Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 07-26-2009, 04:35 PM   #1
mdawg can only hope to improve
Winamp not saving my EQ
Am I missing some setting in RR to make it save me EQ setup. Everytime I restart RR I have to go back in and adjust everything along with my line in volume for my XM it keeps going all the way back down and I have to turn it back up. My skin I am using is Simplistique and it doesnt have anything like a save EQ button.
mdawg is offline   Reply With Quote
Old 07-26-2009, 07:43 PM   #2
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
FIRST: Make sure you're not using winamp LITE or you could get some weird issues. Other than that, RR doesn't change/save EQ settings -- just shows what's on winamp, so you should run winamp alone (no RR) and see if whatever you set stays when closing and re-opening it -- if not, then you need to see what's causing it to loose its settings, maybe remove and re-install it. For your XM volume, how do you get the XM audio in ? through an audio line ? If so, you may want to check the map master volume in RRConfig -- set it to MASTER. Also try changing the output plugin in winamp between directshow and waveout to see if it helps.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
WinAMP 5 Comes to front on launch macbrando Road Runner 7 09-05-2007 09:01 PM
Digital Crossover and EQ spoonraker Car Audio 12 03-18-2007 10:50 PM
Winamp volume problems froop Road Runner 9 09-17-2005 12:02 PM
No more winamp EQ problems!! (for lorty users) embedded Software & Software Development 0 03-28-2001 03:16 AM
Winamp EQ Control Brain General Hardware Discussion 0 02-29-2000 08:31 PM
