for me, I'll switch to something else. I'll keep that Visteon in mind - thanks for mentioning it.
Old 02-05-2009, 10:27 AM   #6
RedMeanie is an unknown quantity at this point
Sure...
I will get a white one off eBay and try it....I was going to give it a shot to have AM available anyway for Baseball season. The rest of my radio time is spent on XM....I will put trying it within about a week when it gets here...
Thanks!
RedMeanie is offline   Reply With Quote
Old 02-05-2009, 11:59 AM   #7
Thanks in advance, RedMeanie! Please let me know about any result or if you'll have any questions.
Old 02-11-2009, 08:47 PM   #8
T_Blaze is an unknown quantity at this point
I tried it and can't seem to control anything in RR. The file opens up outside of RR but seems to not be embedded in RR
T_Blaze is offline   Reply With Quote
Old 02-12-2009, 12:27 AM   #9
Ha! You know what? I didn't use the radio for a while, and now have found that it stopped working on my machine too!
But I've figured out one step I did before, but completely forgot and didn't mention in the readme.
You need to open Sounds and Audio Devices Properties in Windows Control Panel, and select radioSHARK as default sound recording device.
After that everything should work as described above.
Please note the control program does not embed into RR - it just provides the frequency switching functionality - that's why it starts minimized - its UI is not supposed to be used in normal conditions. You use RR & skin screens to select radio stations.
BTW, what version of RadioSHARK do you have - v1 (white) or v2 (black)?
Old 02-12-2009, 06:38 AM   #10
Raw Wave
mitchjs is on a distinguished road
dont wait too long, there is a bunch of Directed dmhd1000s on ebay now
for cheap!!!!
once they gone they gone, both units have been out of production for some time (directed/visteon) + i prob wont produce cables much longer
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 02-12-2009, 09:28 AM   #11
i have the black one (v2).... will try and see if it works... thanks
Old 02-12-2009, 05:33 PM   #12
It didn't work for me. Outside of RR the program opens up but could not control inside RR. For some reason, I can't even switched to FM in RR. It's stuck on AM.
Old 02-12-2009, 06:57 PM   #13
But does it work outside of RR?
Let's go step by step...
Have you selected radioSHARK as default sound recording device?
Do you have Line-In plug-in for Winamp installed and set up?
Open Winamp, right-click, select Play - URL..., enter line:// there, and press Open. It should play radio.
Then start this RRHQCT.exe, open its window, and try to change frequencies and press FM and AM buttons.
If it works, the radio itself is ready to go.
Now, let's see what's up with your RR settings.
Have you selected HQCT in RR Radio Settings and enabled "Use Line-In Plugin" option as described in readme?
And finally, what skin are you using? Note - the skin must support radio properly. For example, it works fine with BMWE36, BMV2 and Carwings-V2, though it's called HD Radio in Carwings, and there is no AM/FM switch in the latter two - you just enter the frequency and if it's out of FM range, it just switches to AM.
Old 02-12-2009, 10:37 PM   #14
Yes
Do you mean the volume control?
Will do tomorrow morning
Yes
DFX 4.0
Just to clarify, the radio itself works outside RR. Maybe the skin just doesn't support it?
Old 02-13-2009, 01:28 AM   #15
I mean this plug-in. I don't remember if I did any special setup for it. Just make sure you see radioSHARK in the list of devices in LineIn plugin configuration window, and when you open "line://" URL in Winamp it actually plays radio.
Please note: it should work in Winamp - not in the standard RadioSHARK application, which comes with the device.
I don't really know. I've just downloaded and tried DFX, but it is so complicated that I could not even add the Radio button to its menu.
But I believe it should work, if you set up Winamp and RR properly.
Anyway, try some simpler screen first - one of those I mentioned.
RadioSHARK v1 is now native to RR. Evolution VIII Road Runner 39 05-04-2008 12:45 AM
For those of you using the RadioShark clinte Car Audio 0 10-19-2005 02:27 PM
radioShark am/fm usb adapter with timeshifting kickerks80 Car Audio 13 10-04-2004 05:08 PM
My hardware/Software computer control system - Wish list/feedback - Easy power off DarkWolf General Hardware Discussion 22 08-13-2001 02:42 PM
Can someone write me a PIC program 4 a awesome s/down controller please? gizmos General Hardware Discussion 3 07-17-2000 01:43 PM
