06-07-2009, 11:56 AM
#1
Help With Sendkey Command And AutoHotKey
Hi
i need some help with the sendkey command to autohotkey
i tried using "Sendkey;{F12}" for example ( keytbl also defined as well )
but the button isn't working
i tried searching here and found that you need to get focus but autohotkey works everywhere ( if i press the key inside rr on an actual keyboard it works perfectly )
what am i doing wrong?
*i also tried kanakey but it doesn't work either
btw i have a problem with skin transitions
it works very very slow
the pc is very strong :
amd 5050e dual core
onboard ati radeon hd3200
2gb ddr2
latest flash
latest rr version
everything else works like charm ( even 3d visual on winamp )
what could be the problem?
thanks in advance ,
nimikipod
06-08-2009, 02:50 PM
#2
Hi Nimikipod,
have you tried to activate the screen/app you want to send the key to first?
How do I use SENDKEY
If I want to make the buttons for embedded applications so that they look like they belong in my skin, how do I do that?
You can communicate with embedded applications using the SENDKEY command. You make the buttons in your skin with the standard button commands, and then use SENDKEY to send commands to your application. Here is an extract of my GPS skin which I embed Infomap Navigator into.
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B01,-1,-2,56,68,"ACTIVATE;Navigator||SENDKEY;{F5}","Zoom In"
B02,51,-1,51,67,"ACTIVATE;Navigator||SENDKEY;{F6}","Zoom In"
B03,101,-1,102,67,"ACTIVATE;Navigator||SENDKEY;%V{RIGHT}I%V {RIGHT}O","Fullscreen Toggle"
B04,201,-1,100,67,"ACTIVATE;Navigator||SENDKEY;%T{DOWN}{DOW N}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN} {DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{RIGHT}{ENTER} ","Exit"
B05,301,0,101,65,"ACTIVATE;Navigator||SENDKEY;%T{D OWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOW N}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{RIGHT }{DOWN}{DOWN}{DOWN}{ENTER}","Exit"
B06,402,0,100,65,"ACTIVATE;Navigator||SENDKEY;%T{D OWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOW N}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{DOWN}{RIGHT }C","Exit"
B07,500,0,101,65,"ACTIVATE;Navigator||SENDKEY;{F7} ","Exit"
B08,601,1,99,64,"MENU;Audio_Menu.skin",
B08,700,1,99,64,"EXIT","Exit"
cheers
KPJUK
M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
06-09-2009, 07:40 AM
#3
RoadRunner Mastermind
I don't believe sendkeys will work to simulate it for autohotkey, but if you tell us what you're trying to do in autohotkey (by pressing F12), we may be able to tell you how to do that in RR. Otherwise, you may need to find a way to perform the autohotkey function you want by command line parameters (using the RUN command in RR).
Ride Runner RR's Myspace
06-09-2009, 11:08 AM
#4
i wrote the message for nimikipod - im helping him with his carpc
kpjuk - i can't activate the window because autohotkey works from tray with no window..
guino - we have made a script which changes the mute state of 2 recording lines from the onboard soundcard
he is using an asus pci card as a sound source
but also using the onboard sound device for hqct and mic ( for phone control )
one is using line-in port
the other is using microphone port
but when you use winamp linein plugin you get both
so basicly what the script from autohotkey does is mute one and unmute the other
for example -
one press - line-in muted , microphone unmuted
press again - line-in unmuted , microphone muted
is it possible to do this inside rr?
thanks
HeadUnit : Car-Pc | Processor : Soundblaster Audigy 2 ZS | Front Stage : Woofer - Mpyre 65M , Mid - Dayton RS100-4 , Tweeter - Hertz HT-25 | Subwoofer : Hertz HX250D | Amps : A/D/S PQ10 , Hifonics Olympus XI | Wiring : Sommer , Neutrik
06-09-2009, 04:58 PM
#5
RR can mute/unmute sources only, not inputs, but if there's a way to execute the same script with a command line parameter to autohotkey then it should be easy to use the RUN command instead of the F12 keypress. There are also a few command line volume control tools that could do the trick.
06-11-2009, 07:46 AM
#6
got it
i downloaded a little prog called volumeline
hope this will do the job
thanks
08-30-2009, 02:21 AM
#7
sendkey right-mouse-button?
Hey Guino,
I'm trying to send a right-mouse-click to my embedded application, but I can't figure it out.
I've tried numerous things, including:
B08,109,438,93,70,"ACTIVATE;MyApplication||SENDKEY ;{F11}", (no space after SENDKEY, forum modified the post...)
where the right mouse button is mapped to F11 via AutoHotkey.
I also tried:
B08,109,438,93,70,"ACTIVATE;MyApplication||SENDKEY ;{+F10}", (same here)
What am I doing wrong/is it possible?
(Thanks Guino, you rock, RR is the best!)
Reason: forum modified my text
08-30-2009, 11:00 AM
#8
It is currently not possible to simulate mouse clicks in RR, but I have thought of making an extension plugin for that for a long time.. for right now, I'd suggest looking for a command line parameter to autohotkey that can execute the F11 command, or trying to activate autohotkey (instead of your application) to simulate it.
08-31-2009, 02:48 AM
#9
Thanks Guino,
I was able to get Autohotkey to fire the "Click right x,y" and close...and I didn't realize putting the mouse in the app window was necessary at first. If you do ever write the plugin I'll be grateful...there's a measureable delay between hitting the button and the right-click, but it gets the job done!
Thanks again for the continued goodness!
p.s. any thoughts of how multi-touch might change things? I bet those touchscreens are coming soon... 8-D
09-26-2009, 02:49 PM
#10
Quote: Originally Posted by flat6
Thanks Guino,
Why cant you add a line to make the window active first so you dont have to hover the mouse anywhere.... AutoHotKey comes with a example script that opens Notepad on Ctrl+Alt+Del
Eample:
^!n::
IfWinExist Untitled - Notepad
WinActivate
else
Run Notepad
return
Hopefully that will make it a little more convenient.
| Thread Tools |
| Display Modes |
Linear Mode
