I haven't been able to get Ride Runner to run correctly after using the new install. The splashscreen for my skin shows then I just get a thin black line on the screen. I can see that RR is running on the task list. Any ideas?
Sounds like a rr.ini setting changed like fastmode=-1 (switched to something else).
I checked and fastmode is set to -1. I tried 0 and 1 but neither worked. I've attached a screenshot and the debug output if that's helpful. Thanks for the help.
is that path right to ur skin? is menu skin images there? (likely not, since u got the ERROR..)
let me guess u install dfx4 and its in "Road Runner" Dir (just a guess)
The path is correct and the skin images are there (menu_OFF.png, menu_ON.png). Is it possible there is some dll that isn't registered correctly or something? I am getting the same error with the default carwings skin. Also, when I goto my old Road Runner directory and try to run I get that same problem, even though it was working prior to the install.
actualy that error can be GENERATED from alot of different reasons
if a bitmap fails to create
which if fastmode = -1, could be GDI issue
which there is gdi, dlls
you did use the installer right?
if so that dll would be registered
GDIPlusWrapper.dll
AND u have to have GDI+ on ur system, which it IS in normal XP
but if u "lite"d the os...
Mitch you are a genius! I ran regsvr32 on GDIPlusWrapper.dll and now its working. I did run the installer so not sure why it didn't work correctly. Anyway, thanks for the help.
yes, i was about to post
i unregged my wrapper
and it did the same
i dont see how the registration failed, if u used the installer
unless U RAN the uninstall on another directory!!!!
like u installed it twice, then uninstalled one of them!!!
that would cause the .dll to be unregged!!!
mitch
Sorry I didn't realize my post was moved. I only installed once. My old roadrunner "install" wasn't from an install but rather an xcopy so I never did an uninstall. Not sure how it got into that weird state...
