06-18-2009, 10:52 AM
#1
One Sharp Cheddar
RR and Garmin Trouble
I am having a hell of time getting garmin to stay on top when embedded in RR.
I have my window name set to Garmin Mobile PC and have also tried CDP_WND_FIELD
nothing seems to keep Garmin on top of RR when I press a play button or try to overlay the OSK.
Wht the hell am I doing wrong...this used to work great...
Dummy problem.. read last post
06-18-2009, 12:29 PM
#2
Contrary to other applications, Garmin mobile PC create a new window each time you change screens. So, it means RR probably make the first screen topmost, but if you switch the screen by pressing the settings button for example, a new window handle is created, so RR don't make it topmost. I have seen this problem as I am in the process to disable the exit and minimize button for my own interface I am building and I had to hook the click on these buttons and I have to reapply the hook each time another screen is shown.
06-19-2009, 09:53 AM
#3
One Sharp Cheddar
I did have this trouble in the past though. When I made the overlay for the OSK it worked great.
Is anyone else having this trouble?
06-19-2009, 04:29 PM
#4
i'm using GMPC all the time with RR v10.10.08 and it embeds great - no issues changing screens ...
06-19-2009, 09:31 PM
#5
One Sharp Cheddar
THat's probably it. I am using the latest RR. 6.01.09
LIke I said it has worked great in the past up until recently
06-20-2009, 01:11 AM
#6
Raw Wave
no changes to anything related to embedding apps.... that im aware of... its not roadrunner vs riderunner
are u using the built in dimmer??? if so, turn if off..and see
(prob not, but worth mentioning)
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
06-20-2009, 11:04 AM
#7
One Sharp Cheddar
Seriously though, that is the only change to my setup in a long time (rr version change). Probably over a year.
06-20-2009, 11:08 AM
#8
One Sharp Cheddar
Now when in the external_gps.skin if I click on music control buttons at the top of the screen GMPC ends up behind RR, but if I go back to the main menu then back to the external GPS screen then it reappears.
Same with trying to use the overlay plugin. If I try to overlay the OSK on top of GMPC then I lose GMPC.
06-20-2009, 11:09 AM
#9
One Sharp Cheddar
Sorry one last post, I have tried this on three different PCs. My desktop, a PC with a fresh install of windows and my carpc.
Same issue on all 3.
06-20-2009, 03:36 PM
#10
Raw Wave
are u using the GMPC overy script??? (ElcosMenu.exe)
that runs outside of rr you know
why not post some screen shots, since im a bit lost
like i dont know what "music control buttons at the top of the screen GMPC" really means...
maybe put a example .skin to gether for me
you know, i downloaded GMPC setup as trial...
set GMPC on Carwings overlay works... kinda...
its a bit buggy... prob needs work
specially cause it might be looking for roadrunner windows
and maybe slipping past the compatibilty.ex
i might need to set it up in skin ur using...
-Thanks
Mitch
www.rush2112.net
within our hearts
06-20-2009, 07:27 PM
#11
Are you using this ?
I have it working with the latest RR and LSXVoid 3. Haven't tried any other skins though.
06-20-2009, 08:10 PM
#12
One Sharp Cheddar
Here is a vid clip of what is happening.
Press the OSK button then press it again to close the OSK, OSK dissappears and so does Garmin.
At the end of the vid I pressed the next track button at the top and GMPC dissapears.
The buttons at the top are part of RR, not the overlay.
06-20-2009, 08:14 PM
#13
One Sharp Cheddar
OH yeah, yes I am using elcomenu for the overlay. I know this is not part of RR. But it still screws up when just trying to press a button outside of the application window.
06-20-2009, 08:22 PM
#14
One Sharp Cheddar
Wow do I feel dumb now....
Sorry for the trouble.
I was missing the application frame in the skin...
DUMB DUMB DUMB...
06-21-2009, 01:09 AM
#15
Raw Wave
DING!
i was gonna ask for the skin file u know
looks nice btw
mitch
-Thanks
Mitch
www.rush2112.net
within our hearts
| Thread Tools |
| Display Modes |
Linear Mode
