Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 02-14-2009, 12:50 PM   #1
One Sharp Cheddar
ThunderStick's Avatar
ThunderStick is on a distinguished road
Question iLists not working
The ilists are not working. The playlist shows but will not scroll.
What am I doing wrong?
using NEW RR, Tried with Carwings and New Age Garmin
Any help is appreciated...
ThunderStick is offline   Reply With Quote
Advertisement Sponsored links
Old 02-14-2009, 12:50 PM   #2
One Sharp Cheddar
Using the newest version of Ride Runner
Old 02-14-2009, 01:15 PM   #3
One Sharp Cheddar
Direct X installed and USEDX=True in RR.ini... Searched couldnt find much else..
Old 02-14-2009, 03:30 PM   #4
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
can you make a debug log ? it should say something in it if it can't start DirectX..
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 02-14-2009, 03:52 PM   #5
One Sharp Cheddar
attached is the debug.txt
thanks for the help
Old 02-14-2009, 03:58 PM   #6
brandensin is an unknown quantity at this point
might wanna look into this,
http://www.mp3car.com/vbulletin/road...rr-freeze.html
brandensin is offline   Reply With Quote
Old 02-14-2009, 04:15 PM   #7
guino's Avatar
"E"rror on InitDX: -2005532109 Automation error" -- there's definitely some missing component.. check that thread above... the DX7VB.DLL is installed with the installshield -- if you used it, in which case you may want to consider update/upgrade your DirectX install.
Old 02-14-2009, 09:22 PM   #8
Raw Wave
mitchjs is on a distinguished road
thunder, i assume u used the installer?
grab latest dx from microsoft
and use the RideRunner installer
mitch
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 02-14-2009, 11:52 PM   #9
One Sharp Cheddar
DX is definitely up to date. DL'd latest of MS website after I started having the problem. I will Reinstall RR and try that.
Old 02-15-2009, 12:20 AM   #10
One Sharp Cheddar
Reinstalled RR, ilists still not working in any skin. Carwings or New Age... reaching out for idea...
Here is a new Debug if it helps.
Old 02-15-2009, 12:27 AM   #11
One Sharp Cheddar
after running the DXDIAG test everything seems to check out fine with DX. Checked if DX7VB.DLL is installed and it is.
Old 02-15-2009, 07:29 PM   #12
guino's Avatar
Can you try "regsvr32 dx7vb.dll" to see ? Something is definitely wrong when trying to initialize DirectX ... question is what exactly..
Old 02-15-2009, 09:03 PM   #13
Raw Wave
video card drivers maybe?
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 02-15-2009, 09:40 PM   #14
One Sharp Cheddar
Just reg'd dx again, no go.
This all happened after I used some screen capture software. Let me work on this some and Ill get back to ya'll
thanks for the help.
Old 02-15-2009, 09:44 PM   #15
One Sharp Cheddar
OK now I feel like a moran, it was the screen capture software. It has a setting to disable or enable direct X for capturing. Well it disabled it. Enabled it and guess what, it works now.
Sorry for the trouble...
EniCar the RR Clone enitalp Software & Software Development 296 12-13-2008 06:12 PM
problems with navigation in streetdeck customaudioman StreetDeck 3 01-25-2008 01:46 PM
Working skin for MS Streets and Trips embedded in RR HyperSprite RR Skins 26 05-02-2007 12:52 PM
pink transparency not working if skin is resized by RR liquid_smoke RR Bug Tracker 3 02-06-2006 01:23 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
