Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 04-24-2009, 02:02 AM   #1
pcpete's Avatar
pcpete is on a distinguished road
Can't autorun command in skin file
If i enter this in my audio_browser skin and press the button it works...
B,305,0,90,60,"SEARCHFILES;folder.jpg"
What I want is NOT to have to press a button but have the command autorun each time the skin file loads...
I tried just entering...
but this doesn't do anything...
Skin gurus, please enlighten me....
pcpete is offline   Reply With Quote
Old 04-24-2009, 02:22 AM   #2
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
"LIST||SEARCHFILES;folder.jpg"
or in flash
fscommand("LIST")
fscommand("SEARCHFILES;folder.jpg")
also not sure but maybe "ONSCREENCHANGE"
EL CAMINO is offline   Reply With Quote
Old 04-24-2009, 07:29 AM   #3
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
Yep, could use the
"ONSCREENCHANGE","LIST||SEARCHFILES;folder.jpg",xx .skin (skinfile name on then end)
will only run after that screen is loaded, everytime.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 04-24-2009, 07:52 AM   #4
pcpete's Avatar
Thx guys, will give them a try ...
Old 04-24-2009, 09:49 AM   #5
pcpete's Avatar
OK, got this to work by putting it in exectbl.ini..
"ONSCREENCHANGE","SEARCHFILES;folder.jpg",covers.s kin
Now I'm having another issue...The larger picture is I want to import a list of folder.jpg paths into flash. I've got it somewhat working using CUSTOMDL.
Originally I issued the searchfiles command from flash ,like this...
fscommand("SEARCHFILES;folder.jpg");
//fscommand("WAITEXEC");
fscommand("GETDL","");
This gets me what I want into flash....but I'm having a timing issue though, flash continues executing commands while the search is going on, as you can see I tried the "WAITEXEC" command, but that hangs the screen skin.
Thats why I was hoping to run the search in RR, do a WAIT;5 then load the swf.
The 5 second delay doesn't happen, the swf loads up right away...is this broken?
I know the search is working and CUSTOMDL does get the populated with the paths...I have a button in my swf that also issues fscommand("GETDL","").
On another note , why is GETDL needed? all my other lables auto update.
Thx for any help or suggestions..
Old 04-24-2009, 09:53 AM   #6
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
You can create a check loop in flash with a variable that RR sets to acheive what you are looking for
change RR's command to
fscommand("SETFLASHVAR;COMMANDCOMPLETE;TRUE")
then check for _root.COMMANDCOMPLETE. If true then perform your flash stuff... then set _root.COMMANDCOMPLETE to false.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 04-24-2009, 10:23 AM   #7
pcpete's Avatar
Thx Sonic, will give this a shot and report back....
RockCar Front End v0.0.154 - Skin Editor Updates Hessian Software & Software Development 1 11-21-2008 11:40 PM
hAv1c and hAv1cPlus Skin release - 800 x 480 (Transparency, custom font color) monkeyracer RR Skins 65 07-23-2008 03:03 AM
Set label on a skin from an .ini file jumbodogs Road Runner 15 05-02-2008 02:41 PM
The KEY tag in skin file GuMiSZu Road Runner 0 05-10-2007 04:37 AM
Tutorial for installing pycar on Linux kbyrd PyCar 18 11-01-2006 01:59 PM
