Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 07-20-2009, 08:52 AM   #1
rodweb is an unknown quantity at this point
Volume control and ASIO sound card in RR
Hi guys
I bought a new USB sound card see: http://www.cakewalk.com/products/UAUM/UA1G.asp
I thought I had it all working well until I tried using my GPS and the volume went to 100% and nearly blasted me out of the cab. On closer investigation, I realised that he problem is the ASIO drivers do not have a master volume control. I see Foobar and Winamp have an ASIO plugin which I will have a play with tomorrow but are there any pointers on which volume control RR should be configured to control?
There is also a switch on the unit which disables the ASIO drivers and leaves everything with the standard Windows drivers So I might play with that as well... Too late at night here...Maybe that might restore the master voume control in the mixer...
RodW
2007 Toyota Hilux with a CarPC..
Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
rodweb is offline   Reply With Quote
Old 07-20-2009, 10:25 AM   #2
Raw Wave
mitchjs is on a distinguished road
no need for asio drivers in a carpc...
go with std wdm drivers
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 07-20-2009, 04:52 PM   #3
Thanks Mitch but still no Master Volume Control, so it's not such a good one for a Car PC. Shows up as USB speakers
RodW
Old 07-20-2009, 05:15 PM   #4
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
as quino(the rr mastermind )so kindly pointed out to me before, rr uses the master volume controler in the taskbar to control the volume, and if it isn't there, it wont control the device(the problem i had).
asio was originally devloped for the music industry as a way to modify the audio signal in real time, and transmit it to a live audience.
for most of us, we are using asio drivers as a way to modify the audio signal while it is still in the digital domain, to preserve teh signal. becasue we are not dealing w/ live sound, latency is not as important.
the vst hosts that use asio require a asio driver for both the input and output, but at least some(console) allow for only one asio device (for both input and output). this makes any asio sound card driver useless(only output).
almost everyone here that is interested in processing the audio uses virtual audio cable, or asio4all, and a vst host. some use only asio4all, and a vsthost, others use all 3.
if this is all greek to you, you are going to have alot of research ahead of you.
if you understand it all, you are welcome to tell me where to go
soundman98 is offline   Reply With Quote
Old 08-07-2009, 03:43 PM   #5
swordfishunter is on a distinguished road
asio4all will do, set the gps volume with wave in rr, then map the master volume control. winamp volume wont work.
swordfishunter is offline   Reply With Quote
Volume control for ASIO / VST setups? JuniorGeezer High End Solutions 2 07-19-2009 12:35 PM
Sound Processing and X-Meridian qpwoeiruty999 High End Solutions 11 01-13-2009 08:15 AM
ASIO or Kernel Streaming volume control through Roadrunner cougarz Road Runner 8 09-25-2007 07:20 PM
M-Audio with ASIO volume control mkysimes2 Road Runner 6 04-17-2007 12:25 AM
USB Sound Card with ASIO driver and volume control tbdombrosky General Hardware Discussion 0 02-04-2003 12:00 AM
