Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 07-16-2009, 11:10 PM   #1
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
music defaults to first song on open
so, like the title says, almost everytime i open rr, it will default to teh first song of ehat ever playlist i am using.
I know i need to use the RRresume plugin, but i cant seem to figute out how to get it to work.
i have downloaded and registered(at least i think i did) RRextended, but debug.txt says that it is not able to allow the plugin to be enabled.
Code:
7/16/2009 9:47:40 PM: PLAYER: Winamp Version: 5.13 7/16/2009 9:47:40 PM: DirectDraw Count: 1 - [] 7/16/2009 9:47:40 PM: No Phidgets interface detected. 7/16/2009 9:47:40 PM: Plugin Manager: loading Global Plugins... 7/16/2009 9:47:40 PM: Plugin Manager: Plugin Found: RRExtended 7/16/2009 9:47:40 PM: Plugin Manager: Warning Plugin RRExtended does not support Enabled Method 7/16/2009 9:47:40 PM: Plugin Manager: Plugin loaded (Global): RRExtended 7/16/2009 9:47:40 PM: Plugin Manager: Plugin Found: SkinTool 7/16/2009 9:47:40 PM: Plugin Manager: Warning Plugin SkinTool does not support Enabled Method 7/16/2009 9:47:40 PM: Plugin Manager: Plugin loaded (Global): SkinTool 7/16/2009 9:47:40 PM: Plugin Manager: loading Global Plugins Completed. 7/16/2009 9:47:40 PM: LoadSkin: C:\Program Files\Road Runner\Skins\DigitalFX 4.0\ 7/16/2009 9:47:40 PM: Plugin Manager: loading SkinDir Plugins... 7/16/2009 9:47:40 PM: Plugin Manager: loading SkinDir Plugins Completed. 7/16/2009 9:47:41 PM: Plugin Manager: Error loading (menu.skin): MOTIONLOCK (ActiveX component can't create object, check spelling of plugin, or its is COM registration missing.) 7/16/2009 9:47:41 PM: Plugin Manager: Warning Plugin MOVIETIMES does not support Enabled Method 7/16/2009 9:47:41 PM: Plugin Manager: Warning Plugin MOVIETIMES does not support Initialize Method 7/16/2009 9:47:41 PM: Plugin Manager: Plugin loaded (menu.skin): MOVIETIMES 7/16/2009 9:47:41 PM: Plugin Manager: Warning loading SKINTOOL (Attempt load more then once, most likely duped in globals and/or in skin). 7/16/2009 9:47:42 PM: Plugin Manager: Warning Plugin RRMEDIADB does not support Enabled Method 7/16/2009 9:47:42 PM: Plugin Manager: Warning Plugin RRMEDIADB does not support Initialize Method 7/16/2009 9:47:42 PM: Plugin Manager: Plugin loaded (menu.skin): RRMEDIADB 7/16/2009 9:47:43 PM: CheckResume: ResumeMusic=1 WasRadio=0 7/16/2009 9:47:43 PM: Enter Exec: False, menu.skin, , False 7/16/2009 9:47:43 PM: Que Exec: True, menu.skin,
what am i doing wrong?
soundman98 is offline   Reply With Quote
Old 07-17-2009, 01:25 AM   #2
THE EXPERIMENTER
carputer1's Avatar
carputer1 will become famous soon enough
according to your scr cap there rrextended is reg'ed and loaded, but at a guess open rrconfig go to music /page2, resume mode bottom right set to always, or open rr.ini in notepad and go to music section and change the resumemusic=2,, start rr then close it then open gain and it should work for you.
this should on rr start resume the track you was last playing, without the useing rrextended,
Links
Author of Ranger skin
Ford Ranger Truck Rebuild and system install Worklog
Current project status
Ranger Truck Rebuild 70% Current Open Project
Ranger Update:30% Total RE-WRITE
Ranger Help File:10%
Ride Runner Help File 30%
carputer1 is offline   Reply With Quote
Old 11-04-2009, 01:43 PM   #3
soundman98's Avatar
ok, bumping this thread again...
carputer1, your suggestion did work at the time, but then a month later i had to update, and it has not worked since the update. i figure i am nearing the time for another update, so i am searching for a solution that will work.
currently, my computer is set to do a full shutdown/startup(i have had issues hibernating with my audio processing program), and rr will always default to the first song in the playlist whenever i allow the computer to exit rr as it's shutting down.
i have setup RResumer, but it does not seem to do anything except when my computer BSOD's, then it will resume the correct song
my current workaround: if i first exit rr, and then shut down, it saves the last song position.
i have attached my rr config, and the rrdbug file.
Old 11-04-2009, 04:55 PM   #4
Raw Wave
mitchjs is on a distinguished road
i have no idea what ur trying to accomplish!!!
but this is bad
: Executing: RunQ;C:\Program Files\RideRunner\Skins\DigitalFX 4.0\scripts\Kill_Task.exe|winamp.exe
11/4/2009 12:02:08 PM: Shell: "C:\Program Files\RideRunner\Skins\DigitalFX 4.0\scripts\Kill_Task.exe" winamp.exe
11/4/2009 12:02:08 PM: Que Exec: True, exit_menu.skin, "QUIT", False
NO REASON TO KILL THE TASK!
killing it will affect RR from the ability to see what the last track was playing
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 11-04-2009, 04:56 PM   #5
Raw Wave
and you dont need RRresume
did u try carwings
dfx4 is a massive skin
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 11-05-2009, 08:27 AM   #6
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
I would HIGHLY suggest to TRY carwings WITHOUT any resume plugin installed, just set resumemusic=2 and it should work, if not, post a debug log running carwings.
Once it works on carwings, it should work on any skin (unless the skin itself is messing with the playlist or player save/resume features)
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 11-05-2009, 09:06 AM   #7
soundman98's Avatar
ok thanks
Old 11-05-2009, 11:15 AM   #8
Raw Wave
its that winamp task kill, remove that
not even sure why it would be in ANY skin
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 11-12-2009, 12:33 AM   #9
HoffR1 is an unknown quantity at this point
mitchjs, how would you remove that? I'm having what I think is the same problem with the dfx4.0 skin, RR (or winamp) does not remember which track I was last playing, so it always starts at the first track on the playlist. I don't want it to actually start playing the song when it opens, but I would like it to remember which track it was on.
I'm running RR with the dfx4.0 skin, winamp 5.13. I can post the debug.txt if wanted, but I expect the relevant lines are the ones regarding the kill_task.exe, which is the same in my debug file as for his.
The part that's really bugging me is I recently had to reinstall everything for a hard drive failure. And I don't recall this issue happening before, but as far as I can tell, none of the settings are different on this install
HoffR1 is offline   Reply With Quote
Old 11-12-2009, 12:48 AM   #10
Raw Wave
im not familiar enough with that skin, but its prob in the exectbl.ini file in the kin dir
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 11-12-2009, 12:51 AM   #11
You refer to this line I assume?
"KillWinamp","RunQ;$skinpath$scripts\Kill_Task.exe |winamp.exe"
Is there a way to change that to make it run the proper command to end the program rather than killing it? It's not a huge issue, it's just bothering me because I don't remember this happening with the old install
Old 11-12-2009, 07:32 AM   #12
guino's Avatar
Just change it to:
"KillWinamp",""
Under "NORMAL" circumstances, there's no need to kill winamp.
Old 11-13-2009, 07:09 PM   #13
Thanks, that helped a lot. It only works now if I exit RR before I shut down the pc (shutting down without exiting still forgets the current track) but at least I have a way to preserve the track number
Old 11-13-2009, 08:52 PM   #14
guino's Avatar
How are you shutting down ? power button ? shutdown option in RR ? I suggest you try different methods to see if it makes a difference.
Unread 11-22-2009, 01:50 PM   #15
kbreeden
Bump - Same Problem Here
I'm now having the same problem. I've been using RR with the DFX skin for years now and this has just started. Whenever I close RR and restart only the first song in the playlist that was loaded at the time of close will appear. I have verified that resume mode is set to always in RRConfig and that resumemusic=2 in rr.ini.
I have now done fresh installs of both RR and DFX on two computers and it's happening on both. I have verified that resume works fine with Carwings, but it now does not work with DFX. DFX has not changed in over a year so it must have something to do with the new RR version and how it interacts with DFX. Any thoughts?
I'll post this in the DFX thread as well.
Thanks in advance.
kbreeden is offline   Reply With Quote
Smart Music - 04OCT09 ThunderStick RR Released Plugins 20 10-04-2009 11:15 PM
Ideal music player in a front-end - does anything like it exist? mrpeenut24 Software & Software Development 2 03-04-2009 06:54 AM
First impressions, bugs and features of Infill G4 & Street Deck 1.1.0.0 DAE51D StreetDeck 34 11-06-2007 03:42 PM
Music Age/Organization Quattro Software & Software Development 2 01-24-2006 07:12 AM
Music screen doesnt update the currently playing song in the list fasternfaster RR Bug Tracker 2 06-25-2005 12:56 PM
